Question about Dishwashers
I press the "start" button and the "2Hr" light just keeps on flashing. unit does not start. then light goes out.
  • 530 Answers
Do you have a maytag? just curious
sounds like you have a bad touch panel
if you can not control the keypad and no keys respond, you have a bad keypad
Posted on Aug 24, 2010
Testimonial: "Yep, its a Maytag. thanks for the great info!!!"
  • erica graber Aug 24, 2010
    You might want to have it checked there is a recall on maytag dishwashers for 2006 to 2009 i believe on the heaters
Sometimes, when we start the carmera and want to take a photo and press the button to take one, a small red light starts to shine. we didn't configure anything on the settings. this is really anoying
Sounds like a feature that comes on when using flash. The light comes on so in low light you can see and focus on what you are trying to photograph. Then we shutter button is depressed all the way the flash goes and picture is taken. Try turning off flash function.
Apr 23, 2014 | FUJIFILM Instax 210 Film Camera
Danfoss rx1 thermostat shows 'of' ?
Remove batteries from room stat,turn off the electrical supply to reciever unit.
Turn back on the electric to reciever unit,the red light should be on,press the top "manual" button,the green light should come on and boiler should fire (assuming the programmer is in an "on" period)
Press the bottom button,and keep it pressed,then press the top button until the green light flashes,stand about 6 feet away,and refit the batteries to the stat while observing the reciever unit,either the red or green light (cant remember which) should flash to show the 2 units are syncronised.
Another basic test if all seems ok,when turning the stat up or down,when the green light on the reciever unit comes on or goes off,its usually accompanied by an audible "click" ive found,that if this is not happening, the reciever unit does not switch either on or off,may be intermittant.
Replacement is the only cure.
garden led light
Jun 04, 2012 | Garden
How to program ct 68a remote
Text from manual below. Pictures of manual attached.
TO"LEARN" A FIX CODE PROGRAM FROM ANOTHER UNIT:
1. Press and hold both buttons (1 & 2) on the SPR. The LED will flash three times. Keep holding {for about five
seconds) until the LED flashes again (twice), indicating that it's ready to duplicate your garage door opener's
code. Release both buttons (Fig. 1 ).
2. Place your existing garage door remote and the SPR unit within an inch of each other. Press and hold the
first button on the existing unit while pressing button 1 on the SPR unit. The LED will flash, indicating that it
is learning. Keep holding the buttons until the LED light goes out. At this point, the SPR unit has duplicated
the code (Fig. 2).
3. Follow Step 2 to duplicate another code.
4. Exit the learning mode after duplicating codes by pressing and holding both buttons on the SPR unit. The
LED will flash once to indicate that you have exited learning mode. Examine the unit to see if your codes
were duplicated completely.
TO EXAMINE CODES:
If the remote is programmed correctly, the LED stays lit while the button is pressed.
If code duplication has failed, the LED will flash when the button is pressed. Follow Step 1 again if duplication
has failed.
TO LEARN GENIE ROLLING CODES:
Genie rolling codes require special additional instructions to program. Once step 1 through step 4 of the Fixed Code
Instructions are completed, you must do the following:
A. Pra•ce the SPR on the top surface near the rear of the original Genie
Remote instead of setting the two units side by side during Step 2 of the
Fixed Code Instruction; shown as Fig. 3
B: Press the Learn Code Button on the Genie Unit. The LED on it will keep
flashing.
C: Press the program button on the SPR. The LED on the Genie Unit will stop
flashing and become a solid glow
D: Press the same button on the SPR for the second time- turning off the
LED light on Genie Unit and finish the Genie Code Duplication.
E: Follow the EXAMINE CODE section of the fixed code instruction to test code duplication.
F. Follow the above steps if you wish to duplicate another Genie Code on your SPR.
NOTE:
If the first time you only programmed one button on your SPR, and you would like to program the second button later
on, either with FIXED CODE or GENIE ROLLING CODE, you will have to REPEAT step one of the fixed code
instruction to enter the leaning mode; then follow the instruction listed previously. After duplication, you will have to
repeat step 4 of the fixed code instruction for exit learning mode as well. This is very important.
Nov 07, 2011 | Brookstone 538744 Remote Control
Timer switch mode is inoperable. no lights in timer setting, the lg ld450eal model operates continously. please advise how to program the 2 hour or 4 hour timer
With the Dehumidifier switch on, pressing the Timer Button should changed between 2hr and 4hr mode.
If this is what you're doing and it isn't lighting the LED nextto the 2hr and 4hr can you confirm what setting you have for the humidity?
Jun 25, 2011 | LG LHD45EL Dehumidifier
I have a digistat scr with a flashing red light and no heating there is nothing wrong with the batteries, this only occured after a poweer cut.
Try this first before condeming the unit.
1. Turn off the power supply to the Digistat SCR (receiver unit)
and leave for 5 seconds.
2. Turn on power to SCR unit and check red light is on.
3. Press override button No.2 and check the green light comes
on and boiler fires.
4. Press & hold down button No.1 (Keep depressed), then
press No.2 and keep depressed. {The Red LED light will flash
a couple of times and then it will go out}
5. Now release both the buttons – {the two LED lights should
come back on}
6. Get the Digistat+2RF/+3RF unit and stand two metres away
from the SCR unit with the Digistat+2RF/+3RF unit in your hand.
7. Remove the battery cover and fit the batteries.
8. The Red LED light on the SCR will now flash for approx. 7
seconds.
9. This confirms that the radio signal is being sent and
received.
10. The Digistat+2RF/+3RF and the SCR are now successfully
linked by a dedicated RF address.
Mar 21, 2009 | Water Heaters
How to turn off change oil light on 2001 Corvette
Unless there is something wrong with you buttons the procedure is as follows:
1. Turn ignition key to ON (not start)
2. Press ENG MET button on trip monitor & release, then press it again within 5 seconds.
3. Within 5 seconds again press and hold GAUGES button until Change Oil lamp flashes.
4. Continue Holding Gauges button until lamp stops flashing & goes out.
5. You should be done, start & shut off car. If it didn't work turn off car and start from top.
Some buttons are very sensitive so try and be deliberate & steady when holding.
If that helps please rate my answers!
Brett
Mar 19, 2009 | 1994 Chevrolet Corvette
Frigidaire F/L Washer - Delay Start will not reset?
I had this EXACT problem this morning and ended up calling the Sears Home Central Team out (I have an extended maintenance agreement). This is an error code that CAN BE RESET by the end user (you and me!) and doesn't need a repairmain. Here's what you do:
PRESS AND HOLD the START and CANCEL BUTTONS.
The four lights above the START button will begin to flash.
Continuing holding the START and CANCEL button and "spin" your wash selector knob to "SPIN".
Release the START and CANCEL buttons and Press the START button.
This will RESET the error codes within the system and allow you to "cancel out" of the DELAY START.
IF the error codes are "bad ones", then the system will stay locked and you'll need to call a repairman; however, this "fix" should work for MOST of the routine system error codes.
Worked on mine and we're a happy washing family once again!!
Nov 29, 2008 | Frigidaire GLTF2940ES Front Load Washer
The receiver will not stay on
have you got the button on the mouse bottom you must press when you have pressed the one on the receiver to have them connect with each other and every time you change the battries in mouse you must repeat this proceedure.
Nov 20, 2008 | Logitech Cordless Mouse
Sears craftsman 1/2 hp garage door troubleshooting
My garage door opener will start to close then stop and go back to the open position. If I put pressure on the door as it is closing sometimes it will close all the way and sometimes it will return to the open position. Can you help me. Thanks pbstation771@verizon.net
Aug 18, 2008 | Sears Craftsman LiftMaster Chamberlain...
Dishwashers Logo
104 people viewed this question
Top Dishwashers Experts
