Question about Kodak EasyShare One Digital Camera
Camera is holding the pictures and won't transfer them to the new card I inserted. How do I get it to do this?
    Brigadier General:
  • 11,967 Answers
In the menu, there should be an entry for "copy" which will give you the option to copy the internal memory to a memory card.
Posted on Aug 24, 2010
How to transfer internal memory pictures on a DSCW70
Unlike most brands/ models of cameras, the Sony CyberShot (DSC) cameras feature internal memories, (not enough to hold sufficient data). If you took a few shots before inserting the memory card, the pictures are stored in the internal memory. You can transfer/ delete those pictures by the following steps.
1. switch off the camera,
2 open the battery/ SD card slot cover and remove the SD card.
3. close the cover and switch on
4. press the display/ preview button and your picture should be visible on the screen.
You can now do whatever you want with your picture.
Does this help? Please provide some feed-back if my answers do help.
Sep 09, 2014 | Sony Cyber-shot DSC-W70 Digital Camera
Easyshare Z5120 won't transfer pictures to computer
The best way to transfer pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa.
Organize edit and share your photos
Mar 10, 2013 | Kodak Cameras
Pictures show up on memory card in camera, but computer won't recognize the card - either inserted directly or by USB
ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER
If your photos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
Aug 11, 2012 | Nikon D40 Digital Camera with 18-135mm...
I am having a problem transfering pictures from my Kodak EasyShare C1013 camera to the computer.........any suggestions, it will transfer a few but not all the pictures. Thank You
The easiest and fastest way to transfer pictures/videos from your camera is by removing the SD card from your camera and insert it into a SD card reader. You can buy card readers at any computer stores at cheap prices. You insert the SD card into a card reader and then you insert the card reader into a free USB slot on your computer and then you can copy ALL your files then wherever you want.
Thanks for using Fixya!
Jun 17, 2011 | Kodak Cameras
When I attempt to take a picture I receive this message on the screen: Memory Full Insert a memory card to transfer and take more photos. I have a memory card already inserted into the camara, and...
The camera only holds one picture, and that only until you turn the power off. To take and store pictures, you need a memory card. The 8025 uses SD and SDHC cards up to 8GB in size. These cards are available at just about any department, electronics, and office-supply stores.
Aug 07, 2010 | Vivitar ViviCam 8025 Digital Camera
When transfering pictures from camera to PC EasyShare will not transfer some pictures. "picture already exists" in My Collection. These are all new pictures taken with blank memory card. This occurs even...
Scrap the camera! Kodak hasn't and won't address the problem. Most picture download software won't recognize the camera. The only solution is to remove the memory card from the camera, put it in USB adapter and treat it like a flash drive. Cumbersome. Awkward. Stupid. After you scrap the ****, tell your friends so they don't make the mistake of buying a Kodak.
Dec 26, 2009 | Kodak EASYSHARE M1063 Digital Camera
Cannot transfer pictures from camera to computer
Try formatting the memory card before inserting it into the slot. also try using the memory card that you were using before you got all these problems
Jan 09, 2009 | Nikon Coolpix S210 Digital Camera
I want to replace the memory card cover for a Kodak cx7350. I need the instructions
Might this help? It is for another model but would closely resemble CX7350 removal procedures.
The above photos originally appeared here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 10, 2008 | Cameras
I have a Kodak Easyshare C530 how do I transfer pictures from computer to camera?
hey, yes you can transfer pictures from the computer to your camera...you take the memory card from your camera and insert it in your computer (if you do not have the slot to insert the memory card you cannot transfer pictures) thn sync pictures to the memory card and then insert memory card back into camera.
Jul 19, 2008 | Kodak EasyShare C315 Digital Camera
Kodak EasyShare One Digital Camera Logo
16 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
