Question about Mitsubishi VS-60607 TV
I pressed the menu input button at the same time and the green light came on. It blinked once paused and then blinked twice. Please tell me what this means and how I can fix it! Thank you so much! Model Is vs 50705 Ac 120 v 60 hz 240 w
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
1,2 IS NO ERROR DETECTED.
YOU need to do something else, remove front speaker grill, it should pull off, remove inspection plate behind it.
These sets have a history of coolant leaking on circuit boards.
Each of the three picture tubes has a sealed area full of Glycol, clear liquid like antifreeze but 10 times more concentrated and toxic.
With inspection plate off, use a flashlight and look at front 3 or 4 FRONT inches of the big boards--Glycol will appear in two ways and you have to look carefully for it.
It will either be a small amount of clear liquid or look like the discoloration you see on battery cables in a car--if you see this and any liquid, do not touch it as you can absorb it by touching it.
I have looked before and not seen it at first--it may also appear as a somewhat white discoloration on solder connections or leads on parts.
If you find it, it is usually fatal to the set.
Let me know what you find and LOOK CAREFULLY.
sd tech
Posted on Aug 24, 2010
When I turn the tv on,,it just turn off,,
do the self check this model has. When green power light goes out on the front of the set press and hold both the menu and input (device) buttons at the same time for at least 5 seconds and then let go of both.
Power light (green) should blink a two digit code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code you find and I will tell you what it means.
SD TECH
Sep 14, 2011 | Mitsubishi WT-46809 46" Rear Projection...
Want all region code for Sony theatre player DAV-X1G
it's possible to unlock with a remote control.I Used a "One-For-All" remote.
This process is working on more that this Sony DVD players.
First prepare the remote control to use right device code.
1: Select the DVD button on the remote
2: Hold "Magic/Set" button util the LED blinks twice (Rabbit appears)
3: Press numbers 0533
Now program the remote control to send special codes on button 1 to 5.
1: Hold "Magic/Set" button until the LED blinks twice (Rabbit appears)
2: Press numbers 994
3: Press "Magic/Set" button once
4: Press number 1891
5: Wait some time
6: Hold "Magic/Set" button until the LED blinks twice (Rabbit appears)
7: Press numbers 994
8: Press "Magic/Set" button once
9: Press number 2552
10: Wait some time
11: Hold "Magic/Set" button until the LED blinks twice (Rabbit appears)
12: Press numbers 994
13: Press "Magic/Set" button once
14: Press number 0953
15: Wait some time
16: Hold "Magic/Set" button until the LED blinks twice (Rabbit appears)
17: Press numbers 994
18: Press "Magic/Set" button once
19: Press number 2214
20: Wait some time
21: Hold "Magic/Set" button until the LED blinks twice (Rabbit appears)
22: Press numbers 994
23: Press "Magic/Set" button once
24: Press number 0795
25: Wait some time
Now the remote is ready for use on the DAV-X1
1: Start the DVD without any DVD in it.
2: At the same time press and hold "Eject" and "Stop" in and then press "volume +" to get into the service menu
3: Now use your programmed remote
4: Press button 12345 with a small pause between each num.
5: Press button 12345 with a small pause between each num.
6: Wait some time
6: Press button 12345 with a small pause between each num.
7: Now use your orginal remote and turn the DVD off
Tested to play Region 2 and Region 1 DVDs without any problems after this. (The remote i used was a Cameleon 6)
May 13, 2011 | Audio Players & Recorders
Green powere lights comes on and goes off.
Do the self check this set has, when green light comes on and goes off, on front of set press and hold both the Menu and Input (device) buttons at the same time for at least five seconds and release both buttons.
The power light will blink a two digit error code like, two blinks, two blinks, a pause and repeat it several times.
Let me know what error code you get and I will tell you what it means.
SD TECH
Jan 17, 2011 | Mitsubishi WS-65809 65" Rear Projection...
"on" light flashes twice and then "blacks out"
IF power light comes on and a few seconds later goes off, do the self check this model has.
On front of set when this happens, press and hold both the menu and input (device) buttons at the same time for at least 5 seconds and then release both buttons.
Watch the power light closely, it should blink a two digit error code like; 2 blinks, 2 blinks, a pause and then repeat it several times.
SD TECH
Dec 11, 2010 | Mitsubishi WS-65909 65" Rear Projection...
Turns off immediately after turned on
Do the self check it should have: when shuts down and green light goes out: On the front of the set press and hold both input and menu buttons at the same time for at least 5 seconds and then release both.
Power light on set should blink a two digit error code: like 2 blink,2 blink, pause and repeat it at least 5 times total.
Let me know what error code and I will tell you what it means.
If this has helped you, rate this solution as I do this here for free.
SD TECH
Aug 15, 2010 | Mitsubishi WS-55809 55" Rear Projection...
My tv green light comes on but then turns back off cant watch tv why is that
when you turn it on and then the green power light goes off:
On the front of the set press and hold both the Menu and Input buttons at the same time for at least 5 seconds and then release both.
The green power light should blink a error code at least 5 times: most common is 2 blinks, pause and 2 blinks----
Let me know what error code you find and I will tell you what it means--2,2 is the most easy to fix and common.
SD TECH
Aug 03, 2010 | Mitsubishi WS-55513 55" Rear Projection...
Powers on then shuts off in 2 or 3 seconds with a green light
Please do the self check this model should have;
When power light comes on and then goes off: On the front of the set press and hold both the Menu and Input (or device) for at least five seconds and then release both buttons.
Watch the power light as it should now blink a two digit error code--for example--2 blinks, a pause and 2 blinks. It will repeat the code at least five times.
SD TECH Steve
Jun 10, 2010 | Mitsubishi WS-55819 55" Rear Projection...
Mitsubishi Medallion 72 inches Tv support does not turn on, when we touch the power button the green lights turns on and there is a clicking sound and the green light goes out
Please try the self check feature this set has:
when power light comes on and then goes off: On the front of the set press and hold both Menu and Input (or device) buttons both for at least 5 seconds and then release both.
The power light should blink a two digit error code--like--2 blinks, a pause, 2 blinks..........it will repeat the error code several times.
Let me know what you find and I will tell you what the error may mean.
If this helped you rate this solution as I do this here for free.
SD TECH
Dec 20, 2009 | Mitsubishi WS-55511 55" Rear Projection...
My mitsubishi 65087 remote stopped working and none of the buttons on the front control panel would work either, including the power button. Couldn't turn set off, so unplugged. When plugged back in, green...
ws65087 or what?
Most of these sets have a self check feature--when power light goes off press and hold both the Menu and Input buttons for 5 seconds and release both--power light should blink a two digit code--like,,,,,,,,2 blinks a pause and 2 blinks---CONFIRM EXACT MODEL NUMBER AND ERROR CODE FOR ME.
Allow for time difference--I am in California.
sd tech
Oct 12, 2009 | Televison & Video
Mitsubishi VS-60607 TV Logo
198 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
