Magnavox model 19MD357B/37 TURNS ON AND THEN OFF IN SECONDS.
4 Suggested Answers
  • 56 Answers
SOURCE: i have a magnavox 42mf231d / 37 it turns on
Hi tt3nry,
Unfortunately the answer isn't a simple one on that set. Just about every board in that set can have a problem that causes it to shut down. The cheaper way out this will be a trip to the shop as opposed to you buying all the boards from a distributor and doing it yourself. A small, local shop will charge you a FAIR price and do it right for you. Plus, most distributors DO NOT WARRANT parts if you are not a professional technician.
Ask friends where they have had work done or call the local chamber of commerce. They can point you in the right direction as well. Avoid the great big places. More than a few techs means more overhead and higher prices.
Good luck.
Posted on Apr 21, 2010
Testimonial: "sounds good, will work on it. thanks!"
SuperTech-11
  • 1591 Answers
SOURCE: My Magnavox Model 42MF521D/37 have
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom need to be replaced.
If you repeatedly turn it on, eventually it'll probably stay on, but every time you turn it off, the TV will get harder and harder to start up until one day it just won't.
Sometimes you have to do the opposite to start it up and unplug it for 5 mins, then try.
If you aren't tech savvy, this unit needs to go in for repair.
If you are handy with a soldering iron and can identify the power supply and inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for different brand, but same issue) on youtube.
http://www.youtube.com/watch?v=Mm51C_RDIZE
http://www.youtube.com/watch?v=BNHHrgX_6cs&feature=related
http://www.youtube.com/watch?v=8l0AUj8QUkg&NR=1&feature=fvwp
http://www.youtube.com/watch?v=Y7b_nTaZYcU&feature=related
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors.
The parts are cheap, and skill required is minimal.
Posted on Mar 08, 2011
  • 586 Answers
SOURCE: "I have a rarely used Magnavox 15MF400T/37 Series
first, make sure the Tv is correctly plugged into the wall. You can try another outlet. If that doesn't work, then your Tv is certainly having a power problem.
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board. You might be lucky it's just a blow fuse. Also a defective transformer can cause your TV not to power on.
All these can be checked on the power supply board.......
But more often bad capacitors causes problem on the power supply board. I do not think the power board needs replacement, rather those defective capacitors is causing this issue. Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes).
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors). After replacing these capacitor(capacitors) most likely the normal operation will be restored. Or you can by a refurbished complete power board to save you some stress.......
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
Yours sincerely.
Elect_Comp.
Posted on May 15, 2011
Magnavox turns on then goes off model 37f337b/37f437b
More than likely power board,usually repairable,look for blown capacitors.A blown capacitor will look like the top is rounded also suspect capacitors will show signs of the plastic coating shrinking .
Jan 13, 2013 | Toymax Magnavox 37MF337B 37 in. LCD TV
Removing back
Best way is lay face down on a padded surface and remove screws until entire back cover can be removed.
Jun 16, 2012 | Televison & Video
Remove back cover on magnavox 19md357b/37
Send your email address to me, and get back a copy of service manual to your set, by return mail. It will have all details.
Jun 11, 2012 | Televison & Video
My magnavox model 50MF23ID/37 is 4yr old. tv wont
If you hear a clicking noise that sounds like the ballast trying to power on the lamp, but nothing happens, the lamp may be faulty.
http://www.discount-merchant.com/
Here you can get your lamp that most likely needs replacing.
Mar 26, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Magnavox 42 LCD 42mf438b/f7 turns on/off by itself sometimes screen goes blank tv unresponsive to remote
I have exactly the same problem with a Magnavox LCD 42", very similar model 42MF437B/37. I don't have a solution. If you unplug the TV and plug it back it starts working, sometimes for hours, sometimes for less than 5 minutes, before it turns off again. Does anyone have any real solution?
Jul 08, 2009 | SNK Magnavox 42MF438B/27 42 in. LCD TV
42 inch magnavox #42mf230a/37
One of the driver IC'S has gone bad. Need to replace just the driver IC or the board that the IC is on and that should solve your problem. If that doesn't do it, then the BAD NEWS IS THAT THE PANEL IS BAD. Replacement is you only option then. Good luck. GURU JAY.
Mar 16, 2008 | Televison & Video
Televison & Video Logo
258 people viewed this question
Top Televison & Video Experts
