Question about Toshiba MD20FL1 20 in. TV/DVD Combo
My dvd player will not recognize the DVDs. I am not using burned dvd's or anything unusual, it will just say "No Disc" when i have a regular DVD in. How can I fix this?
    Genius:
  • 1,112 Answers
Hi:
this is due to a bad optics or mech assembly, the most common failure in DVD/CD players is the spindel motor, this is the motor that actually spins the disc, the bearings in the motor wears out and does not spin up to its right rmp, thereby causing a speed sense error to the microprocessor and the unit stops or says no disc. Replace the mech assembly to restore operation back to normal.
Posted on Aug 24, 2010
  • lljwales
    lljwales Jul 10, 2012
    how do i replace the mech assembly?
Blaupunkt tv/dvd...dvd is not reading the disc
Most likely the disc is badly scratched or is a format not compatible to the player. Commercial DVD? Or home-burned DVD-R? They are totally different formats. DVDs can be made using many different audio and video CODECS. Players are designed with support for specific CODECS and will not recognize others.
Dec 26, 2013 | Car Audio & Video
Make my memorex mvd2040 play homemade dvds (avi files on a disc ) ?
In order for you to make the unit read home movies, you haveto make sure the AVI files are being converted to a DVD format. If the video isnot transcoded to that format, the player will not recognize the disc. You willneed to use a burning application that converts the files prior to burning it,or get software that converts files to DVD and then burns it to a disc.
Dec 05, 2010 | Memorex MVD2040 DVD Player
Dvd won't play disc on my daenyx tv
check to make sure it is proper format,. if it is burnt disc, dvd player may not recognize format. if all regular dvds do not play, it is problem with player, use head cleaner for lense, if that does not work, purchase new player. without more info, all i can suggest is basics
Oct 17, 2010 | Televison & Video
It says no disc inserted
well it sounds like a problem with your lense. so just take it apart and look at your lens and see if there is anything wrong or out of the ordinary with it.
Sep 27, 2009 | Toshiba SDV395 DVD Player/VCR
DVDs burned with Pioneer DVR-110D do not play on the same burner
Are you burning the files with a DVD+R format. Use DVD-R. Not all players will recognize DVD+R. Also, check the region that the movies are made in and see if the player can be switched to that region. Also, are you trying to burn files larger than 700 MB. If you are, in creating an iso image or copy if you are downloading the file you have to match the checksum of the original file to the downloaded one.
Jul 25, 2009 | Pioneer DVR-109 DVD±RW Dual Layer...
DVD burner will not burn or finalize
There are three things you can do that will eventually give you a working solution. Depending on the level of problem. Start with 1 progress to 3 until it works.
1. Use a cleaning disc. (one that use an alcohol based liquid)
2. If the cleaning disc does not solve it, you can use an ear bud, with some iso-propyl alcohol to clean the DVD lens on the drive directly. (you have to open the player and the drive)
3. The guaranteed working solution is to replace the DVD drive inside the player. This is quite a simple process, as most players use a standard IDE DVD-ROM or DVD writer.
You simply remove the face plate, (apply power to the drive, and press eject first) the tray will open. Unclip the tray face, and then with the tray open you can unclip the plastic face plate too.
Remove the old drive, and fit the new drive by reversing the removal procedure.
Once everything is assembled you should be able to watch DVD's again. If you can't find a cheap DVD drive locally, try ebay.
I have done this on over 50 players for my clients in the past. I use LG DVD roms and DVD writers for the DVD recorders, irrespective of brand.
Let me know how it goes.
Jun 15, 2009 | Lite On LVC-9016G DVD Recorder/VCR
Did not burn dvd
The DW-100 burns files in the same format as they were originally recorded by your camcorder. The Canon Vixia HG-21 records in AVCHD--a high-definition format--which is completely different from standard-definition DVD and which is not compatible with regular DVD players (even though the disc itself is a standard DVD-R). As it states in the manual for the camcorder, "High-definition (AVCHD) discs created using the optional DW-100 DVD Burner can be played back only with AVCHD-compatible DVD players."
The DW-100 is really more for archiving your files in their native format than for creating standard DVDs that can be played on regular DVD players. Regular (standard-definition) DVD players can't play AVCHD, although many Blu-Ray players can. Unless you use a Blu-Ray player that supports AVCHD playback, there are two solutions to your problem:
1. If you want to keep your recordings high-def, you can view them by playing them back with the DW-100, which must be connected to your camcorder via the USB cable, then from your camcorder to your TV via an HDMI cable.
2. If you want to have standard DVDs that you can play on any DVD player, either import the files to your computer and convert them to standard-definition using video-editing software, then burn them to DVD with your computer's DVD burner, or connect the analog output (component=better, composite=good) to a stand-alone DVD recorder (i.e. not the DW-100).
I've used the route of Vixia HF-10 camcorder > composite output > Panasonic DMR-ES25S DVD recorder (about $65 used on eBay) with pretty good results when I've wanted to give videos to relatives who don't have Blu-Ray players. You just have to make sure to set the camcorder 's analog (composite) output to 480i so that it formats the picture in the right aspect ratio, or else the 16:9 image will be squeezed to 4:3 instead of letterboxed.
Hope this helps. Good luck.
Mar 19, 2009 | Canon DW 100 DVD-RW Burner
HP LightScribe 740i dvd burner/ wont read dvds
u try using 80 conducter cable,if u using 40 conducter cable ,
regards prasanna
Mar 03, 2008 | Computers & Internet
Toshiba MD20FL1 20 in. TV/DVD Combo Logo
153 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
