My brother dcp 7030 printer shows the "Toner Life End" message even if i replace the new toner cartridge. so, please what is the exact proble of my printer and how can i solve this problem?
ctf1800
  • 4402 Answers
SOURCE: brother dcp 7020 says toner end life
unplug plug it back in, did you remove the protective cover and clean coria wire?
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000000/000065/faq000065_018.html?reg=us&c=us&lang=en&prod=dcp7020_us
Posted on Dec 20, 2007
SOURCE: Toner Problem.
Is this a remanufactured/ compatible unit? I suspect that the toner reset lever on the cartridge has either not been installed or not properly set. return for another one
Posted on Apr 24, 2009
komguy
  • 2306 Answers
SOURCE: Toner Life End message on DCP-7040
If your cartridge has a lever on the left side near the rear, it needs to be reset, and there's a lever inside on the left that can stick and cause that error. You need to wiggle and pull that lever until it moves freely again.
Posted on Jan 04, 2010
SOURCE: i have a printer dcp 7030 brother company i am
i have a printer dcp 7030 brother company i am showing problem toner life end after reffling
Posted on Oct 28, 2010
SOURCE: i have dcp-7030 brother printer.
I know how to solve drum end problem along with change tonner.... Send me mail on mananadhaprabin@hotmail.com... Thanks
Posted on Dec 10, 2010
My brother DCP 7055 shows eror replace toner
Some Brother laser printers have separate consumables - the toner cartridge and the drum unit. From time to time you may need to replace only the drum unit and not the toner cartridge.
The error LED lights up, or an error message shows on a flat screen panel, when the drum unit is near the end of its working life. Use the drum unit until you have a print quality problem, then replace the drum unit with a new one.
Jul 26, 2012 | Brother 1 Black Genuine Laser Toner For...
Error message "put the black toner cartridge back in"
I got this same error message on a newly acquired Brother DCP-7040 that I purchased used off of ebay.
As I was troubleshooting this unit (that I bought untested off of ebay - hey gambling has paid off handsomely for me many times before!), this error message kept popping up.
I checked the COUNTERS (page & Drum life) and found out that the DRUM had 0% life left. BUT, the reason it showed ZERO was because this unit did not have any drum! The toner cartridge (TN-360) needs to sit WITHIN the drum (DR-360) on this DCP-7040 unit, as well as in models DCP-7030, MFC-7340, MFC-7345C, and MFC-7440N.
So perhaps some of these "put the black toner cartridge back in" problems could be related to the DRUM (or lack thereof). A possible tipoff (since the toner cartridge actually does slide into the unit much like other units that do not use Brother's DRUM carrier) seems to be the relative ease with which the toner cartridge slides into the DCP-7040 and really doesn't seem to "lock" into position real firmly.
DCP-7040 USER GUIDES: http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_index.html?reg=us&type2=-1&prod=dcp7040_us_as&c=us&lang=en&flang=all
Apr 23, 2012 | Brother MFC-7340 All-In-One Laser Printer
Toner life end replace toner catridge message on the screen
When the toner cartridge is exhausted or empty then theprinter will not be able to print further documents or the prints will be veryfaint. You may be able to print a few more pages by removing thetoner cartridge and shaking the toner cartridge in a horizontal position a fewtimes and then placing it back into the printer. This will give you an opportunity to print a few more pages and give you time to purchase a new tonercartridge for your printer. A cheaper alternative is to purchase are-manufactured toner cartridge for your model printer.
Feb 24, 2011 | Brother DCP-7030 Digital All-in-One Laser...
DCP 7030 printer says toner life end, replace toner cartridge. After replacing the toner printer still gives the same message and will not print.
What worked for me was to follow the instructions in this video: Resetting lever on cartridge There is a lever on the left hand side of the toner cartridge (left hand side - with you holding the cartridge as if you were going to insert it into the printer). It seems that lever has to be at the '12 o'clock' position to tell the printer that you have a new cartridge. The video showed the person removing 3 screws and then ensuring the lever was at the '12 o'clock' position. On my cartridge I had to do some wiggling to get the lever to move as it's gear assembly seemed to want it to only move down to the '4 o'clock position' and then stay there. Eventually I got it moved to 12 o'clock - and when I stuck the toner back into the printer - the 'toner end of life' message went away. I then removed the toner cartridge - as I wanted to try another cartridge that I had also reset the lever on. I found that lever had again moved to the 3 or 4 o'clock position - after printing just one test page so I am guessing it being at the 12 o'clock position tells the printer you have a new cartridge - and then it moves over to the regular position at 3 or 4 o'clock..
Feb 01, 2011 | Brother DCP-7030 Digital All-in-One Laser...
I have a printer dcp 7030 brother company i am showing problem 'toner life end change your cartridge' after reffling. i have no new cartridge what can i do?
If printer displays "Toner Life End" after installing new cartridge, open front cover, press 'Option' button, then key *00 on the keypad. This resets the device so it knows it has had a new cartridge.
this will reset toner counter on a lot of brother printers good luck
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 29, 2010 | Brother DCP-7030 Digital All-in-One Laser...
I have a printer dcp 7030 brother company i am showing problem toner life end after reffling
I just had this problem and fixed it. The original toner cartridge that comes with the printer cannot be reset. You have to buy at least one new cartridge. The reason is that the original cartridge that comes with the printer doesn't have a reset flag. You can, however, refill/reset a cartridge that you buy separately. Pull out the drum and lift the cartridge out of the drum. Hold the handle and look on the left end. You should see a crescent shaped hole with a white flag/lever. To reset this, move the white flag all the way to the left (I had to use something to push it). Put it back into the printer and voila - it fixes itself. Then, after the printer has been reset, you can use the original cartridge again, if you want. The flag part won't matter once the printer has been reset. I hope this is clear. I know it worked for me, and I had the exact same problem.
Jul 14, 2010 | Brother DCP-7030 Digital All-in-One Laser...
Toner Problem.
Apr 24, 2009 | Brother DCP-7030 Digital All-in-One Laser...
119 people viewed this question
jasbo
jasbo
