Question about KitchenAid 24 in. KUDS01FLBL Built-in Dishwasher
No water iis spraying during tha first cycle. The control panel seems to be working property.
  • 530 Answers
Sounds like you have a broken chopper
is it just the top rack not getting clean or do you not have any water at all? do you hear humming?or does it not do anything?
Posted on Aug 24, 2010
Spray arms not working
Hi frustrated in Raleigh,
I understand that the spray arms are not moving or spraying water, even after you have cleaned the screens and arms. What might be happening is you are not getting enough water pressure to the dishwasher.
The hot water line to your dishwasher must provide water pressure between 20 and 120 psi.
Low water pressure may occur when laundry or showers are in operation.
Wait until water use is reduced before starting dishwasher.
If you are still noticing that the spray arms are not moving or spraying water, I would have a local Authorized Technician come out to see what exactly is going on with the spray arms of your dishwasher.
-Best Regards-
Jan 06, 2014 | Frigidaire FPHD2491KF Dishwasher
Frigidaire FFBD2403LW normal cycle hum
Hello ddux97 - Often this occurs because either not enough water is being pumped to the spray arm or in other words the full flow of water is not making it to the upper spray arm. Will the spray arm rotate freely? If it does not, then you might have to remove or replace the spray arm assemblies since it is possibly damaged. Confirm that the drain hose is strapped up properly under the sink to prevent the water from siphoning out during the cycle. If issue persists, I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if the unit's status has changed successfully.
Jun 20, 2013 | Frigidaire Dishwashers
Water sprays into machine on spin cycle
the machine is programmed to spray water during the initial period of the spin cycle as an added method of removing any remaining suds
that stops then the spin cycle goes into high speed spin for that last few minutes
If the problem is that it continues to spray water until the spin cycle is finished it will be the program board or program controller switch
Oct 15, 2017 | Washing Machines
The dishwasher seems to be cycling - but I no longer get the flush into my disposal and I don't hear much water circulating inside the machine. Also, the soap doesn't all diappear. Any suggestions?
The high pressure water pump is defective and is not spraying the much required jets of water to the dishes.
This is the reason that your dishes are also not cleaned.
You might have to remove and check if the pump is faulty or a cleaning job can rectify the issue.
Sep 11, 2010 | KitchenAid KUDS03FTBL Dishwasher
Dishwaher does not spray water during the wash or rinse cycle
Check m/c water pump. Look for clogged water ways inside the machine wash chamber. Check you water inflow to the machine also.
Apr 06, 2010 | Maytag 24 in. MDB5600A Jetclean II...
How do you know if your dish is working property
1. water temp must be 120+
2. soap must not be old
3. Machine must work as designed
place a cup upright on the top rack, run a few min. it should have some water in it.
Usually the spray arms are not turning with that problem. They are designed to turn by water forced out the end of the arm, much like a lawn sprinkler works.If the end holes are clogged, it wont spin. The arms should spin freely.Then check to make sure that the water didn't drain out as fast as it came in. Some D/W have a valve that will get stuck open and the water drains out during the wash cycle..no water, no wash..
Oct 25, 2009 | Dishwashers
The dish washer is taking ages to wash and it not clean ing dishes well
ok so If your dishwasher has worked fine in the past but, suddenly, your dishes aren't clean after the dishwasher completes all cycles:
1) Check your water heater's temperature dial to be sure it hasn't been changed recently.
2) Be sure dishes haven't prevented the detergent dispenser from opening properly during the wash cycles or kept the spray arms from turning, the lower arm from rising, or the spray from reaching the upper rack's dishes.
3) During the wash cycle, listen to the spray arm spinning inside. If it seems to be spinning poorly, clean out the spray holes in the spray arm(s) with a stiff piece of wire; wait for the machine to cool, and then remove the spray arm(s) by unscrewing the hub cap and lifting the arm(s) off
Regards Gizokieth
Sep 10, 2009 | Dishwashers
Our dishwasher is not running through all cylcles
Either:
1. the water does not get into the dishwasher open the dishwasher 3-4 times during cycle, you should see some water at least once, if not - check water valve, water level float and water pressure.
2. the pump is clogged - there is water, the motor will run but no water is circulated. Check pump filters, check chopper and impeller.
3. motor in main pump is not working - could be caused by something stuck on the impeller or chopper or could be a problem with the motor itself or control board. Check if line voltage is coming to the motor during wash/rinse cycle.
Good luck,
Vlad
First Choice Appliance
Dec 02, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Basin will not fill with water during rinse cycle but will agitate and spin.
most new washers have cold water only rinse and spray rinse ck cold water coming into machine during wash if no cold comes in suspect cold side of fill vale not opening ..could be wiring issue or a bad valve
Oct 24, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
KitchenAid 24 in. KUDS01FLBL Built-in Dishwasher Logo
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
