Question about Canon Cameras
The isux 60 displays a message "card locked". how is it unlocked
  • 6,831 Answers
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Posted on Aug 24, 2010
Insert sim card
Do you want to insert other network sim or if your Blackberry Curve 8350I displaying insert sim card,if already sim card inserted.Don't worry i will help you.You can insert other network sim card in the phone by unlocking the phone from current network lock.To unlock Blackberry Curve 8350I use unlock code.Visit the site Wickedunlock.com get unlock code and unlock it easily.Then insert any GSM network sim card.If the phone displays insert sim card even though sim card is already in the phone.Please remove the sim card and replace it correctly.It is because the phone didn't detect the sim correctly.After inserting if it is display invalid sim or sim not valid message on the screen.It is locked to some network,you need to unlock it.To unlock use unlock code.Get code from online site and unlock it.
Jul 30, 2013 | Blackberry Curve 8350i
My go phone sim and a 3G sim and my phone is sayin dat the sim cards r invalid
Since you say it is a GO phone, you need to call ATT and they may help you with that.
Jul 24, 2013 | Cell Phones
Unlock my phone
If the Nokia X6 16GB phone,displays invalid sim card message on the screen it is locked to some network.Please find out the network and country it is locked now.If it is locked to network,it will not accept other network sim card.But you saying it is accepting other networks sim card.How many network sim card have tried inserting in it?If you tried only one network sim card and it accepted that it is locked to that network.You can also try using some other network sim card.If it displays invalid sim message again.It is under network lock.To unlock it use unlock code.Visit the site Wickedunlock.com get code and unlock it easily.
Jun 11, 2013 | Nokia X6 16GB Cell Phone
Moultrie game camera
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jun 09, 2013 | Cameras
SD/SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
My mobil is lock model5000d-2
Is it Your Phone Locked To Network Or Security Lock,It locked to Network means You cannot use with Other Network Sim card,You can find that By inserting Other Network Sim card.....It accepts means It's Unlocked from Network LOCK and You can use with any GSM Network,So it's Need some other LOCK unlock,If it not accept Other NETWORK Sim card in the Phone While insterting Other Network Sim card means ..It's Under Network Lock,You have to Unlock it Get the Unlock code and instructions from here
Mobileunlocksolutions.com and Unlock it from Network Lock ,then use with any GSM Network Sim card.....You can Try 0000 or 1234 as default code to Unlock from Security or Password lock,It not works means call the service provider get the master reset code and reset from Security Lock.You can follow the instructions Below To UNLOCK from Network Lock,You need to specify the Network and Country It locked now,to get the code...
Warning : Do not enter any wrong unlock codes on your Nokia 5000d-2 mobile phones. If you enter over a certain amount of wrong unlock codes on your Nokia 5000d-2 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch on your Nokia 5000d-2 without any sim card.
2 - Don't bother as to what is displayed on your Nokia 5000d-2.
3 - Compose #pw+CODE+1#.
4 - The Nokia 5000d-2 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 5000d-2 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia 5000d-2
Each Nokia 5000d-2 mobile phone has an unique unlock code. You can buy the unique unlock code for your Nokia 5000d-2 mobile phone using the form above.
Aug 24, 2011 | Nokia 5000 Cellular Phone
How to unlock my nokia E 71 code
To get the Unlock code at here Prounlocking.com and Unlock it from Network Lock,then you can use it any GSM Network Sim card.
Nokia E71 Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your Nokia E71 mobile phones. If you enter over a certain amount of wrong unlock codes on your Nokia E71 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch on your Nokia E71 without any sim card.
2 - Don't bother as to what is displayed on your Nokia E71.
4 - The Nokia E71 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia E71 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
Aug 01, 2011 | Nokia E71 Smartphone
Open the contary lock of nokia n97
Use this site to open the country lock...
Follow the following instruction to unlock your country lock..Get the instruction here mobileunlockguide.com
1 - Switch on your Nokia N97 without any sim card.
2 - Don't bother as to what is displayed on your Nokia N97.
4 - The Nokia N97 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia N97 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
After that get the unlock code here mobileunlocksolutions.com to your mobile Nokia N97...
Jun 13, 2011 | Computers & Internet
I have a stylus 600 model, if i place the memory card in the cam a message will display in the screen..."write something"....what does it mean?
Here is a tip that I wrote about SD Cards and how to unlock and lock SD Cards.
If you are getting a memory card locked message then check this out.
How to Unlock SD Card
heatman101
May 12, 2011 | Olympus Cameras
Keep getting card locked on my display screen
Hi there.
Face the card towards you, look for a small white tab on the left hand side of the card, to unlock it push the tab down, it will be at the side of the card like this 59a6de4.jpg .
Please post back if you need any additional advice.
Good luck and thanks for choosing FixYa!!
May 29, 2009 | Pentax Optio 60 Digital Camera
Cameras Logo
22 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
