SanDisk Sansa E280 MP3 Player Logo
Posted on May 05, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Corrupted files I have formatted the e280 several times. The music does not appear on the unit but if you looke at it on the computer it shows numerous corrupted files that you cannot get rid of. When you try to delte them the computer tells you that the e280 is either not connected or available.
  • Jean Sintulaire May 11, 2010
    How did you format your device?
ThaMp3Doctor
Level 3:
  • Master 8,597 Answers
  • Posted on May 23, 2008
ThaMp3Doctor
Master
Level 3:
Answers
8597
Questions
Helped
2173452
Points
14133
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
or
http://www.sandisk.com/DriverDownload/driverList.asp
-Tha Mp3 Doctor
I need to recover deleted memory
Try re-installing the drivers or updating it online :)
Added music, but can't listen
I experienced a similar problem caused by corrupt files saved on the internal memory of my e280.
(I could not delete/remove the files) I had to format the internal drive of the e280
and re-copy the files back on to the unit. Works great now. When formatting the device
use the command from windows. (ie right click on the internal memory icon and select format)
Note: Formatting will remove/delete all the files (eg music,photos..) from the e280 so make sure that
you have backups.
Cheers
2answers
I can't delete my music!!! Please help.
I'm having the same problem and trying to work through it. The problem is that your memory in the music section is corrupt. You may need to reformat. If I figure it out, I'll leave a note for others.
Apparently, this is a problem with this player. Not sure why. I've had this problem in the past and was able to fix it by disconnecting the battery and then reconnecting. But this time it's gone. I had a "bad track" message before it stopped.
2answers
Is there an easy way to delete all the music off of my mp3 player?
it says in the user manual that you have to hold down the power/menu button for about 15 seconds
E280(8GB) not responding
What I would recommend you to do is to format your device...
Formatting the player erases all files in the player, and oftentimes this is the best option to ensure that all files are removed and any corruption eliminated. Also, it is best to format the player when in MSC mode.
2. When the appears as a drive letter (under MSC mode), right-click on that drive letter and select "Format". On the "Format" pop-up window, click "Start" to begin the format process.
3. Follow the on-screen prompts and safely remove the player from your PC when the "Format Complete" display appears.
4. Unplug the player from the PC and when the player is powered up, the message "No Files" should appear on the player's LCD screen
5. Switch the mode back to "MTP", or continue to use "MSC". Note: It is best to use "MTP" when you are transferring subscription music to the player
Then I would recommend you to get the latest firmware upgrade for your device..To get the latest firmware upgrade follow this link...
http://sandisk.com/Retail/Default.aspx?CatID=1376
Thank you
Computerrep
P.S. Please rate accordingly...
2answers
Sansa e280 not formatting
Lets the battery runs out and then try to charge it again, it worked for me
5helpful
4answers
Delete songs from sansa e280
Open up your windows media player and click on the sync tab..your device should be listed there..and also it will show you all the songs you have in there...or you can just format the whole player..formatting will erase everything in that player...
Sansa e280- files added via WMP10 or Windows explorer, but don't show up on player
No limit on the Genres.
If you keep adding music in different modes, Windows Media Player and Windows Explorer will not show the correct free space.
Theres a good chance you have too music music on your device and the device does not have enough free space to create the Database, or the songs, artists, album, etc.
Try deleting a few songs from the device with Windows Explorer and disconnect the player and let it restart.
If that doesnt work, you can FORMAT the device to remove all of the music and start over.
To format in My Computer>Device name (e280)>Right Click and select FORMAT.
Best of Luck.
My e280 has 8gb but only 2.5gb shows with nothing on it have upgraded firmware but still the same
Sounds like you may have some corrupt music on the device.
Try formatting the device thru My Computer.
My Computer>Device Name (e280)>Right Click and select FORMAT.
This will erase everything and you should see all of your space available again.
Best of Luck.
1helpful
Formated the SanDisk Sansa E280
You dragged & dropped files in recovery mode? Recovery mode is only for re-installing the firmware or formatting the device if it is unresponsive. If you are wanting to drag and drop files onto the device, the music needs to be put into the Music folder on the device. If you do not see the Music folder, you will need to enable hidden files and folders on your PC. Best of Luck. p.s. - you can add to this question this doesnt work.
Top SanDisk Audio Players & Recorders Experts
SmartAviator
SmartAviator
Grand Canyon Tech
Grand Canyon Tech
Alexander
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
