Question about Sharp Aquos LC-46D62U 46 in. LCD HDTV
Coax conection broke off tv - Sharp Aquos LC-46D62U 46 in. LCD HDTV
    Scholar:
  • 72 Answers
If the coxal connection broke of u can order a replacment tuner. It will just have to be solder in and the old one taken out. If u send me the model number of your tv and first 6 digits of serial number i should be able to find a replacement if i dont have one already.
Posted on May 06, 2008
Looking for cable with analog on one end and coax on other end
Since you're going to be soldering anyway, these are available on ebay. Just keep your wire as short as reasonable.
The other way is just grab a short f-type to f-type coax (standard TV coax cable) , and cut off one end. Then unweave the shield and solder into a bundle with a short wire to the TV antenna ground.
Sep 11, 2016 | Westinghouse Televison & Video
Do they make a adaptor that goes from coax to hdmi or video plugs
No - co-ax is used to carry a signal at RF level while HDMI is audio/video.
A co-ax socket can be replaced by any qualified technician
May 04, 2015 | Televison & Video
I can't get channel 3 to show satellite channels. They only show up on Video 3. I need channel 3 to work for surround sound. I checked wiring diagram and it looks like everything is hooked up the way it...
The only way this will show on channel three is to have the receiver connected via coax to the TV and since it is displaying on Video 3 it either is not or it is connected in more than one manner and the Coax port on either the receiver ot TV may be bad.
Lets just ensure that tha coax from the back of the receiver is attached to the CH3-4 out port and then run to the back of the TV. If the TV has a dual coax input it will need to be connected to the analog or antenna port.
If the receiver does not have a coax port for TV1 you can get an rf modulator to facillitate this conection.
If all else fails try taking the red and white cables that are connected to the TV from the receiver and connecting it to the surround directly.
I hope this assists you.
Thanks for using Fix Ya and being a valued Dish Network customer.
Mar 27, 2010 | DISH Network IR Remote Control
I WANT TO BE ABLE TO SEND SKY TV SIGNAL TO ANY ROOM, i HAD THIS IN OUR LAST HOUSE BUT CAN NOT REMEMBER HOW i RUN ALL THE COAX CABLES. i HAVE AN APLIFIER IN LOFT WHICH CABLES TO EACH ROOM, SO DO i NEED TO...
put coax from sky box output then into splitter in loft ampifier and conect all other coax that run down to other rooms to the outputs in amplifrer and turn on sky and put menu on then tune tv's in on anolog station
Dec 20, 2009 | Panasonic TH-42PX60U Television
I have plenty of old TV's that have a standard cable input, but no AV input (The white and yellow plugs that modern TV's have). Do they make a converter that turns the yellow and white AV plugs into a...
these are not cross compatible an rca hook up is a base band signal basically raw data, and coax(cable line) is a frequency with a carrier best suggestion I have is to buy a vcr with a coax out put and rca input that way the vcr can pick up the video signal then remodulate it onto a channel frequency and send it to the tv
Apr 14, 2009 | Televison & Video
Coax cable broke off my wife tryed to put back in the cable line with coax insert broke off there was connector on the cable line she just jammed the bare cable line into the hole where the coax...
Yes there is a possibility that something shorted... remove the cable wire and unplug for 10 to 30 min and try plugging back in and restarting the set. otherwise the tuner probaly would need replaced. something any tv tech can do. AT the shop we replace these conectors al the time. just depends how bad the tuner is damaged.
Mar 17, 2009 | RCA Televison & Video
EWF TV ANT IN BOKEN
ANGLS186-YES YOU CAN RESOLDER THE ANT. IN COAX CONECTION BUT KNOW YOU MUST FIRST SOLDER THE CENTER WIRE OF COAX TO TUNER BD. THEN CAREFULLY INSERT COAX BACK INTO ORIGINAL POSITION.THE EASIER SOLUTION IS TO USE A VCR OR CABLE BOX HOOKED TO YOUR SETS' VIDEO IN PORT AND CHANGE CANNELS W.THAT COMPONENT.JOE TV
Nov 19, 2007 | Emerson EWF2004 20" TV
Sharp 36R-S450 Coax broke off Help!!
it should be alot to fix all u have to do is buy the coax connector n solder it
Oct 28, 2007 | Sharp 36R-S450 36" TV
Sharp Aquos LC-46D62U 46 in. LCD HDTV Logo
97 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
