Question about Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed
Engine runs well but put in gear at any of 6 speeds and it does not go. Notice that there is slack in belt and wonder if this is related to my problem.
  • 760 Answers
Without the model number it is hard to be sure, but yes if the drive belt is slack, then that's a problem. If you have your manual it should indicate how to tension the drive belt (adjust clutch) You can look and be sure the belt is on all pullys.
Posted on Aug 24, 2010
How do i adjust tension on drive belts
Hi there, If you lower the deck to its lowest level and follow the track of the deck belt you'll see the tensioner pulley. Check its spring is still engaged and strong enough, some mowers let you hook the spring into different holes for more/less tension. Check the pivot bush isn't too slogged out for it to tension properly.
May 24, 2014 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Does my 2003 dodge caravan have an interference engine
Not sure but if doing belt yourself I will give you important tips. 1) before removeing T/Belt set engine to TDC nr 1 there should be marks on the crank and cam (s) gears that line up with a mark on the block / head. 2) prior to removeing tension to belt get liquid paper & mark cam gear(s) & crank gear to point on block / head. 3) mark T/Belt to cam(s), crank, balance shaft if fitted. 4) release tension & remove belt. 5) transcribe marks from old belt to new belt & make sure correct amount of teeth. 6) fit new belt so YOUR marks line up. 7) have tensioner suply presure to belt. 8) turn motor twice by hand to make sure pistons no hit valves 9) Make sure YOUR marks line up if YOUR marks line up it has to be right. 10) Very IMPORTANT if spring tensioner lossen locking bolt again to take up extra slack in belt. 11) tighten locking bolt. 12) put back together.
Jul 11, 2012 | 2000 Dodge Caravan
Craftsman 42 inch15 hp kohler mower 6 speed manual transmission- Will not go into gear
This is a crash type gearbox, so if there is any drag on the belt to the gearbox pulley it will not go into gear, with the engine not running will it go into gear? if yes it is a belt dragging issue, check the keepers around the engine pulley and gearbox pulley.
Jun 09, 2012 | Craftsman Garden
Show me where are the timing marks on 2.0 toyota camry engine
the cam gear has a round hole that you will have to use a light and a mirror to look through the hole and see the t mark . put cam gear at 12 oclock and look through the hole and you will see a straight line on cam cap just below valve cover and you might have to clean the cam cap off to see it. on the outside of the crank gear there is a mark between the teeth just to the right of the key way slot. on the oil pump there is a dot at about 1-3 oclock and you might have to clean off the oil pump to see it. put crank gear on and line up the marks then on the cam gear look in the hole and put the line on cam cap in the middle of the hole.put belt on and get all the slack out that you can putting the slack towards the tensioner trying not to move the gears and check your marks and if all good release the tensioner and then tighten. put the crank bolt in and turn the engine over 360 degrees and recheck marks and if all good check to see if there is any slack in belt towards the front of car.if there is take a 14mm wrench and put on cam bolt and lightly tap on it towards the firewall to get the slack out and release tensioner and retighten double check t marks and you should be on the road again.
Jun 17, 2011 | Toyota Camry Cars & Trucks
Squeak in low gear.
Try spraying the belt with a "dressing" spray. With the engine not running of course. If it stops, then your belts may need adjustment or replacement.
Feb 06, 2010 | 2007 Mazda MAZDA6
1986 S-10 stalls when making left turns only.
seems like you got the problem solved. could be a power steering problem. maybe the engine belt is too slack. tighten the belts. check all the belts. if power steering belt is slack and you turn the wheel should get hard and the vehicle shuts off.
Jul 07, 2009 | 1996 Chevrolet Blazer
How do you change the belt 1997 ford escort timing belt
not fun. Have to take off all the belt driven stuff, Alternator ps pump etc. undo the bolts holding the cover in place, remove the cover and the belt will be under that. Put something in place to release the tensioner and remove the belt carefully so you dont move the cam or crank. slide on the new belt release the tensioners and put the cover and belt driven stuff back. I would recommend a new water pump while you are in there. they arent that expensive and might as well do it now than do the whole works again if it fails. new tensioners now a bad idea either.
Mar 31, 2009 | 1997 Ford Escort
John Deere L118 Riding Lawn mower speed problem
I have lost the key to my John Deere Model L118 lawn mower. Where can I buy a replacement?
Mar 16, 2009 | Garden
Replaced 305 engine with 350, runs poorly at steady speeds
try replaceing/testing knock sensor, unless you already did
Dec 01, 2008 | 1996 GMC Sierra
Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed Logo
181 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
