Question about E-Machines Computers & Internet
I need a video controller vga comptable for a emachine t2080 which will allow my video card to work properly however, do i need to open the tower to check the maker and serial numbers of the card i thought that emachine was proprietary and that i would not need to do this i tryed to google this and all i find is scan your pc and update the driver automaticly but i have no internet connection to this pc so i was tryin to find the original driver
    Brigadier General:
  • 10,406 Answers
From the manufacturer's web-site:
http://global-download.acer.com/GDFiles/Driver/VGA/VGA_S3_6.13.10.1061_XPx86W2K_A.zip?acerid=633935235276656256&Step1=Desktop&Step2=TSeries&Step3=T2080&OS=X01&LC=en&BC=eMachines&SC=PA_6E
there is a downloadable ZIP file for the VGA adapter for Windows XP.
Download that file, and copy it to a USB memory-stick.
Take the memory-stick to your eMachines system, and copy the file.
Then, right-mouse-click on the copy, and choose 'Extract All'.
Then, install from the un-ZIP'd files.
Posted on Aug 24, 2010
Emachines el1200 will not start up. When power button is turned on...it will blink shortly after ( no beeps ). It will not turn on monitor
As mentioned that when you turn on the system the lights on the system turns on and the monitor goes off, unplug the VGA cable from the system tower and turn on the monitor and check if you get signals on the screen if it shows you some color bar or a massage, that means your monitor is good. IF not then there is problem with the monitor . get it repaired or replace it. If that is not the case you would need to unplug all the external devices connected to the tower and try, IF not then you need to open the tower and check for the green light on the motherboard if it comes on or you can try reseting the memory card or if you have an video card, then you will have to remove the card and try the build in one .
Regards
Samson ved
Oct 21, 2013 | Computers & Internet
No Video
If its a flat screen monitor ?
eMachines flat-screen monitors offer high quality at low cost. eMachines flat-screen monitors are compatible with most brands of PCs. Issues with eMachines flat-screen monitors can arise from faulty power sources, cable problems and incompatible settings. These issues can be resolved by testing step-by-step each possible cause.
Plug the computer's power cable firmly into a working AC outlet. Press the computer's power button.
Check the LEDs on the front of the computer case to confirm that the computer receives power. Plug the eMachines monitor's power cable into a working AC outlet. Press the monitor's power button. Check the LEDs on the front bezel or power button of the eMachines monitor to confirm that the monitor receives power. Orange or blinking LEDs indicate low power or no signal. Green LEDs denote a working connection.. Perform a monitor self-test. Switch off the monitor. Unplug the video cable from the monitor. Press the eMachines monitor's power button. An eMachines logo, Windows logo or "no signal" message indicates that the monitor is working properly. Plug the eMachines monitor's video cable into the video port on the computer. Attach the monitor's included DVI-to-VGA adapter to the monitor's VGA cable if your computer has a DVI port (15 or 25 pin-slots with 1 side slot) in place of a VGA port (15 pin-slots, no side slot). Press the eMachines monitor's input button to change the monitor's setting to match the computer port used. Set your monitor to DVI if connected to your computer's DVI port. Set your monitor to VGA if connected to your computer's VGA port. Connect the eMachines monitor to a known working computer with a known working video cable if the problem persists. Contact Gateway, eMachines manufacturer, if the monitor issue is not resolved. Hope this helps.
Jan 03, 2013 | Computers & Internet
Can i connect my xbox 360 using Dvi D to Hdmi in the dvi slot and also my tower to the vga slot on my eMachines E19T6W
I am not an xbox person, but as far as hooking it up, it should work as long as the other device is NOT powered up. That being said you will still have to provide audio from the xbox another way as dvi only carries a video signal, unlike the hdmi which carries both audio and video.
Dec 12, 2011 | eMachines E19T6W 19" Monitor
When turning on the emachine, No Signal shows on the monitor
Please check the cable at the back of the tower connected to the monitor. Make sure its plugged in properly on both ends. If you have another monitor, try connecting that. If still, that does not work, then, check on the video card. If you have a video card, then you should connect your monitor there, and not the internal one. Still doesn't work, try reinstalling the driver for your video card.
Dec 19, 2009 | E-Machines eMachines Desktop PC
There is no signal getting to from my computer to the monitor - Help... I have replaced the cord, but it did not work. The monitor is working fine as I hooked it up to another computer. Tries the opposite...
It is the video card!
So, when you plug the monitor in to the rear of the eMachine case, do you connect it in the aread where the keyboard mouse and USB and sound conntors are OR do you connect to the area when all the expansion slot covers are?
If you answered YES to the first part of the question, then the video signal comes from an 'integrated' video card that is part of the mainboard. This is bad. Contact eMachines in order todetermine if the system will allow a video card to be installed in an expansion slot...
If the second part of the quetion is YES, this is better. You can replace the video card andprobably be OK. Get you teenager to open up the case and pull out the video card. You need a new one but they come in multiple 'types' so you need some to have look at it and sell you another compatible one.
Oct 13, 2009 | eMachines W3611 PC Desktop
My tower comes on but i cant see anything on the screen. sometimes it works but most of the time i see nothing except a box that says monitor is working, check pc.
the graphics card in your pc maybe loose. the grapics card is located where you plug your vga/dvi connection in to the back of the tower. If you slide open the town you will see the graphics card in a brown slot beside the white PCI slots. check if it is secure.
Also the vga/dvi cable maybe faulty try a different cable.
Aug 06, 2009 | E-Machines eMachines Desktop PC
T2080 processor driverd
Try This:
http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=T%20Series&model=T2080
This site will have all the drivers you need for yopu T2080 PC
Good Luck
DR GEEK MD
May 09, 2009 | Computers & Internet
F1903 not turning on with tower when restarting
Get a PCI or VGA video Card!
I'd recommend at least somethin like a
nVidia GeForce 7300 GT (256mb) Video Card
You can get one for dirt cheap on Newegg.com
Or your local PC store/Repair shop.
The Problem you are having is your Video Card Driver isn't the correct one, or it's got issues...
You should get a better video card.....yours might be onboard or really low-end rated.
FYI -
Pre-Manufactured PCs generally ****..... I build WAY better PCs for less.
HPs ****, but not as bad as a Dell (Dell does make the best pre mf 'd Servers which is ironic!)
but the worst pre mf'd PC I've ever fixed was a GATEWAY........
Apr 19, 2009 | HP Pavilion F1903 19" Flat Panel LCD...
Need to replace M/O for eMachine T2080
go to the web address line and type in fine that type of mother board it will come up
Dec 13, 2008 | E-Machines eMachines Refurbished EMA / AMD...
Graphic Card
jumper settings for old graphic needs to be disabled or in the bios settings the on board vga settings need to be disabled this will allow the other new card to be ran as the dominent only video card
jumper settings are tricky
but bios settings are easy just find vga and disable on board video thats it save and boot
Jun 04, 2008 | E-Machines EMA IMPERIAL GV (845GV) TG3...
Computers & Internet Logo
81 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
