Question about Chapin 1 Gallon Bleach SureSpray Sprayer
I need the manual for model # 1125D 2.5 gallon sprayer. I can not find it anywhere in the house or garage and I need to use it in the morning
  • 490 Answers
Howdy. I was at the Chapin sprayer website and they don't list a model #1125d or similar. If you have any additional information, I'm sure we can get you a manual tonight.
Posted on Aug 24, 2010
I got a roundup sprayer at a garage sale. I don't know how to fill it. It has a model # 020p10 Any assistance you can provide will be greatly appreciated as there is no manual. Larry
The handle pushes down and locks to be carry or to unscrew it. Push handle down, then twist left to unscrew. It may take a bunch of force to start. Better to hold the sprayer down and relieve all pressure before doing the unscrew.
Apr 10, 2011 | Roundup 2 Gallon Pro Garden Poly Tank Pump...
How do i get the spray to come out in a fan shape. The model number I have is 1125D.
You need to consider what materials you will be spraying. Wet table powders and sprays with relatively high solids contents will work better with a diaphragm pump than a roller pump. For tanks, plastic should be fine unless you are spraying materials which will react with the plastic. If you are concerned about it getting banged around, consider welding a roll cage or some bumpers around the tank. With 2 acres to spray, the sprayer will not be getting heavy use, so you won't need super heavy duty equipment.
Check out this video:
http://www.youtube.com/watch?v=5_yE8o6vnMg
Please get back to us if you have any further query or else accept the solution.
Oct 31, 2010 | Rl Flowmaster Rl Flo Master Proplus No...
I have lost my owners manual for my model 2602. Can I get that?
FUNNEL TOP SPRAYER MODELS 2601, 2602, 2602I, 2603, 1602: Operating Instructions ( http://rlflomaster.com/service/pdf/971-230.pdf )
Or, tired of browsing the web? Call us: 1-800-253-4642
Hope helps (remember to rate this).
Sep 30, 2010 | Rl Flomaster 2 Gallon Acid Resistant...
I have a 15 gallon Fimco trailer sprayer. Last
Bleach gives off corrosive vapors, so the internal parts of the pump may have corroded over time. Least expensive fix is to disassemble the pump, find and replace any corroded parts, but you'll be tinkering for a day and it may not be repairable anyway. More expensive but faster is to replace the pump - check the GPM rating and find it here for about $60 - $100. Good luck!
Jul 05, 2010 | Fimco Trailer Sprayer, 15 Gallon, 2.1 GPM,...
Sprayer Gun Problem
Before choosing a garden sprayer you must identify the problem. Some areas can be spot-treated with small amounts of pesticide, other areas (such as lawns or large gardens) need a larger capacity sprayer. Sprayer sizes vary greatly, from 1 quart to 4 gallons, so finding a model to fit various gardening needs will not be hard.
Aug 27, 2008 | Chapin Industrial 2 Gallon Viton...
Sprayer Question
Hose end sprayers are the simplest and least expensive of the category. A sprayer jar is attached to a regular garden sprayer. Concentrated material is added to the sprayer jar. An adjustment on the jar determines the amount delivered. The force of the water through the hose pulls the material up from the jar and mixes and dilutes it with the water. A built-in anti-siphon device prevents unused material from being pulled back into your water supply. Compression or tank sprayers are the most common type of spray equipment. Concentrated material is added to the tank. Water is then added to a marked fill line. The remaining air is pressurized by pumping the handle a designated number of times. A control lever on the wand controls the spray pattern and amount. Compression sprayers provide a precise, on target, non-drift spray good for soil and lawn pests. Adjust the sprayer for a coarse, drenching spray, a concentrated stream or a fine mist. Tank capacities range from 1 quart to over 3 gallon for handheld models. Homeowner type backpack sprayers hold up 4 gallons. The tanks may be made from polyethylene plastic, galvanized steel or stainless steel. In addition to treatments for pests and diseases, compression sprayers are designed for applying cleaning solutions for decks and siding. Backpack sprayers are operated in the same manner as the handheld compression sprayer. The over-the-shoulder configuration makes it easier to carry the heavier load of material. Some backpack models also use a lever-style pump to maintain pressure without removing the unit form your back. Powered sprayers rely on a gasoline engine for spray power. Great for larger yards or gardens due to portability and capacity (12 gallons). Dusters are a slightly different breed. Dry powders (mostly for blooming plants such as roses) are added to a canister and applied by manually pumping. NOTE: Compression sprayers deliver liquid under pressure. Compression sprayers are powerful and efficient tools. This fact also makes them potentially dangerous. Always read the manufacturer's instructions and safety precautions carefully.
Aug 27, 2008 | Sp Systems 02sv320065 Farm & Home 2 -...
Chapin 1 Gallon Bleach SureSpray Sprayer Logo
205 people viewed this question
Top Chapin Garden Experts
Nick Olsen
Are you a Chapin Garden Expert? Answer questions, earn points and help others
