Question about Canon PowerShot SX20 IS Digital Camera
I have a cannon powershot sx20 and it keeps reading memory card error. i have tried to put in different sd cards but all the same thing
  • Canon Master
  • 17,130 Answers
It is possible that the card reader software is corrupt within the camera controller unit. If there is any connecting cord which can be used to connect the camera to your PC, then try this tip. Remove the battery and reinsert. connect the camera to be detected, now use a virus scan on the new hardware, if there is any detection remove the error from the memory
If this wont work then it is possible that the card reader connection within is faulty, might have to remove to take a good look inside.
Otherwise do not tamper but a camera tech to have a good look rather than tampering with poor tools.
I was not able to get your chat line but I hope this helps.
Posted on Aug 24, 2010
Cannon s5is powershot as soon as i turn camera on a memory card error comes up and theres no card in it, does same thing when card inserted. it's got to be something in the camera slot, is there a lock in...
On the SD card there is a little switch you can move. It has 2 positions, LOCKED, and UNLOCKED. To make the card available, put the switch in the UNLOCKED position.
Here is an example-
If that doesn't work, try putting the card into a memory card reader, like on your PC or a special USB attachment. If the memory card is recognized, then it might be a problem with your camera.
Mar 01, 2011 | Canon PowerShot S5 IS Digital Camera
My Cannon Powershot SD1200 IS says there is no memory card inserted when my memory card is in the camera. Help!
this card does take sdhc cards so that shouldnt be a problem, if your using it with 32gb try a smaller card like 4 or 8gb. if you can, try another card and try using a memory card reader with your computeer to see if it reads it. if all failes its probably time for a new sd card
Feb 27, 2011 | Canon PowerShot SD1200 IS / Digital IXUS...
The camera reads memory card error but when I go to the menu to format the card the format catagory is not highlighted and when you page down it skips over the format area. I am using a scan disk mobile...
There are no 16GB SD cards. A card that size is actually an SDHC card (yours actually sounds like a Micro-SDHC card). SD and SDHC cards fit the same slots, but they are slightly different. Many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible.
You really don't need a card this size on a still camera. 1Gb is plenty. If you really need more space, you can carry a spare, like people used to take extra films with them on holiday.
I don't know why the 512Mb card is giving you trouble. This might indicate an actual fault.
Dec 11, 2010 | Canon PowerShot SX20 IS Digital Camera
When putting the memory card into my canon powershot sx20 is i am getting a memory card error
These questions are old, I hope you have found a solution to your problem if not try this. The memory card needs to be formatted. You have been deleting pictures and not formatting, in this case format the memory card. Always format and never format in the computer the programing between the camera and computer are not compatible.
How do i fix a memory card error
Probably the first thing to try is formatting the card. There is a function in the camera menus to do this. If it won't format or gives an error when you try, then there may be an issue with the connectors in the card slot or the card may be incompatible. SD and SDHC cards fit the same slots, but many cameras won't work with the SDHC (high capacity) cards. Some cameras have a capacity limit, and won't work with cards that are too large (in memory terms).
Oct 27, 2010 | Canon PowerShot SX20 IS Digital Camera
I keep getting a memory card error for my Canon Powershot SX20. I tried a 4 and an 8 GB card and keep getting error message. Also made sure the lock was off. Any ideas? It's a brand new camera. Thanks.
Have you tried wiping your memory cards completely? The formatting may have gotten messed up somehow so the camera can't recognize them. I would also check the contacts on both the camera and the cards to make sure they are free of dust. It could also be a problem with the cards themselves, but I find it hard to believe that they would both fail simultaneously; just to make sure, buy a brand new SD card and see if that works (it doesn't have to be big, you can probably pick up a 1 GB card for less than $10). If all of that fails, there's a pretty good chance that your card reader is bad. Considering that your camera is brand new, you should have no trouble sending that in for a warranty repair.
Aug 01, 2010 | Canon PowerShot SX20 IS Digital Camera
Canon PowerShot SX20 IS Digital Camera keeps giving me a memory card error. The memory card is a 4gig PNY memory card (lower budget)
Make sure the slide switch on the side of the card is unlocked. Your camera may just want you to format the card in the camera. Download any pics from it first using a card reader if necessary.
Jun 22, 2010 | Canon PowerShot SX20 IS Digital Camera
Memory Card Error
You could take the card to a store that has a Kodak picture maker machine (Walmart, etc.). From there, you can print your pics or even make a cd of them. The card may be faulty or just may not work in Canon cameras.
Aug 28, 2009 | Canon PowerShot A520 Digital Camera
Sd card error on canon powershot s3
I get a memory card error everytime I insert a memory card. They are not locked and I have tried 4 different memory cards and nothing works. How can this problem be fixed?
Jul 28, 2008 | Canon PowerShot S3 IS Digital Camera
Canon PowerShot SX20 IS Digital Camera Logo
315 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
