I have a 2400 HD raedon pro video card and I cannot boot in safe mode.I get as far as the black screen that says safe mode but that's as far as it goes.
    Genius:
  • 1,112 Answers
Hi:
I dont't think this is the video card causing this error, it just may be the harddisk drive that is freezing up the unit, Check in your Bios for a HDD checking feature. And run a full scan on the HDD to determine if it is indeed the HDD. If you think its the video card remove it and install a different card to verify this is the problem, most modern motherboard come with built in video capability. take out the 2400 and connect to the on board video connector and try booting then, if same results then either windows is corrupted or the HDD is faulty.
Posted on Aug 24, 2010
Monitor goes blank when trying to use radeon HD 2400 Pro graphics card
Well Michael,
it can be your monitor thats broke u can test it on a other system and see if the monitor works or not,if it works than u know its your graphic card thats broke and u should replace it
May 09, 2014 | ATI RADEON HD 2400 PRO Graphic Card
Black screen and no sound on my Hauppauge Colossus PCI Express Win 7 capture card. I have confermed that the signa is getting to the card, by plugging each the HDMI, S-Video and composite video cables into...
Restart your computer and then press and hold F8 keys until you get Advanced Options menu screen.Use the arrow key to highlight Safe Mode, and then press Enter, your computer will boot automatically to safe mode.
If you able to start in the safe mode then Scan your computer for viruses. Some viruses can cause a black Screen , especially ones that infect the master boot record (MBR) or boot sector.
Update drivers for your hardware. black Screens are hardware or driver related so updated drivers could fix the cause of the STOP error.
Return BIOS settings to their default levels. An overclocked or misconfigured BIOS can cause all sorts of random issues, including black screen.
If it didn't helps you then simply get the system utility program like PC Fresher that will fix windows errors that cause of black screen screen
Aug 27, 2013 | Hauppauge Colossus PCI Express HD Video...
OC problem - boots into black screen after botched OC
Hello booting to safe mode is by pressing the F8 button
while you boot
And select one of the boot options useualy boot with network support. Out of safe mode is just to reboot.
Try to set the graphic settings back to factory specs.
If you still have black screen you might have burned the gpu chip
and the graphic card must be renewed.
If you have any luck try to renew the driver from here:
http://support.amd.com/us/gpudownload/windows/Pages/radeonaiw_vista64.aspx
This is the windows 7 driver 64 bit.
If you are running another windows system select it here:
http://support.amd.com/us/Pages/AMDSupportHub.aspx
Hope this will help you
Nov 13, 2012 | ASUS ATI RADEON HD 5870, (1 GB) PCI...
Im useing a ATI Radeon HD 2400 Pro and when i go to play sniper ghost warrior i get the sounds but no video i get a black screen saying invalid format and im using a windows vista tower and a vizio 3
Check and configure the video card to the game.
Go to the game menu, video, and adjust it for the right specs to the video card.
Hope that helps!
Dec 24, 2011 | Motorcycles
Get "out of range" video display error - screen is
shut the system down and when u hit the power button on the system start tapping the f8 key and select the option safe mode and when in safe mode go ahead and uninstall the driver from add and remove programs in control panel and restart the system and go in to the normal mode and download the latest version and install it
Jan 23, 2011 | ATI RADEON HD 2400 PRO Graphic Card
ATI Radeon HD 2400 Pro install - computer won't boot when added
Click here to for your computer product specification.
ATI Radeon HD 2400 Pro is a PCIe and your computer is compatable only for PCI
hope this helps,
Thanks, Prem
Feb 18, 2009 | ATI Diamond Multimedia Stealth RADEON HD...
My computer comes up with a black screen
try and start in safe mode
then see if your driver is correct in my computer property hardware devices
Jan 17, 2009 | ATI RADEON HD 2400 PRO Graphic Card
Display problem ...Graphic card or screen
that is graphic problem, you might not properly set the correct resolution, or the cord might loose connection. try to remve the video card clean it then re install
Oct 04, 2008 | Computers & Internet
Raedon DDR video card
Check that you have installed the correct driver for your model video card and the correct OS version.
To check that the video card and driver is working, you may have to boot up in Safe Mode, go to Control Paned - System - Click on Hardware Tab - Click on Device Manager button - scroll down the list and if you see a yellow ? against the video then there is a problem with the video driver.
The problem could be that the refresh rate for the monitor is too high for the monitor to handle.
Boot up your computer and press F8 and then run in Safe Mode, go to Control Panel - Display - click on Settings Tab - click on Advance the Monitor Tab and change the refresh rate to 75Hz or lower.
Reboot again
Sep 02, 2008 | Dell OptiPlex GX110 PC Desktop
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
