Question about GE Dryers
Not getting heat and smell gas and the dials do not move to shut off when its dry
  • GE Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Sep 12, 2010
Gas dryer dries sporadically. dial for automatic dry doesn't move
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ...Replaced outlet, cord, and moved the outlet so we don't have the same ... Whirlpool LER4634EQ0 110 v timer motor, when timer contacts TM .... David Villa 7 months ago ... 3 years and now thedryer won't heat and the timer doesn't advance, ...Missing: cu
Nov 17, 2015 | Whirlpool Dryer. Gas Dryer. 7.0 cu. ft. in...
Set dial in automatic dry option onmore dry. When start dryer comes on but dial never moves and there is barely any heat. Dryer only shuts off manually or when open dryer door.
if there is no heat, there is no drying and the dryer will not shut off until the clothes are dry. Sounds like you have an electrical problem, bad heater or thermostat. we do not have sufficient information to help you, you will need specific tool to determine the problem and for performing the repairs.
Jul 29, 2015 | Dryers
Dryer making clicking noise when running. Heat no longer working. Gets "stuck" in a cycle continues running and dial not moving.
Based on symptoms, this is a gas dryer. The clicking that you hear is the solenoid opening so that gas can flow and be lit. Except that gas isn't flowing, or the igniter is burned out (if or pilot is blown out if so equipped).
It is normal for the dial not to move unless it is in a timed dry mode (like air or freshen mode) because the moisture level of the clothes is not changing.
Jun 13, 2010 | Kenmore 63942 Dryer
Dryer works but there is no heat in cycles, just plain air drying, do not know how to get hot air, it is an 10 year old kenmore gas dryer, has a dial for time of cycle, can not turn dial to get warm or hot...
I think you will need a repairman to fix this. The gas valve coils may be bad if the igniter radiates but then shuts off before the gas ignites. A repairman can also look at the radiant heat sensor nearby the igniter and replace it if it is bad. He should inspect fuses and circuit breakers and the heating element for continuity, using a device called an OHM Meter. I don't think this is a do it yourself repair job.
Feb 03, 2010 | Kenmore Dryers
Amana Gas CLothes Dryer Mod#NDG7800AWW dryer will heat and does dry some but when it moves to the less dry the dial does not move and the dryer does not heat
if your clothes are damp because you say it does dry some what then it sounds like it could be the gas coils,the coils will work for awhile but then they fail and the timer will not move if there is no heat on the more or less
Oct 30, 2009 | Maytag Neptune MDE5500AY Electric Dryer
My dryer is not getting hot. It comes on and runs but it doesn't blow hot air. If I place my dail on "More Dry" the dial doesn't move from the spot i place it in
if your not getting heat the dial will never move its not getting dry, and your in a sensor circuit.
if you have no heat at all
electric......element
gas...........ignitor
this is where id start
Oct 23, 2009 | Dryers
Mytag Dryer ModelLdg4000Aw
I have a Maytag Atlantis Gas Dryer that will turn on, rotate, but will not get hot and dry the clothes. A load of clothes in the afternoon, didn’t dry, tried again but didn’t dry – went to bed after putting on auto dry - next morning the dryer was still rotating and didn’t turn off. No hot air – only cold air.
Jul 13, 2008 | Maytag Atlantis MDG7400AW Gas Dryer
Dryer smells of natural gas
Of course, this applies to gas dryers only. If you smell natural gas near your gas dryer, do not light matches or a lighter and don't operate electrical switches or anything that might spark, igniting an explosion. Immediately shut off the gas valve that serves the dryer. If the smell is mild, ventilate the area, wait until the air is clear, and re-light your pilot light. If the smell is strong, move everyone outside, leaving the doors open to ventilate the house. Turn off the gas supply valve --located by the gas meter on the gas inlet pipe-- by rotating the valve one quarter turn with an adjustable wrench. The valve's oblong stem should be perpendicular (at a right angle) to the inlet pipe to stop the flow of gas. Call your gas supplier (or the fire department) from a neighbor's phone or a cellular phone outside the house.
Jan 18, 2006 | AEG T57800 Electric Dryer
Dryers Logo
29 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
