Question about ASUS K8V-MX Motherboard
Can i install 1tb hdd with asus k8v-mx motherboard
map9966
  • 2351 Answers
SOURCE: ASUS K8V-MX Motherboard with 250GB SATA HDD and 250GB IDE HDD Problem
Hi LP,
I’ am very familiar with ASUS motherboards. I am thinking you have posted two questions or more referring to the,
ASUS K8V-MX board. When you sign into you're FixYa account you than need to click on you're profile. Within you're profiles are the questions you have posted. Click that question to add or see the expert's answer. If you need another question (about the same item) re-post within that same question. You can even copy the link to an older post & past that link into you're next question. (Than I can read you're last question & my responce).
LP you have me all mixed up. I'll answer the question you have posted above. In the future please provide you're old post so I understand better.
There is nothing wrong with IDE 250GB drive or the SATA drive.
The problem you are haveing is setting the correct settings.
The ASUS K8V-MX can support two serial ATA SATA drives. The SATA drive's can only run at 1.0 version. 1.5GB transfer speed & not SATA II, the 3.0GB speed.
How to setup the SATA drive?
Please disconnect any other drives (IDE) & a second SATA drive that may be connected to the system. Except the CDROM drive.
Using you're manual the SATA drive should be connected to SATA1 port. Page 1-24 in you're manual.
Put you're windows CD into you're CD-ROM drive & boot the PC. You will see, Press any key to boot from CD... (press any key on your keyboard). Windows will start to install. Durring installation of windows the system will restart. You will again see, Press any key to boot from CD... (DO Nothing)!
Just allow windows to conintue on its own. Windows will continue to install it's self. This will happed once again, & again do nothing. Windows will finish installing it's self.
After windows has finished, load the ASUS CD into you're CD-ROM drive & install it's driver software. Restart the PC.
You must register windows. Do so.
Than update windows through windows update service. (This will take some time to complete). (Do not install service pack 3).
If you have an IDE drive 250GB in size & you installed windows on it. You must erase the drive or it will conflict with you're new installation on the SATA drive. To do this, look on the IDE drive & you will find a large white sticker. Printed on there is instructions of how to set the drive pin. Set the drive up as a slave drive. (This is only temporary).
Power off the PC & unplug the power cord. Connect the 250 IDE drive's power cable & data cable. Plug in the power cord to the PC & turn on the PC. Windows will load. Right click once on the start button & slide up to & left click on Explorer.
Find the 250 IDE drive, it should be drive letter D or E. Right click the proper drive letter & format the drive.
( Do Not format, Local_Drive C:\ ). Once the format is complete, power down the PC by clicking on the start button & click turn off the computer. Once off, unplug the power cord. Change the pin on the 250GB IDE drive to Master with a slave. Take the 40GB drive & change it's pin so the 40GB drive is a slave.
Connect the 250GB drive to the end of the IDE data cable & connect the 40GB drive to the next connector of the same IDE data cable. Re-check all power cables & data cables for good connections before closing the case. Plug the power cord in & power up the PC. Everything should run just fine.
Setting the pin for you're IDE drive's can be very confusing. Click on the link below. This will give you an idea of how to set you're pin for a master drive, master with a slave drive. If you post the name ST****** of you're two drives I can post the correct pin locations from Seagate's web site.
http://www.seagate.com/images/support/en/us/mxo_ata_jumpers.gif
Have more questions about this post?
Mike
Posted on May 21, 2008
  • 10 Answers
SOURCE: Need asus k8v-mx video drivers
Get your drivers from this link
http://support.asus.com/download/download_item.aspx?product=1&model=K8V-MX
Posted on Jun 09, 2008
Styme
  • 84 Answers
SOURCE: K8V-MX SATA and XP instal problem
http://support.asus.com/download/download.aspx?modelname=K8V-MX&SLanguage=en-us
then go to RAID select 4 th one down in RAID
2.0.950.430 XP raid driver
Posted on Jul 24, 2008
  • 70 Answers
SOURCE: ASUS K8V-MX SOUND DRIVER PROBLEM
Is the driver the right one? What operating system do you use?
Try disabling/re-enabling the device and/or reinstalling the driver.
Type your model number into the search box on this page:
http://support.asus.com/download/download.aspx?SLanguage=en-us
Download the available audio drivers.
Hope this helps!
Posted on Oct 23, 2008
ericbrunswic
  • 88 Answers
SOURCE: How to install soundmax drivers for ASUS K8V-MX motherboard
I have found a link for the driver for the ASUS K8V-MX motherboard.
SoundMax Audio Driver V5.12.01.5150 for Windows 98SE/Me/2000/XP/2003
Download the file and then run it,
I hope this helps,
Eric
Posted on Jan 19, 2009
Sir, Im having P4BP-MX Motherboard 2GB DDR 40 GB HDD, CAN I GO FOR 1TB HDD for my Motherboard. I bought 1TB its not identifying Is my P4BP-MX Motherboard support 1TB or Not ?
There's two things wrong:
1. You can't simply install a hard drive and then use it. You have to format it and/or install an operating system on it.
2. Your motherboard is a very old model. While it is new enough to support LBA48 mode (which is necessary to fully use hard drives above 127 GB), it is possible that it has an old BIOS version that does not support it. You should check ASUS' website to download and install the latest BIOS update.
Dec 11, 2014 | Samsung Computers & Internet
Everything was disconnected from my motherboard and power supply. It is an Asus K8V-MX/s
You will get all the required stuff as i have viewed and confirmed, from this source.
http://dlcdnet.asus.com/pub/ASUS/mb/sock754/K8V-MX/E2335_K8V-MX_h.pdf
best of luck!
Mar 11, 2012 | ASUS K8V-MX Motherboard
I have K8V-MX motherboard. I am planning to buy a 1TB SATA HDD Will this support ? Thanks! Madhusudan
Your model KV8-MX motherboard does not have a SATA controller.
To install a 1Tb SATA hard drive you need to install a PCI SATA controller and then connect the SATA hard drive to this controller board.
Aug 21, 2010 | ASUS K8V-MX Motherboard
Asus K8V-MX vista driver not found
Here is a link to download a driver for your motherboard Asus K8V-MX:
www.yboyandrei.com/K8V-MX
Please rate me.
Thank you.
Sep 14, 2009 | ASUS K8V-MX Motherboard
Asus k8v-mx mbd no display
It would be nice if you can get something on the screen, isn't it? Try fixing a AGP VGA and check. Remove HDD cables while checking for MBD errors.
Jul 31, 2009 | ASUS K8V-MX Motherboard
PATA SATA PROBLEM
This motherboard does support SATA. Check out the specs on the ASUS website:)
http://www.asus.com/products.aspx?l1=3&l2=14&l3=225&model=754&modelmenu=1
Dec 30, 2008 | ASUS K8V-MX Motherboard
Sata driver
check for the website of your HDD vendor.eg-www.seagate.com for seagate hdd.
make sure you format using fat32 file system.
Jan 28, 2008 | ASUS K8V-MX Motherboard
All drivers that are on CD are also on this page (motherboard driver page):
http://support.asus.com/download/download.aspx?SLanguage=en-us&model=K8V-MX
Oct 24, 2007 | ASUS K8V-MX Motherboard
NEED FOR K8V MOTHREBOARD SATA DRIVER
there are 4 different k8v motherboard types, you didnt say which variant?
but you shouldnt need any 3rd party drivers, either the one built into the cmos, or the ones that are on the cd rom that comes with the motherboard should work fine with win2003.
they have always been fine on my installs, just ignore the question on the initial setup, its only asking incase you need to use one, you dont have to.
Oct 17, 2007 | ASUS K8V-MX Motherboard
ASUS K8V-MX Motherboard Logo
81 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
