Question about Amcor PCMB-16000EH Portable Air Conditioner
My potable a/c unit is leaking water - Amcor PCMB-16000EH Portable Air Conditioner
  • 139 Answers
The drain line is clogged their should be a visible hose connected to the unit to drain blow it out or use a shop vac
Posted on Aug 24, 2010
My Pump is new and is so noisey we can hardly hear ourselves talk
take it back and get an exchange unit under warranty
it is possible that it is sucking air and not water so make sure that the new pump is properly primed first
Feb 22, 2016 | Flojet R3526144A Potable Water Supply...
Where is the potable water tank drain located?
sorry no idea without seeing the unit in person .
Oct 29, 2015 | RVs
My 2004 Kenmore leaks water at the water filter housing. I put a new filter in but when I wish to get water it overflows at thde top.
Fist issue, plumbers putty should not be used on any water connection for potable (drinking) water, use Teflon tale if you need to. If the leak is at the housing most likely the housing is bad, replace it.
Feb 05, 2015 | Kenmore Refrigerators
Need to know steps to winterize a 2001 Thor-Citation 23-R trailer. Or schematics of key points to address.
If you don't have a hot water heater winterizing bypass kit installed,get one before going any further.
Next, drain the water out of the hot water tank. Add POTABLE (not automotive) anti freeze to the water system Run run faucets one at a time both hot and cold, toilet and shower head until you see the anti freeze . Next, shut off the water pump and open the faucets. This saves any chance of cracked water lines. When you want to use the trailer again, close the bypass valves on the hot eater tank and run the pump long enough to remove the antifreeze solution from the system. Fill the water tank and run the faucets for a few minutes. Potable antifreeze won't make you sick so there's no worry if you don't get it all out of the system.
Nov 02, 2014 | RVs
Trying to fill fresh water tank. Overflows in a minute
there is probably a stoppage in the relief opening. should be next to the potable water fill. are you trying to fill from the pressure inlet or potable fill inlet? if from the pressure inlet, there is a bypass valve by the fresh water tank to divert watr into it.
Jun 19, 2014 | Thor Motor Coach RVs
What is theproblems in using cast iron valves for water pipeline
For drain pipes (waste water) they're fine.
But for potable water (fresh water), the cast iron could rust, allowing the rust to get into the water.
Also, the iron could leech into the water.
Apr 28, 2014 | Plumbing
Water leaking out of the top of the hot water furnace
1) Copy following linkL
http://waterheatertimer.org/Leaking-water-heater.html
2) Add comment and include brand and type of water heater for possible additional help
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Feb 18, 2013 | Watts Premier Watts 0067421 ET-60...
Heating element/brewer tube leaks, Where can I get a new one?
Take the old one to any hardware store and match it up with a hose that is approved for potable water.
Aug 16, 2009 | Cuisinart DCC-1200 Coffee Maker
When I fill the patable water tank it leaks on the inside of the trailer
If it leaks while filling it is likely any of the several fittings or it may be the 3 port check valve attached to the incomming water line. These are routinely installed backward. The idea is that when hooked to an external water supply the water goes only to the faucet and when using the tank, water can only go from the tank to the faucet. You cannot be hooked to external water and use the tank.
Any cracks in the tank should be obvious.
Use teflon plumbers tape on all screw fittings or will leak for sure. Hose clamps are also a necessity.
May 30, 2009 | Coleman Campers Grill
Amcor PCMB-16000EH Portable Air Conditioner Logo
85 people viewed this question
Top Amcor Heating & Cooling Experts
AJMAL KHAN
Michael Youngman
Michael Youngman
Are you an Amcor Heating and Cooling Expert? Answer questions, earn points and help others
