Question about Epson DFX-9000 Matrix Printer
Epson DFX 9000 Error 03, Printernya ke pause terus
ohms
  • 1879 Answers
SOURCE: epson dfx-9000
the SP motor brake signal didn't switch on within 3 seconds after turning printer on.
check for disconnected SP motor-related connectors. the printer needs servicing.
Posted on Jan 22, 2008
  • 3 Answers
SOURCE: error oC on epson dfx 9000
I have encounted this problem on several occation.
Check to ensure that all the four fan on the printer are working fine.
Take note of MOTOR 2. The motor below main motor.
That should solve the problem.
Regards
Posted on Feb 25, 2008
Inky
  • 691 Answers
SOURCE: error 07 ,turn off Printer on dfx 9000
The motor (+42 V) or head drive (+37 V) voltage fell below the
allowable level.
This error indicates a power output problem, or a voltage detection circuit failure.
Check and replace the following in the order below, checking
functionality at each step:
Power Unit
ROM Board
Posted on Jul 23, 2008
ohms
  • 1879 Answers
SOURCE: PROBLEMA IMPORESORA EPSON DFX-9000 ERROR 3
Aprendizaje hablar español
ERROR 3 - Carriage Return Horizontal Position Error
The SP motor brake signal did not switch ON within 3 secs after turning the printer ON.
La señal del freno del motor del SP no encendió en el plazo de 3 secs después de girar la impresora.
Check SP motor connection or call for service.
Compruebe la conexión o la llamada del motor del SP para saber si hay servicio.
Posted on Sep 11, 2008
ohms
  • 1879 Answers
SOURCE: Epson dfx-9000 printer is showing error 0D when it is switched on
check print head built in thermistor and the carrier cable.
Posted on Nov 20, 2008
What does error 03 indicate?
Fatal Error Code 03: CR Horizontal Position Error
The SP motor brake signal did not switch on within 3 seconds after
turning the printer on.
Check, and if necessary replace, the following in the order below.
1. Check for disconnected SP motor-related connectors (ROM
BOARD: CNSPHS, CNSPM), See 4.2.3.3 SENSOR BOARD
UNIT (p.139).
2. Check the Interlock switch, and if necessary replace the
INLK SW ASY (p.146).
3. Check both the SP motor and driver. (Always check both.) Check for a broken fuse on the SP motor 42 V line. Replace the
SP MOTOR ASY (p.156), and/or ROM BOARD (p.137) as necessary.
Epson DFX 9000 Service Manual Troubleshooting Based On Error Codes
Mar 28, 2016 | Epson DFX-9000 Matrix Printer
Error : paper jam Epson DFX-9000
I find problem printer epson dfx-9000 with mesage
error : 0E
turn off printer
help solution this problem ????
Sep 14, 2010 | Epson DFX-9000 Dot Matrix Printer
Error 01 0n epson dfx 9000
i have a problem on my printer epson dfx 9000 with erro code 01 turn off your priner any one with solution?
Aug 29, 2009 | Epson DFX-9000 Matrix Printer
Error13 for epson printer dfx 9000
ALLO CHO MINH HOI MAY IN KIM EPSON DFX 9000 BAO LOI ERROR 03 LA BI PAN GI VAY ?
Mar 18, 2009 | Epson DFX-9000 Matrix Printer
DFX 9000 Printer on display Error 03 plz help out.
DFX 9000 Máy in L?»?i hi?»?n th?»? trên 03
Jan 11, 2009 | Epson DFX-9000 Matrix Printer
Printer repair
carriage load measurement error-chances are you will have to sendit to a servicer to have it fix
Mar 26, 2008 | Epson DFX-9000 Matrix Printer
Epson dfx-9000
Jan 15, 2008 | Epson DFX-9000 Matrix Printer
DFX 9000 error oC
09 : FAN1 driver error
0A : FAN2 driver error
0B : FAN3 driver error
0C : FAN4 driver error
Jan 11, 2008 | Epson DFX-9000 Matrix Printer
Epson DFX-9000 Matrix Printer Logo
77 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
