Question about Denon AVR-900 Receiver
Yes when I hit the power button the standby light blinks 6 times and then stops and stays solid. Nothing else happens after that. Thanks for the help. Chris
  • Chris Davis
    Chris Davis Aug 24, 2010
    Thanks for the suggestions. Maybe I can tell you what I have tried and you can guide me in the right direction. I pulled the cover off and checked the fuses. One was blown so I replaced it. when I hit the power button the unit made a loud hum and then blew the fuse and smoke came from around the front center of the main board.
  • Chris Davis
    I took a picture maybe it will be easier to walk me through which parts will need to be replaced.
    Top Expert:
  • Denon Master
  • 78,267 Answers
This indicates the output circuit of the amplifier is shorted out, this can be a defective power transistor or a shorted speaker wire or speaker, disconnect the speakers and try the amp, if the light doesn't flash u have your answer,if it still does the same thing u have a defective amplifier and need to have a shop repair it.
Posted on Aug 25, 2010
  • 5,807 Answers
• If you feel you can DIY, you may have to check for
Power Transistors , on the Main Amplifiers and have it
removed.
• If the Unit turns ON, then have the pair of Power Transistors
replaced.
If the Unit still wont turn ON, you may have to check for
low voltage regulators.
• If you can try to monitor ( hooking up to other amplifier
or Signal Tracer ) the Line " Out " at the back of the unit
and hear sound , you just eliminated a large percentage
on electronic troubleshooting. ( you may not need to check
for more regulators on the preamp circuits. )
• But have a check on 12V supply/circuit also.
• More thorough troubleshooting details can be done with a
help of a
Denon AVR900S/M
http://www.encompassparts.com/products/?AVR900S/M
( only with a fee ) Click on the link above
Should you need more details , post so I can help you
further.
Regards, and Good luck!
palaboy
Posted on Aug 24, 2010
  • 33 more comments
  • Rommel Cana
    Rommel Cana Aug 24, 2010
    • you may need to take out the power transistors,
    or test each of them with a Multimeter.
    Check the collector and emitter on each , ( usually the center and the right most pin )
    • If it is a Module have it removed.
  • Rommel Cana
    You may not the sound you need yet, but the blinking should stop.
    • Then you can trace further if audio can reach the inputs on each amplifiers using a Signal
    tracer or another small amplifier
    here are your guide , just in case you need one:
    a ) Start with the input , then to the op-amp IC. b ) check your cable like those above for co
    Source:
    http://www.fixya.com/support/r4008719-di...
    these may not be the same as yours, but the process of troubleshooting is the same
    • Once you can confirm there is audio, it is now time to order on line the part that you will
    be needing to replace..
  • Rommel Cana
    • or can you possibly describe what it looks like ( component that get burnt/smoke ) ?
    or have an image or a picture perhaps if you cannot describe it.
  • Chris Davis
    I unsoldered a transister I believe. Its square with 3 prongs coming out bottom. When I took it out I put it all back together. Put in new fuses and hit the power. It came on the display came on for a few seconds then went to protect.
  • Rommel Cana
    Thanks for the quick response!
    • It is not only one transistor , they are transistors ( see the link above ).
    They ( transistors ) are in pairs.
    It is an NPN and PNP type.
    • One way to isolate is to have it all remove.
    But put something in there to mark what you have extracted.
    Say C X X X X ( NPN ) and A X X X X ( PNP ),
    we will have to deal with these later.
    • Once the protect does not appear anymore, and the fuse is not blowing ,
    Then check all the component that you have extracted , one by one.
    And post , before you put it back.
  • Rommel Cana
    • transistors may look like these:
    These transistors are mounted on the aluminum heatsink
  • Rommel Cana
    Without these Power Transistors connected ,
    • It should not blow fuses
    • There should be no sign of protect.
    If protect still appears do not put back the said transistors and we will troubleshoot more.
    • Look for you Multimeter and you will measure Offset Voltages on each amp out
    ( without the power transistors )
  • Chris Davis
    Ok I pulled the next one also know it stays on so those were the problem. Now I am wondering how to go about finding these replacements. I also noticed a burned resister right by those two transistors. How can I find the value? I have the number off of the circuit board
  • Chris Davis
  • Chris Davis
  • Chris Davis
  • Chris Davis
  • Chris Davis
  • Chris Davis
    Would you know where I can find these transistors .
  • Rommel Cana
    OK, now , if the unit now turns ON , and there is no more protect ,
    no more blowing of fuses then.....
    • you may have to replace the component later , after you can hear sound on other channel.
    sample :
    you can connect a small speaker there might be a small sound , not like the original one
    which have a loud and strong Audio.
    • just see to it that the audio you are hearing is OK ( clear ), although a weak one.
    When it does , you are ready to order parts on line.
    post the number or letters printed on the transistor and i will look , where you can find it.
    it might also include resistor , be sure to check everything before connecting a new one
    and post
  • Rommel Cana
    you can test the unit , without the power transistor for a whole day, just to insure your new
    power transistor will not get damage.
    • Before hooking up the new , insure the resistors with it are OK , or your new transistor will blow
    same with the fuse.
    Since it is only one pair, other channel will work ( will have audio ) Normally speaking.
    The channel ( wherein there is no power transistor ) should work only with a weak but clear
    audio on a small speaker.
  • Rommel Cana
    • If the Audio ( on the channel which have no Power transistor ) have a distorted ( although weak )
    you may need to extract the other pair connected to it .
    • If you have Multimeter , insure also that the Offset voltage should not be over 0.7V
    ( output of that amp ) before applying the new replacements.
  • Chris Davis
    The numbers are A1633, and C4278. And also the resistor is blown and I cant see the color codes.
  • Rommel Cana
    • If the transistor is marked with ( sample only ) C5200
    it means it is 2SC5200
    • If the transistor is marked with A1943
    it means it is 2SA1943
  • Chris Davis
    on the chanel without transistors there is no sound at all
  • Rommel Cana
    If the resistor is connected to the " Emitter " ( rightmost pin of the transistor ) it is safe to use
    0.33 ohms 5 watts as replacement.
    If it is connected on the leftmost pin , then you can measure the value it is still in there although
    burnt. and post
  • Rommel Cana
    just like i said before , it is a pair , ( two in each channel )
    Each ( NPN ) has a drive before it goes to your speaker ,
    same with the PNP it is in a Darling ton Configuration.
    • Check the component ( transistor again ) that is connected on the base of that NPN transistor
    same with the PNP transistor , or have it removed too.
    It is also a pair like the one you have extracted and post , it could be connected to the
    resistor that have burnt.
    Base means leftmost pin of the power transistor
  • Rommel Cana
    • It will also be marked with C X X X X and A X X X X only smaller than the power transistor you have
    extracted a while ago , and post
  • Rommel Cana
    • there will also be a single little transistor , that is connected on that Drive , connected on the
    base of that pair , it should also be needing to be replaced.
    it starts with C X X X X or other part number another NPN type small signal transistor
  • Chris Davis
    yes the resistor is on the base side.
  • Rommel Cana
    Here is the transistor you need to look
  • Rommel Cana
    the resistor value is 4.7 ohms 1/4 watt
    Have you found the small transistor?
  • Rommel Cana
    the collector of that transistor is connected to the burnt resistor .
    • Collector could be center pin of the transistor if the part number starts with C or D
    like D947 which is equivalent to 2SD947F
  • Chris Davis
    Sorry I have to go to work. thanks for the help i will try back later when I get off thanks again
  • Rommel Cana
    Here are other things to check :
    If these are not checked properly , you might end up , same all over again
  • Rommel Cana
  • Rommel Cana
  • Rommel Cana
    Rommel Cana Aug 25, 2010
  • Rommel Cana
    • that small transistor is connected to the trimmer resistor ( blue arrow )
    See the schematics above for schematics , you need to find these one .
    Before putting back a new pair of Darlington Power Transistors.
    • These transistor is the life of your pair, if these is not checked
    you might not like what will happen later.and post
  • Rommel Cana
    On the trimmer resistor , On One end
    • A resistor is connected that goes to the Collector side of the transistor you need to look,
    On the other end also a resistor that goes to the emitter of that transistor.
    these transistor should also be needed to be replaced with a new one.
    • Do not forget to check the resistors too , before putting back a new small transistor.
My Emerson flat screen wont turn on. The standby light is on and when you turn it on the green light blinks about 6 times goes solid for a second then straight to standby again. Every 20 times or so you...
The 6 blinks are actually a error code. Go to the Emerson web site you should be able to look the code up there. Its more than likely a bad power supply. I have a friend who works on tvs and he said nine times out of ten there are popped or raised capacitors in the power supply. Hope this helps.
Jun 16, 2014 | Televison & Video
More detail --- Toshiba md20q42 tv/dvd combo not powering on, initially when it happened i Hit power button and lite came on and blinks for about 3 seconds then turns off--- now when i push power button...
Hi
It is probably a power supply problem associated with standby circuit. If this circuit is bad the set hardly comes on and fails. This is a task for a technician to trace the fault through the whole power supply.
Sully
Sep 22, 2013 | Toshiba MD20Q42 20" TV/DVD Combo
Sony Triniton TV KV 32FS120 will not turn on
In standby mode (red led on/after the led stops from blinking), press "Display", "5", Volume (-)", "Power on" on the remote control in sequence, self diagnostic screen will be display, let me know the what is on the screen to diagnose where the fault came from.
Nov 25, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My motorola h700 wont pair to my htc hero.when i hold the button down on the bluetooth, it lights up blue for 5 seconds then the light goes out
go into settings, look for wireless controls or bluetooth, should ask you to pair with the name of your bluetooth if it wont, turn off the bluetooth in the phone and turn off the bluetooth itself by holding down the button for about 6 secs till the light blinks a few times then goes out. turn the bluetooth function on on the phone FIRST, wait till it says its on, then turn on the bluetooth itself by holding the button down until the light blinks a few times then you get a solid light, it wont stay solid, it will blink a few times then go out blinking from time to time. go back to your phone and find the bluetooth menu and it should ask you if you want to pair, hit yes or whatever option you have and it should start pairing and then connect or you may have to hit the connect option if you have one they dont all connect automatically sometimes so you have to go through all this when you charge the bluetooth or turn it off. good luck.
Dec 14, 2010 | Cell Phones
Hello. My Nec LT35 projector will not turn on. From standby mode, I hit the power button, the power LED turns green, the fan starts, but after two seconds it switches back to standby. The...
i have the exact same error with same projector. did you manage to solve this?
my status led blinked red 6 times indicating a "lamp error" which wasn't helpful. i also tried removing and replacing lamp but didn't work.
Dec 01, 2010 | NEC LT35 Multimedia Projector
When I turn on my Canon iP3000 printer the power light blinks five orange and one green light and continues to to so. It will not stay solid green.
Hello try
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Nov 02, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Blinking standby light and nothing else...
When Sony TVs detect a problem, they shutdown and present a blink code. The blinking should be a repeated count. Please report that count here as that indicates the circuit in which the problem was detected.
Thanks,
Dan
May 20, 2008 | Sony KP-46V35 TV
693 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
