Question about RCA HD52W59 HDTV Projection Television
TV wont turn on.
I plug my HD52W59 hdtv into the wall, but when i go to press the on button the button blinks once then shuts off and the tv wont turn on. What does this mean and what should i do?
    Genius:
  • 1,030 Answers
I am sorry to hear about your problem with your rca... I work on these sets daily. (so that should tell you how dependable..First thing you can tell is that is not the main fuse.. THe main processor is recieving power and then something in the startup procedure upset the processor.. so it shut it down. unfortantly thats where the troubeshooting begins....technicians have specail computer equipment that alows them to read errors codes much like that of a car... most of the time it will be a high voltage issue. hoizontal transistor. flyback..if you have to replace a board you may even need special euipmwent to do that...Does the set make any noises chirps or squeals..did it smell ...what what is doing when it whent out
Posted on May 05, 2008
I have a Mitsubishi WD-62525 HDTV that suddenly wont turn on. Just has a green blinking light when you hit the power button. Any ideas?
I found this on another website, most likely it is your power supply capacitors.
  1. Press the "reset" button and hold for 10 seconds .... Does TV turn on and blinking green light turn to solid green.
  2. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours..... Does blinking green light continue upon plugging in the TV.
  3. Disconnect ALL devices from the TV; DVD, Tuner, Cable Box, unplug the TV for various duration times .... Does blinking green light continues upon plugging in the TV.
  4. Press Power and Menu buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  5. Press Power and Display buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  6. Insure that no front panel buttons are inadvertently stuck in an "engaged" position.
Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
  1. DM Module Capacitors have FAILED.
  2. DM Module is defective.
  3. EEPROM Board failure
  4. Power Supply failure.
Feb 28, 2011 | Mitsubishi WD-62525 62" Rear Projection...
Sony kp-65wv600 projection tv error code. My tv blinks 7 times.
The Standby LED blinks when the TV is turned on, then shuts off when the picture is displayed. If the LED blinks continuously, this may indicate that the TV requires service. Before getting the TV serviced, try power resetting the TV and factory resetting. Try the below steps also: Connect the TV to a different wall outlet and check if it helps. This is to check if the issue is with the Power. Disconnect the TV from the Power Strip or the Surge Protector and connect it directly to the Wall outlet and check if it helps. To Power Reset the TV, disconnect the Power cord for a short period of time (approximately 1 minute). Then, reconnect the Power cord and power ON the TV. To factory reset the TV, turn it ON. Then while holding down the RESET button on the Remote Control, press the Power button on the TV front panel. The TV will turn OFF and then turn ON again. Then release the RESET button to complete the reset procedure. If the issue persists, service may be required.
Good Luck!!
Nov 09, 2010 | Sony KP-65WV600 65" Rear Projection...
Turn tv on no power
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Jul 27, 2010 | RCA HD52W59 HDTV Projection Television
MY TV WONT CUT ON
Coming out with a silly thing here, have put pressed the TV button on the Hand Controller for it
Jan 27, 2009 | RCA HD52W59 HDTV Projection Television
Power button blinks, tv won't turn on
replace the flyback, that should straighten it out. You need flyback 259296 you can get one at the following link with free step by step instruction on how to replace it, from beginning to end.
http://servicemanuals.vstore.ca/
Sep 05, 2008 | RCA HD52W59 HDTV Projection Television
Rca hd52w59
does the power indicator light up? Does it blink 3 times then go off/ let me know and I may be able to help you that model is famous for bad flybacks
Apr 27, 2008 | RCA HD52W59 HDTV Projection Television
Comcast Remote Control Code
comcast sucks and its tech support are a bunch of idiots. the book that comes with the remote is wrong (and for some reason no one in tech support knows this). the remote requires 5 digit codes and all the codes in the book are 4. typing the number 1 in front of any of the codes in the book, for any device and manufacturer, should fix this problem.
Jan 28, 2008 | RCA HD52W59 HDTV Projection Television
50 inch 1999 TheatreView Television
#1 When I turn on the TV the power button comes on then blinks 6 times then goes off for a few seconds then repeats the cycle. I have sound over my surround system during this time but no picture.
#2 My sound would crackle and pop every once and a while until now it does nothing. I have to watch it with the surround sound on.
Nov 26, 2007 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 HDTV Projection Television Logo
156 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
