Question about RIM BlackBerry Pearl 8100
My blackberry isnt accepting my media card - RIM BlackBerry Pearl 8100
    Brigadier General:
  • 5,158 Answers
I had trouble with mine. i put a 2 gig card it. it should accept it but to actually access it you need the stand alone roxio media manager which you should be able to get right from the blackberry site. it's the only way i could access it with my computer. you also need to go into your options... settings should be ON , NONE, ON and YES.
Posted on Aug 24, 2010
My blackberry 9900 won't read media card
Will it read any card? if it will read another card just not "yours" or the one you want it to read then the card is either faulty, needs to be reformatted, or is a too high capacity for your phone.(some phones wont accept high capacity memory cards) How ever if your phone will not read any card it means you phone memory card reader is faulty or has poor or non existence connection to the proper points on the phone circuit board- in that event if it will not matter what the cause may be, you cant fix it- take it for repair--Good Luck.
Jan 27, 2013 | RIM BlackBerry Bold 9900 Cell Phone
How do I transfer pictures from my blackberry device to the media card?
It's recommended to buy a microSD card to store your media files on, so you don't run out of memory on your device.
Depending on what OS your BlackBerry is tells you what size microSD card you can buy. You can check under Options ' About (will be listed as v4.xx.xxx). Look at the chart at the following link to see what size you can obtain -http://www.blackberry.com/btsc/KB05461
On the BlackBerry go into Options ' Media Card. Recommended media settings are as follows:
Media Card support : ON
Encryption Mode : NONE
Mass Storage Support : ON
Auto Enable Mass Storage Mode When Connected : YES
Mass Storage mode allows your BlackBerry to act as an extra drive when connected to your PC. So it will show up as an extra drive letter in Windows Explorer. So you can just drag/drop media files onto your media card and vice versa.
Or if you use ITunes, you can you the Media Sync to synchronize with the device. Read up about that here:http://na.blackberry.com/eng/devices/features/media/mediasync.jsp#tab_tab_overview
Oct 10, 2010 | RIM BlackBerry? Curve 8330 Cellular Phone
Can't see files located on the 4gb micro sd hc memory card on my Blackberry 8100 Pearl. Path:Media/Music/Media Card - the folder comes up blank. Any ideas?
your card may not work with the blackberry. try formatting the card via it ebeing in the blackberry, and then put everything back on the card afterwards. it should work. if not again, your card might just not be compatible wit the phone
Feb 17, 2010 | RIM BlackBerry Pearl 8100
My Blackberry Curve 8330 won't format a media car
From the Home screen of the BlackBerry smartphone, click Options > Media Card or Options > Advanced Options > Media Card.
Display the menu and click Format Card.
  • some times Format Card option does not appear on the menu, skip the step and perform the procedure that follows.
  • A warning message will appear asking if you are certain you would like to format the card. Click Yes to continue.
    If the Format Card option does not appear on the menu, complete the following steps:
  • On the Media Card screen, set the Mass Storage Mode Support field to Off.
  • Display the menu and click Save. The Media Card screen closes automatically.
  • Click Media Card to reopen the Media Card screen.
    To format the media card, display the menu and click Format Card.
Nov 03, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Cannot play Blackberry 9000 mp3 files on Bluetooth devise
Complete the following steps:
1) Use a search engine or a dedicated download site to find and download a third-party conversion tool. The tool must have the ability to convert the format of the audio or video file to a file format that the Media application can read.
2) Install the third-party conversion tool and follow the program instructions to convert the audio or video file to a format that the Media application supports. Refer to the following tables for optimal settings in the Media application.
Optimal settings for the Media application on the BlackBerry 9000 series smartphones:-
For video setting's
a) Video format: MPEG-4.
b) Video file extension: .avi
c) Resolution (4:3): 240x180
d) Resolution (16:9): 320x180
e) Video bitrate: 400 Kbps
f) Frames per second: 24
For Audio settings:-
a) Audio format: MP3
b) Audio bitrate: 128 Kbps
c) Sample rate: 44 kHz
d) Channels: 2 (Stereo)
Transfer the audio or video file from the computer to the BlackBerry smartphone using one of the following methods:-
1) Using BlackBerry Desktop Manager.
Note: BlackBerry Desktop Manager 4.2 must be installed on the computer.
  1. In BlackBerry Desktop Manager, open BlackBerry Media Manager.
  2. Use the Media Manager tool to transfer the audio or video file to the BlackBerry smartphone using a USB connection.
  3. Copy the files to the appropriate folder (either \blackberry\Music or \blackberry\Video) on the media card, or directly to the internal BlackBerry smartphone memory.
Note: Files larger than 3 MB cannot be transferred to internal BlackBerry smartphone memory.
2) Using the BlackBerry smartphone as a USB mass storage device:-
  1. On the BlackBerry smartphone, go to Options > Advanced Options > Media Card.
  2. Make sure that Mass Storage Mode Support is set to Enabled.
  3. Connect the BlackBerry smartphone to the computer and follow the prompts on the BlackBerry smartphone.
  4. Open the My Computer folder on the computer. The media card should appear there as a Removable Disk.
  5. Copy the files to the appropriate folder (either \blackberry\Music or \blackberry\Video) on the media card.
Using a media card reader
  1. Make sure that the media card reader is connected to the computer.
  2. Insert a media card into the media card reader.
  3. Open the My Computer folder on the computer. The media card should appear there as a Removable Disk.
  4. Copy the files to the appropriate folder (either \blackberry\Music or \blackberry\Video) on the media card.
  5. Insert the media card into the BlackBerry smartphone.
Oct 24, 2009 | RIM BlackBerry Bold 9000 Smartphone
Can't find hidden media folders
Follow these steps to hide or show pictures on the BlackBerry smartphone:
  1. On the Home screen of the BlackBerry smartphone, click Media.
  2. Go to Pictures.
  3. Open the picture that you want to hide.
  4. Press the Menu key and click Properties.
  5. Select the Hidden check box and click Close.
Follow these steps to show a picture on the BlackBerry smartphone:
  1. Click Media.
  2. Press the Menu key and click Explore.
If the picture is in Device Memory,
  1. Click Device Memory.
  2. Press the Menu key and click Show Hidden.
If the picture is in Media Card,
  1. Click Media Card.
  2. Click BlackBerry.
  3. Press the Menu key and click Show hidden.
Additional Information If the computer is set to Show all hidden files and folders, the BlackBerry smartphone user should be able to view all hidden pictures by using Roxio® Media Manager. However, pictures cannot be hidden or shown using Roxio Media Manager. If a picture is on a media card and the computer is set to Show all files and folders, pictures can be viewed, hidden and shown by using the removable disk drive.
Sep 12, 2009 | RIM BlackBerry Pearl 8100
When i put my media card in my blackberry it says its not there?
back up first all of your files.then format your media card using your Blackberry,not your PC.If it is still same problem after formatting,try to replace another media card and check if other media is working in your phone.lastly,if still not working its already a hardware problem,its a memory card IC,not working anymore,you must replace it.
Jul 22, 2009 | RIM BlackBerry Pearl 8100
Can send mp3 from laptop to blackberry 8310
go to your menu and then to media then to music hit the menu button select recieve using bluetooth then have pc connect to blackberry
Apr 23, 2009 | RIM BlackBerry Curve 8310 Smartphone
Problem in unlocking iPhone 2G
BOX, PSP, PS2,PS3, IPOD, IPHONE, IMATE, 02, Blackberry, HTC, Palm, HP, Repairs n service HI WE REPAIR ALL OUT OF WARRANTY APPLE IPODS,IPHONES, AND APPLE LAPTOPS PLEASE CONTACT US AT JULIAN JOHN : 9810124668 ZION TECHNOLOGIES 245a,sant nagar,first floor, East Of Kailash New Delhi 65 (since 1997) 41620696//26435057/58//9810124668/41620840/
Jan 08, 2009 | Apple iPod nano
My blackberry media card
Try opening your options menu and select "media card". Make sure media card support is turned on.
-Neil
Oct 24, 2008 | RIM BlackBerry Pearl 8100
RIM BlackBerry  Pearl  8100 Logo
44 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
Andrew Wright
Trisha
Trisha
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
