Just received a new LG 42LD550 TV and after setting it up the right half of the screen is completely white. Tried different channels, tried DVD player, and Wii half of screen is still white. Unplugged TV held down power button for 30 seconds, plugged it back in and got the same result.
  • 443 Answers
Bad panel, take it back for an exchange, you don't want that one!
GOOD LUCK !
Posted on Aug 24, 2010
    Genius:
  • 1,112 Answers
Take it back this could be due to a faulty T-Con board or main system board failue.
White screen when playing dvd
try either a different player or a different tv to see which is causing this, if a player usually cheaper to buy another one.
Sep 01, 2012 | Televison & Video
Hook up and programming
have you try to check the the video cable connections from the dvd to the tv..?
Jun 19, 2008 | Sanyo DVW-5000 DVD Player/VCR
LG 42LK450 flat screen.I tried auto tuning but didn't pickup channel 31. I tried manual tuning with no result. The old style TV I had prior to this could pick up channel 31 so it isn't a reception...
If your trying to receive over the air make sure the TV is not set to a Cable mode, if your on Cable your new TV is most likely a ATSC tuner (digital) and the cable company can map channels any way they want. If your old TV had the older style cable tuner, the lineup will be different.
HDTV has level thresholds, if the signal is weak you wont see anything, but the old TV would.
Without knowing much about where or what sort of TV your using, these are my best ideas.
Oct 26, 2011 | LG 42 42LK450 42 LCD TV
LD4088 LCD will not play sound via HDMI cables. Component cables are fine. Hear a faint "click" from speaker when switching to HDMI input. Have tried all three HDMI connectors and have tried...
This is how AUDIO works in HDMI setup, you can select the source to send the digital audio along with the digital video through HDMI, the receiving end HDMI sound setup must be set to receive the digital audio through HDMI. Otherwise the audio may be sent and received through analog audio ports (Red (Right channel) and White (Left channel) RCA jacks) in stead. Most of the new TV and DVD player use auto detection.
So please check the HDMI audio setup to see how the audio signals are set to be processed.
Please leave rating if it helps.
Jan 14, 2011 | Apex Digital LD4088 LCD TV
LG 42LD550 LCD - Internet connection problem
After the network is connected to the TV, you have to go into the TV’s network menu to complete the setup process.
If you look in your owner’s manual starting on page #55-#57, you can read the direction to walk you through the wired network setup process.
It should be very easy to setup as long as your router has the DHCP turned on. That allows the TV to automatically assign it an IP address on your network.
If the DHCP is not turned on in your router, then the TV’s IP will have to manually entered by you.
May 20, 2010 | LG 42LD550 42 in. TV
I no longer receive my local channel 9.1 (RF 9). I've tried rescanning and resetting the TV, to no avail. I've unplugged the set for a half-hour, but that didn't work either. Is there any other way to...
I have one TV that would sometimes receive one channel and sometimes not, while two other TVs received this channel just fine. We thought for a while there was a problem with the coax goin to that TV and when it was bent in such a way the reception was better. Not sure of the reason, but each TV is different in the reception of the new digital signals. Maybe watch that channel on the other TV's, or try to move the ant. cable around some?
Nov 25, 2009 | Sanyo DP32746 32 in. LCD Television
Sony RDR-VX535 I tried hooking it up to just a TV, no cable box or anything else. I put the 3-pin cable from the Sony's Output to my TV input (only has yellow and white on TV, no red). However, when I...
Red is Audio Right
White is Audio Left
Yellow is Video
You don't say what TV you have so it's impossible for me to guess what the connection it is that you are using. You will not see a signal on any of the channels you will need to select AV or Mode or Input or something similar on the TV
Jul 26, 2009 | Sony RDR-VX535 Player
DVD Player connection to the tv... Theres three different colours on each side (red, white, and yellow) I already got it hooked up to the tv but the problem is that to hook the other end into the DVD...
Red is usually the left channel audio, white the right channel audio, and yellow the video. Look for something to the effect of "audio out" and "video out" on your DVD player.
Jul 07, 2009 | Norcent Technologies E-DVKIT003 10.2 in....
I've hooked up my LG 47" 1080p widescreen to a LG HE903PAW audio receiver / 5 disc dvd player with upscaling capabilities. I have tested the speaker system and everything's connected properly....
I was talking with LG on virtually the same problem. I have a samsung blu-ray player hooked up via HDMI. Even though the blu-ray is outputting 5.1, 6.1 or 7.1, the LG is only outputting 2 channel unless you switch to pro logic. LG states that this is a known problem and that you are to return the system to where you bought it for a replacement. Call the 1-800 number and they should give you the same answer.
Nov 23, 2008 | Audio Players & Recorders
42LC2DR
You need to press the button on the top right of the control ( the TV button) once and that will allow you to control the tv once again. Problem occurs when you accidently push VCR or DVD button which means remote control will try a different frequency to operate a VCR or DVD that isn't there. Hope this helps.
Aug 18, 2007 | LG 42LC2D 42 in. LCD HDTV
Televison & Video Logo
127 people viewed this question
Top Televison & Video Experts
Electro Med Services...
