Question about Kenmore 73952 Gas Dryer
Still running fine but did not dry clothes. thanks alot.
  • Kenmore Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Posted on Sep 12, 2010
DOES'NT GET HOT ENOUH TO DRY MY CLOITHES
Always clean filters, if your hose goes up, check for stopped up vent hose (in the attic, happens alot in apts. ). If you have a neighbor behind you who is attached to the same vent going out and you leave your clothes in the dryer and they are dry. His dryer running will make your clothes damp. Have had all of these problems.
Jun 06, 2012 | Maytag Dryers
My dryer doesn't completely dry my clothes. Usually I have to run almost 2 cycles to get my clothes dry.
check your vents,, inside the house and outside,, check to make sure the vent hose is not kinked,, if all is good make sure the unit is blowing out air good, if so then you may have a thermostat or heating element going out,,, i have seen alot of vents on the outside get wet and clog up
Jan 22, 2011 | Kenmore 98702 Stacked Washer/Dryer
My dryer DLE 2514W does not dry the clothes enought, we have to put it on for a second time to get them all dry. Seems to be alot of heat but doesnt dry the clothes
disconnect vent hose and run a load of clothes, if they are dry then the vent hose is restricted/clogged. if for some reason it is doing the same then take dryer apart and clean from lint screen back, I am almost certain that it is the vent tube.
Dec 23, 2010 | LG DLE2514 Electric Dryer
I have a dryer # 67832791 and doesn't seem like it heats up and takes longer to dry the clothes. Seems to run fine and operate fine just not drying the clothes.
restriction in the venting, disconnect vent tube, leave disconnected dry clothes and if they dry then clean out vent tube(vacuum, leaf blower, etc). Hope this helped Tim
Nov 28, 2010 | Kenmore Dryers
My dryer runs but does not heat up or dry clothes. What could be the problem?
I have a Kenmore dryer and it runs but won't heat up and dry the clothes. I don't hear the ignition even turn over. Please help. I can't afford to buy a new dryer at this time.
Feb 16, 2010 | Kenmore 62602 Electric Dryer
LG dryer (model DLE3733W) takes forever to dry the clothes.
check your vent hose for a clog. If dryer dont vent clothes wont dry.
Aug 25, 2009 | LG DLE3733 Electric Dryer
DV448AEP sensor drying doesn't seem to work
I had the same problem with mine. My wrinkle free setting some how got turned off. As soon as I turned that back on machine kept running and dried the clothes fine.
Feb 19, 2009 | Samsung DV448AEE Electric Dryer
Maytag electric dryer model mde308dayw not heeting up
CHECK YOUR WALL VENT AND DRYER VENT AND MAKE SURE THEY ARE CLEAR,ALOT OF THE TIME IF BLOCK THEY HOLD THE DAMP HOT AIR IN THE DRYER AND WILL TAKE FOREVER TO DRY,IF NOT THAT IT CAN ONLY BE YOUR HEATER BOX OR HEATER BOX FUSE,IF YOU HAVE A METER YOU CAN CHECK BOTH,LET ME KNOW-MIKE
Dec 06, 2008 | Dryers
Dryer seems to work, but clothes end up damp?
Corwyn, looks like the problem you are having is not with the dryer. The vent line is probably clogged up, which caused the moisture to stay inside the dryer. To make sure this is a vent problem, you can disconnect the vent hose behind the dryer and run it for one load with it disconnected. If it runs fine, then the vent line needs cleaning. Usually it needs special equipment and is very hard to do yourself. It would cost you around $90 to get a professional out to do it for you. Gendos....post back.
Dec 19, 2006 | Whirlpool LER6636PW Electric Dryer
Kenmore 73952 Gas Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
