Question about Philips Magnavox 27MS343S 27" TV
32 inch tv worked. after transport 8 hrs, there is no picture, just a flat horizontal line in center of screen. is this a bad picture tube? what else might it be?
    Genius:
  • 1,112 Answers
Hi:
There could of been a connection in the vertical circuit that has come loose during transport, another thing is i hope did not use a dolly underneath to load and unload this unit as they tend to crack the main board in and around the deflection circuit. A straight line means there is no vertical deflection for the CRT, if you look inside the vertical output wires going to the yoke on the neck are usually yellow and white check this connector to see if it just poped loose while transporting.
Posted on Aug 24, 2010
  • Philips Master
  • 508 Answers
Check everything in the vertical output stage including the IC for that section, look for burnt spots, broken PCB tracks, leaky diodes, bad capacitors, open resistors, dry solder joints (both on the parts of the board and the pins of the vertical IC and jungle IC).
It could either be the vertical output IC, the jungle IC, one of the drive transistors that has short-circuited. A series of voltage and waveform measurements will give you some clue as the true nature of the problem.
The best way to determine if it is a part that has failed, or a bad connection is to lightly tap the board while the set is on with the handle of a small screwdriver - if it affects the line - causing it to bounce or almost produce a picture, then it's a simple case of dry joints. If tapping does not make any difference, then check components as above. Replace them if required.
Posted on Feb 15, 2011
My 42 in phillips LCD flat seen has a black horizontal line toward the bottom how can I fix this.
Samsung LN46B650 Thin Black Horizontal Lines - Forums - CNET
www.cnet.com > Forums > Samsung
CNETI'm experiencing thin black lines from the top of the screen to the bottom. ... by babes808gpa / January 15, 2010 1:42 AM PST ... lines are about 1/4 inch apart from top to bottom of screen. starts on the right and about a 1/3 of the way toward the ...have the exact same problem, my lcd tv has multiple lines are horizontal it ...
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the ...
? 3:05
https://www.youtube.com/watch?v=KiqJuMiEiak
Jun 8, 2013 - Uploaded by Sameh Moustafa
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the picture SOLVED .... I just have one black line ...
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Dec 20, 2015 | Televison & Video
My tv made a little noise and then the picture disappeared. The screen is black with a vertical line of picture approx 1/4 inch wide going up the middle of the screen. Is it fixable?
Generally this is not good news. Even in the event this TV is repaired, it will work very long. This TV has a horizontal problem. This is the most stressed area of any conventional TV. The Horizontal Output Transistor will need replace, the flyback transformer is bad, you have bad power supply with horizontal capacitors that are bad, and last, is a possible bad picture tube. This TV is not worth the effort or money to repair. Thanks for asking and show all hands of support!
May 20, 2011 | Sharp 32SC26B 32" TV
I have a Panasonic 32" tube television that is only 6 years old (Model CT-32D31) that we bought from Sears. We suddenly have nothing but a horizontal white line across the screen, which "grows" into a...
Sounds like 'bad' or 'dry' capacitors in the vertical deflection circuit. Please note that leaving the white line on the screen too long can burn in the screen, which is permanent damage.
Jan 31, 2018 | Panasonic CT-32D31 32" TV
Horizontal line in My SHARP AQUOS LCD 32'' TV screen
Try to conect with DVD signal in A/V input if good picture, cable line are no good
Feb 16, 2009 | Sony 32 in. LCD TV
Toshiba TV CX2789K Horizontal Line
Failure in the vertical deflection amplifier section. This is usualy from failed components, and sometimes cold solder connections. Most of the time, I found bad capacitors, and sometimes the output IC or transistors (depending on the model type) that have failed.
Take the set to a service center for an estimate. You may find it more feasible to buy a new set depending on the parts that failed and the time involved to do the work.
Jerry G.
Apr 14, 2008 | Televison & Video
25 inch sanyo tv
If the horizontal lines going through the picture are fine white lines, then I would suspect the picture tube as having a heater to cathode short or some other problem. Since some sets have had a 3 year warranty on the picture tube, you may be lucky unless the labor to replace the tube is more than the set is worth. Sanyo is usually not a good name in consumer electronics anymore, so if you're looking for a replacement I would look elsewhere.
Mar 31, 2008 | JVC AV-32F704 32" TV
No picture on screen
if its wired to cable/satelite test scart leads unplugg /plug back in and if you have xbox unplug that while watching tv then plug in when u want to use it hope this helps it worked on mine
Sep 26, 2007 | JVC AV-32S575 32" TV
Tv not working
this symptom, sometimes called the tube light effect, it is characterised by a bright thin horizontal line across the middle of the screen. this symptom is caused by a breakdown in the vertical deflection circuit. hence maybe the trouble maybe in the vertical oscillator, amplifier or output circuits. but if all i have said is not clear to you, better bring it to a qualified tv technician. good luck!
Mar 08, 2007 | Sanyo DS31590 31" TV
Philips Magnavox 27MS343S 27" TV Logo
146 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
