Question about Zenith R56W36 56" Rear Projection Television
Plug tv in and i get a large snapping sound from the back end
    Genius:
  • 1,112 Answers
Hi:
This is usually an indiction of a cracked flyback transformer or splitter block, the spitter block is responsible for dividing the high voltage between the three CRT's or picture tubes. This could also be caused by a open tracing in the Horizontal scan circuit, Sometime bad horizontal caps go bad and cause this error also, there could also be a cracked picture tube at its neck, the best way is to take off the back and make the room dark as possible and stand a short distance away and have someone turn on the unit, you will see the arc of blue high voltage from the defective part.
Posted on Aug 24, 2010
Testimonial: "thank u very much i will check into that tommorrow. info has been a great help again thanks"
Why do my spark plug wires I'm my 1994 ford
Probably not seated well on the plug. When you push the plug wire boot over the plug, you have to make sure the wire end terminal's ring end snaps onto the spark plug. It is not connected tight until you hear the wire's end terminal snap or click onto the tip of the spark plug. If you can't hear the snap, the end of the wire may not be seating onto the spark plug tip. Push the boot back away from the spark plug wire end to investigate-the boots can get very stubborn with age-keep twisting it and pushing it till you get it moving back from end of wire. Examine the metal end tip of wire-trey to snap a spark plug down onto it now-if there is a problem with the end terminals you will see it-it may be too big to snap over the spark plug tip and hold securely, or if the ends are bent, use pliers to straighten them out. If these are aftermarket spark plug wires, the end terminals may be too small to go over the spark plug tip. You would then need a new set of spark plug wires.
I suspect you just have not pushed the wires down far enough to seat them on the plugs-push the wires onto the plugs until you hear them snap or click. Then they are seated firmly, and should not be popping off.
Sep 04, 2013 | Cars & Trucks
How do you connect your nintendo 64 to your tv
You need two cables. One has a very large, thick end that fits into the back of the N64. That is the power cord, you just plug that one into the wall. The other cord is a little trickier. It has a smaller end that plugs into the back of the N64 to the side of the power plug. On the other end of that cord, you have composite cables. (The red, white, and yellow plugs). Just find the matching color plugs on the back of your TV, set it to the correct input, and you're all set! I hope this helps!
Apr 11, 2011 | Nintendo Video Game Consoles & Games
Sound went out on tv was told i need a sound module,also need to get price of one
This model had a lot of odd problems including loss of audio.
With back off as you look from back are three large circuit boards.
One on the far left has another board about 4X5 inches plugged into it at the left rear corner.
Every one of these sets, that is the bad board--controls audio, remote and many other things. Large board it is plugged into is called Small signal Board (SSB), small one is small signal module (SSM).
It is plug in board held with two metal tabs at either end on bottom, It will have printed on it a part number (usually on a white label) with the part number, popular one ends in 2581 but are variations.
Last time I used one it was about 100 exchange(they are all rebuilt boards now)
Ten minute task to replace with back off and 95% chance it is your problem.
Everyone of these sets with no sound or intermittent sound, it was the problem.
SD TECH
Oct 14, 2010 | Philips 60PP9202 60" Rear Projection...
How do I hook them up. Moved and can't remember how to hook them up. I have them on the side of the computer with plug in , one on the left side and 2 plugs on the right side...no sound
speaker A should two cables running from it plug one end into speaker B a large RCA jack,
Plug the other end into your PC Sound card (speaker out ((( )
then if it's a active systems plug Power converter into A/C port on back of Speaker A
Aug 24, 2010 | HP JBL Platinum Computer Speakers
Connecting TV and DVD for surround sound
HDMI is fantastic in that's the only thing you need to plug in to get what you want.
You'll need two of them however. Plug one end of the HDMI cord into the HDMI "OUT" on the dvd player and the other end of it to the receiver..labeled HDMI 'IN' Then, take the second cord and do that step with the receiver back to your big screen...HDMI OUT to IN.
Surround sound from TV sources only needs a L&R audio cable connected to the receiver input labled TV or MONITOR audio IN. Unless you'd like 5.1 dolby digital or DTS from the television that requires devices that you haven't mentioned owning. In that case you will be able to get Dolby ProLogic and Pro Logic II from stereo broad casted sources on your TV.
Jan 21, 2009 | Onkyo HTR500 Receiver
Swithced ic chips
Those wires are ground wires they don't matter where you hook them up....there is a wire that comes off the trippler (the pice that hangs off the metal that holds the tubes and has the 4 big red wires plugged into it) and plugs into the deflection board is that plugged in?
Sep 20, 2008 | Televison & Video
We have been enjoying our 50" Pro 1110hd plazma Tv for 4 years with no problems. Last night the screen went blank and there was a sharp snap noise. We cannot turn it back on as it tries to start up...
The large snap indicates that there was a high voltage spark inside the set. Something blew. The set has protection circuits that detect problems and to prevent further damage, will shutdown the set. This unit should see a service center. There is little inside that can be repaired by a homeowner.
Dan
May 01, 2008 | Televison & Video
Rca ctc195 big screen tv trouble
You are likely to have a high voltage transformer bad which is common problem for ctc 195 RCA If you look into the back of the tv it is the white square looking thing about 3 inches across by 3 inches with the large red wire coming from it and going back into the set. Must have original RCA part and must be unsoldered and solder in new one. Not to be done by the untrained. Average cost to come out and repair is $250 to $300. depending on the repairman (Note: the chassis is in a complete wooded chipcore box that will come out with quarter inch nutdriver and unplug two plugs at the top of the box The box or chassis can be taken to the repair shop leaving the screen at your home saving a service call. Hope this helps
Dec 30, 2007 | RCA P52937 52" Rear Projection Television
Zenith R56W36 56" Rear Projection Television Logo
231 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
