Question about Acer Aspire 4520 Notebook PC
How to force external monitor on lap top monitor broken boots on external monitor than switches right to broken monitor tryed f f3 f5 does not work
  • 2,973 Answers
To be able to use the external monitor, first boot in safe mode. Then in the Display settings when you see two monitors select the external monitor. set its resolution to a shade lower than the displayed. (you can adjust it later.) Now reboot in normal mode and press the Fn key alongwith the key to transfer the display from LCD to monitor (this happens to be different for all makes of laptops). It has an LCD and a monitor made on it.
Posted on Aug 24, 2010
  • yudanjiao522 Aug 25, 2010
    What I think the most significant influence in cultural difference is the power distance. (Hoecklin,1995:28)"It would condition the extent to which employees accept that their boss has more power than they haguccive and the extent to which they accept that their boss's opinions and decisions are right because he or she is the boss." I considered it as how much subordinates can consent or dissent with bosses or managers. It is the distance between a manager and subordinate.
    prada
    hermes louis vuitton replica handbags pradahttp://www.eluxurywow.net/
  • Acer Master
  • 3,866 Answers
The issue is the OS boots but is not SET for the external monitor
You can try and use the FN and the monitor key but as a perm thing you cannot do this, just cannot be done its boots on the port for the primary display and that is the way it was built. Now if the F# or F% does not work then the operating system is not set up for the external monitor with the display broken i do not see a solution for this one as a tech,
thanks for the question tho but i want to remain honest and say its not possiable.
please do rate my answer before you leave thanks.
MY N5030 LAP LCD IS IN LAW LIGHT.CAN AS A SHADOW. I CONECTED TO EXTERNAL MONITOR IT WORKING BUT LAP DISPLY STILL AS
look khal sometimes most netbooks have a "hotkey" sequence to dim or brighten the screen on mine its Fn/F4 or Fn/F3 try this first or goto you manufacturers site and find the exact sequence of "Hotkeys" [remember Fn/F5 toggles between screen and monitor]!!
Good luck
Davey snake!
Jul 20, 2011 | Computers & Internet
My screen on my laptop is broken. Can i plug a monitor into my laptop?
1) connect your external monitor to the laptop and then switch the monitor on
2) boot up the laptop
3) after it has successfully booted, you need to identify which function key toggles the external monitor on/off
4) you should be able to do this by holding down the Fn key and trying each of the F keys in turn, waiting a few seconds after pressing each one
5) begin by holding down "Fn" + "F3", "Fn" + "F4", "Fn" + "F5" etc.
If this doesn't work, it may be worth examining all the keys and look for a small monitor symbol on one of the keys. If you find this symbol, hold down the Fn key and then hit the corresponding key with the monitor symbol.
Oct 19, 2010 | Computers & Internet
Is it possible to bypass the built in screen monitor(compac 7770 DMT) and connect to another computer monitor. I bought my laptop at the local goodwill store and the monitor just looks like wet splatter....
1) connect your external monitor to the 7770DMT and switch it on
Oct 18, 2010 | Compaq Armada 7770DMT Notebook
I don't have video on my 400sd4 laptop
If the system is booting up completely and you can hear is starting up then the problem is limited to your video.
First try this
Boot up your system so that it's in windows (listen for start sounds and windows music etc)
once you believe the system is fully booted press and hold the FN key. While holding FN press and release the F3 key one time and then let go of FN. Wait a few second and see if the LCD screen comes on. If it does not try FN-F3 a couple more time, waiting a few second in between.
If that does not work then try plugging in and external monitor to verify that the system is working otherwise. If the external monitor does not come on right away then press Fn-F3 again with it attached to allow the system to send a signal to the external port.
If it works on the external monitor but cannot come on the LCD screen, the that indicates a problen inside your laptop or LCD screen.
Dec 03, 2009 | Gateway 400SD4 Notebook
I cannot get my lap top to show on the all with my projector
Laptop will often have a function key (usually F5) for cycling between built-in display, external monitor, and both. Try pressing F5. If that doesn't work and you have a "Fn" key (usually near the left Shift key) hold down Fn and press F5.
Oct 11, 2009 | Compaq Presario Notebook
Swithcing from laptop screen to lcd monitor
Hi
Connect the monitor, flat panel, or projector to the laptop's 15-pin video connection on the back of the computer as shown to the right. Once connected, your laptop may automatically switch to the new external display or you may be required to press a sequence of keys in order to switch from the laptop to the external display. video.gif For example, often either Fn + F3, Fn + F5, Fn + F8, or Fn + F9 is pressed to switch between alternate displays. So if your laptop was Fn + F3, pressing and holding both Fn and F3 at the same time would switch between displays. Often, the alternate key pressed in conjunction with the Fn key will be labeled as CRT/LCD and/or have a picture of a monitor on the key or close to the key. Unfortunately, the keys pressed to switch displays is dependent on the model and manufacturer of the laptop. If none of the above key sequences work, consult your laptop documentation or consult your laptop manufacturer.
Some laptops also have the ability to have the display on both the laptop and external display and/or one or the other at a single time. Laptops with this ability can switch between these modes by continuing to press the same function keys until in the mode the user wants.
Feb 01, 2009 | HP Pavilion dv6000z Notebook
Cenection to an external Toshiba TLP-X20 projector
if reboot vista is not work for you. then you must trying display setting in your vista. usually each operating system have their own display setting application. for example i using windows xp with intel graphics on board. the graphics have the software called as intel graphics media accelerator driver. in my pc i can found a little blue box icon in the right bottom. i just right click then choose the output to monitor + notebook. what type of your vga?, you can find that information in device manager.
Feb 16, 2008 | Microsoft Windows Vista Ultimate Edition
Acer aspire 3680
Display Toggle - <Fn> + <F5> will toggle from external monitor
Screen Blank - <Fn> + <F6> will turn the LCD off
hope that helps.
Jan 27, 2008 | Acer Aspire 3680 Laptop
External monitor for amilo pro v2030
hi
when the external monitor is connected hold down the function key " f n " ( which is located 2nd on left of lowest row ) and then press either the F4 or F5 function keys on top line....the one that has a small icon like a rectangle or tv screen on it ....it has usually 3 toggle positions so if it dosent work first time then just press the same key again (still holding fn key) until it allows the monitor to get the signal.....if F4 dosent work then go thru the same sequence with F5 but depending on the laptop model it could be any one ...F3/F4/F5/F6 the usual suspects....
hope this helps
Jan 04, 2008 | Fujitsu Siemens AMILO Pro V2000 Notebook
Open Questions:
Acer Aspire 4520 Notebook PC Logo
687 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
