Question about JVC Car Audio & Video
20006 dx nissan navara i am trying to find the constant power wire and colour of this wire from factory radio harness i am fitting an aftermarket cd player
    Problem Solver:
  • 5 Answers
Yes I havn't heard of this vehicle. But most all Nissans the yellow wire in the radio wire harness is the 12V.
Posted on Aug 24, 2010
I have a 1985 ford ltd crown vic I just bought a aftermarket radio but the wiring isn't the same its still has the factory radio and wiring kit how do I change them in order to use my new cd player
You can go to best buy or a stereo shop they have wiring harnesses and fit kits for aftermarket CD player the wiring harness plugs into the stock wiring harness the u have to match the wires to the cd play
Mar 28, 2014 | Cars & Trucks
Radio wiring colours nissan nivara 2006
fastest and easiest way to do it would be to get used plugs from the junkyard and then get a wire harness for the radio to fit it, most auto parts stores carry the radio harness.
Oct 16, 2012 | 2006 Nissan Navara 2.5
Audio wiring diagram for 04 nissan navara needed. with colour coding please
This model is also called Nissan Frontier2001-2004 Nissan Frontier (North America) Nissan D22 Navara (Australia).
Then, check this:
2004 Nissan Frontier Truck Car Radio Stereo Audio Wiring DiagramCar Radio Battery Constant 12v+ Wire: PinkCar Radio Accessory Switched 12v+ Wire: BlueCar Radio Ground Wire: GrayCar Radio Illumination Wire: Red/BlueCar Stereo Dimmer Wire: Red/YellowCar Stereo Antenna Trigger: N/ACar Stereo Amp Trigger Wire: N/ACar Stereo Amplifier Location: N/ACar Audio Front Speakers Size: N/ACar Audio Front Speakers Location: N/ALeft Front Speaker Positive Wire (+): PinkLeft Front Speaker Negative Wire (-): BlueRight Front Speaker Positive Wire (+): WhiteRight Front Speaker Negative Wire (-): BlackCar Audio Rear Speakers Size: N/ACar Audio Rear Speakers Location: N/ALeft Rear Speaker Positive Wire (+): Light GreenLeft Rear Speaker Negative Wire (-): VioletRight Rear Speaker Positive Wire (+): BlueRight Rear Speaker Negative Wire (-): Pink
Hope this helps.
Apr 23, 2012 | Nissan Navara Cars & Trucks
Do the jvs have a memory wire. I tryin to put this in a 2001 nissan altima. I need to know if the car have a memory wire for this redio.
You need to hook up the yellow wire from JVC to the yellow/green wire in car(12+ constant memory) and the red wire from JVC to purple from car(switched 12+ volt accessory)
Hope this gets you tuned in!
Oct 23, 2009 | JVC AM FM CD DET FACE CAR STEREO
96 dodge caravan radio wires
see an auto sparks ,or take to a local radio fitting shop ,no good telling me here because colours of wires can vary between manufacturers of both the radios and the vehicles
Aug 07, 2009 | 1996 Dodge Caravan
Installing newer radio in older truck
Hello zachary_reed,
What you need is an aftermarket wiring harness. These are made by Metra, Scosche, and others and are made to plug directly into the OEM radio harness. It appears that the one you want is the Scosche FB02B available from SonicElectronix. You simply connect the wires from your new receiver to the harness wires and then plug it into the factory radio plug. Another online retailer that sells aftermarket harnesses is www.crutchfield.com. Your local car audio shop or perhaps Best Buy may also have the wiring harness.
Be sure to match up the wires from your new radio harness to the aftermarket harness by FUNCTION, not by color. For example, most newer receivers will use Yellow as the 12V constant (hot) wire. The wiring color code for your F150 is shown here. Make sure that the pin on the aftermarket harness is connecting the yellow from your new receiver to the green/yellow of the OEM plug and so on.
Hope this helps.
Jun 09, 2009 | Pioneer DEH-1100 CD Player
2003 silverado z71
You could get a stereo installation kit for your year, make & model, that comes with a pigtail plug that would plug right into the existing harness plug and prevent you from having to hack up your original wiring harness.
If not....
Car Radio memory Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: The radio harness does not provide a switched power source. Run a wire to the fusebox for switched power.
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Good luck
Aduz
Mar 21, 2009 | Alpine iDA-X200 Car CD/ MP3 Player
Tried to put an aftermarket radio.
Hello, If you haven't cut any wires you really don't need to. They make a plug that you can get at wally world for about $15. It makes a clean installation and when you get ready to sell the envoy you will be able to replace the aftermarket back with the stock radio. It will make the wiring simple and easy also has an adapter for the antenna. Please rate my answer, Thank you.
Mar 04, 2009 | 1999 GMC Envoy
Wiring difference
If your installing a stock radio/cd player from another Dodge the wiring plug is the same and will fit.If your installing a aftermarket radio/cd player(JVC,Pioneer,etc)you will need to buy a adapter plug that wires up to the radio and is a direct fit to your factory wire harness,so your not cutting your wires.When you buy the adapter plug it comes with a wire diagram of which wire is what.Your aftermarket radio should have a diagram also,either on it or in the manual.Hope this helps you.
Mar 04, 2009 | 2002 Dodge Caravan
How do I know if a new/used car cd player will fit?
yes.......... just buy a mounting kit for your car and a wire harness for your car.........to install just unplug factory radio and clip the harness on to factory plugs that you just unhooked from factory radio now just attach the same colour to colour wires from your new deck to the harness......mounting kit comes with instructions
(make sure to buy WIRE HARNESS & MOUNTING KIT for your car) and your install should take less than a hr to do
have fun
Feb 18, 2009 | Pioneer DEH-P2000 CD Player
Car Audio & Video Logo
233 people viewed this question
Top JVC Car Audio & Video Experts
Radames Pagan
Radames Pagan
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
