Question about Whirlpool LTE6234D Top Load Stacked Washer/Dryer
Water level does not tur n off - Whirlpool LTE6234D Top Load Stacked Washer/Dryer
  • 443 Answers
Bad pressure switch(water level switch), or check the hose going to the water level switch to make sure it doesn't have a hole / leak in it, or just make sure it isn't disconnected from the switch fitting.
GOOD LUCK !
Posted on Aug 24, 2010
Im getting a strong fuel smell from my bilge followed by fuel in the water when the bilge turs on. the sailboat is a 1984 catalina
obviously you have fuel leak and a major fire hazard. find the leak before a fire happens.
Jul 10, 2017 | Cars & Trucks
Gulfstream pool heater is displaying ,,max heat temperature but pool water is cool.
I have the same issue. Went to tur non today and reads max water temp. Manual reads call for service for that display. Will open panel and check a few connections first.
Mar 31, 2017 | Pool & Spa
Back passenger power window stopped working
I can help with a little testing. On the hinge side of rear passenger door, should be a wiring harness. Probably has a protective rubber boot covering, pull the covering back far enough to get at wire colors in the diagram. One wire is voltage the other is ground depending if the window is going up or down. Use a test lite to check. Key on, I would think.Your front passenger window works ok? If the wires check out good for voltage and ground, could be something wrong with window motor?
Oct 22, 2017 | Cars & Trucks
My whirlpool washer drains to rinse but when it spins it spins very slow clothes stay soaked
Your machine is not comeing out of the nutrual drain the motor can't tur the tub full of water and wet clothes or it will sling water out and will burn out the motor very quickly so the transmission has a nutrual drain you will need a new transmission sorry
Mar 31, 2009 | Washing Machines
Nokia 9500 light
try taking off the battery and drying the device for a few days in a warm environment. i hope u didnt leave the battery on just after it hit the water, then it might be busted
Nov 25, 2007 | Nokia 9500 Communicator
Whirlpool LTE6234D Top Load Stacked Washer/Dryer Logo
Dan Webster
Dan Webster
Sal De
