Question about Toshiba Satellite M35-S320 Notebook
My sd slot does not recognize the memory card when i put it in? ddvoraksr@yahoo.com
The Machine
  • 788 Answers
SOURCE: SD card slot -
The slot is for multiple card formats, usually SD/CF/xD/MMC etc...
Look at it closely you should see different contact points inside, your sd card should slip into one of the slots inside the larger slot.
BUT!!! Some user guides are printed for entire families of notebooks and mention all the available options for that type of notebook. Your laptop might not have come with an SD card slot at all even if it is mentioned in the book.
Posted on Jan 18, 2008
computafixa
  • 317 Answers
SOURCE: SD card slot problem
Yes, these HC cards require a different reader, than traditional SD cards. The builtin one on the laptop probably doesn't support them, since any SD card above 2gb is technically considered an HC SD card. so my advice is to go to a cheap computer parts supplier, and see if they have a reader that will work for HC SD Cards.
DAMN THE MAKERS OF FLASH MEMORY FOR BEING SO COMPLEX!!!!
Posted on Feb 05, 2008
SOURCE: 2GB SD card no recognized
Thanks.
I have only one card reader. Will see if I can find a way to connect my GPS with the SD card in it to the PC.
Otherwise I guess I need to .. buy a new card.
What do you mean by formatting the SD card. I copy a file on it from Windows explorer (copy/paste) without doing anything to the card? If I buy a new card, should I format it first? How?
Since the system does not recognize the card I cannot do anything to it.
Thanks!
Posted on Mar 13, 2008
e-Guru
  • 3917 Answers
SOURCE: SD card reader not recognizing card
the original file (apparently version 2.0) is here:
http://64.233.161.104/search?q=cache:2288as3q0skJ:www.asus.it/support/download/selectftp.aspx%3Fl1_id%3D3%26l2_id%3D45%26l3_id%3D0%26m_id%3D1%26f_name%3DCardReader_050118.zip~zaqwedc+CardReader_050118.zip&hl=en
the updated driver (version 2.3) is located here:
http://support.asus.com/download/download.aspx?modelname=V6V&SLanguage=de-de
scroll down to where you see RICOH card reader driver
or more specifically this link here:
http://dlsvr03.asus.com/pub/ASUS/nb/V6V/CardReader_XP_2K_050808.zip
even though the site is primarily in german, all the component names are in english, go figure. So it would seem that the asus comp manufacturer are a little more forthcoming than dell in this particular instance. for example, nowhere on my component sheet does it say that RICOH is the manufacturer for the card reader, that's something i got from you guys on the forums
anyway, after installing this driver and rebooting my comp, card reader immediately recognized both MMC and SD media. unfortunately, it was only able to access the mmc card, and i'll be shipping my comp off to dell for whatever motherboard replacement they're willing to give me (which i don't mind, so long as it works when it comes back to me) but i thought these links might be helpful for others who are having the same problem.
Posted on Mar 19, 2009
ta_mcguire
  • 125 Answers
SOURCE: Sd card stuck in slot
you will have to remove the palm rest and then unplug the sd device look in the back of it and should be a small hole take a paperclip and push through the hole
Posted on Jul 27, 2009
Compaq 6910p Notebook does not recognize a SD-MMC memory card when inserted into the slot. The memory card is fine, as I can access it using a USB card reader, but it is not recogized in the Notebook's...
If the memory card is recognized and readable in a USB card reader, the memory card is fine. If the 6910 does not recognize the memory card, either the card is not properly seated in the 6910 card reader slot, the card slot is not connected to the main board of the 6910 or you need a DIFFERENT device driver for the 6910.
Nov 25, 2009 | Compaq Hewlett Packard 6910p Notebook
Kodak EasyShare SV811 won't read SD / HD card
Compatible Card-Slots : SD/MMC; xD; CF;Memory Stick; Microdrive; USB
You might have too much data on the SD card. Try with less pics onto the card.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Jun 25, 2009 | Kodak EasyShare SV811 (8858946) Digital...
My computer does not recognize my SD 2GB SD Flash Card which I insert into my camera and take pictures. I have a slot on my computer for SD cards. Can I just put the card in the slot and access the...
yes you can directly use the SD card slot, make sure you unlock the write protection before inserting it into the slot if you wish to modify or copy the contents from or to the card.
Jun 24, 2009 | SanDisk 2GB microSD Memory Card
Computer will not recognize memory card
Check two things and let me know how it goes.
1) Are you putting the SD card from your camera into a slot on your laptop, or pc? Or are you putting it into a card reader?
2) Are you sure the switch on your card is in the unlocked position? Let me know if any of these doesn't work.
Rob
Mar 07, 2009 | Sanyo Xacti VPC-T700 Digital Camera
I put a game cube game in to the wii and it says to insert a memory card into slot A so i put a 128mb memory card into slot A andi turn the wii on and it says no memory card found in slot A WHY?
It might be talking about the GameCube memory card slots, not the SD card slots. There should be a door on the top/left side of the WII. See if it's talking abou that.
Aug 18, 2008 | Nintendo Wii Console
Problem getting HP Photosmart to recognize digital camera memory card
From what read of the specs, the C6100 does not support SDHC cards, only SD cards. SD cards top out at 2GB; what you have is technically an SDHC (High Capacity) card, which does not work in SD devices.
Jul 22, 2008 | HP Photosmart C6100 All-In-One Printer
Memory card not recognized
Try to put your sd card to the slot, and check device manager.
check if there is yellow question mark on the device manager.
if it is, it's driver problem, just update the driver.
if not, try with another sd card and if this still not working, it's your sd card slot has problem.
Mar 22, 2008 | Acer Aspire 5500 5570-2609 Laptop
Storage memory card
high chance that your card is dead...take it to another card reader, like at a Wal-Mart kiosk to transfer pics for printing.
May 29, 2007 | Cingular Wireless 8125 Smartphone
Toshiba Satellite M35-S320 Notebook Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
