Question about Whirlpool Cabrio WTW6600SBK
Whirlpool cabrio wtw6600sw2 has error f54. what does it mean and what can I do to fix it?
  • 530 Answers
You can locat the tech sheet by lifting the lid
you will see a **** that goes all the way around the washer
to the very left and right corners in the front about 4-5 inches you will find 2 clips
push in on the clip and pull up
do both sides it is sort of tricky
maybe have someone help you one person to hold the lid so it does not spring back and break
you will find the tech sheet to the left inside a plastic shething
Posted on Aug 24, 2010
2 Suggested Answers
57 varieties
  • 1653 Answers
SOURCE: F54 error code
The F54 code is a motor control overcurrent error. If you keep seeing this error then you ned to callin a service man to have the system looked at.
Posted on Oct 02, 2009
Whirlpool WTW6600SW2 Cabrio Washer.
These codes are not usually manually erased, they are overwritten as explained in the service book. Only the last so many codes are stored, beyond that they drop off. Pleazer Appliance...
May 20, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
F54 code after repair
Okay F54 is a motor over current doubt if bearing was original problem this a rotor stator setup you should get a little resistance with the motor installed since the rotor has magnets, this code can drive you nuts there could be a crack in the rotor magnets are they rusty did the original seal leak,check the stator resistance on the control board ohm out the 3 wires on terminal P5 1 to 3, 2 to 3 you should get 31 ohms +/- 5 to get into diagnostic make sure machine is off use any button except power, start,stop, pause/cancel press and hold for 3 seconds, release for 3 seconds do this till 88 displays press the same button within 5 seconds of 88 should hear a beep you are now in manual diagnostic slowly rotate the basket the wash, rinse and spin light should flash as you rotate if all of the checks are good you have either a bad rotor or a bad control hopes this helps.
Jan 29, 2014 | Whirlpool Washing Machines
Need to know what the error codes mean on a whirlpool cabrio model wtw6400sw3 F54,F82,F83,F84. Please help.
you may have something between the tubs or your bearing is going bad . does it sound like a jet plane in spin cycle?
Feb 20, 2013 | Whirlpool Washing Machines
F1 signal what is the meaning
Pressure Signal Out-of-Range
F then 1 flashes when the control detects an out of range pressure signal.
* Check pressure hose connection from tub to machine/motor control. Is hose pinched or kinked?
* If F then 1 repeats numerous times after POWER is pressed and the pressure hose connection is not pinched or kinked, replace the machine/motor control.
Whirlpool Cabrio F1 error code - NOW A RECALL ISSUE! model # WTW6600SW2 Call Whirlpool or a repair center. The number for Whiripool is 1-800-253-1301
Hope helps.
Jul 12, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
What does F1 error mean?
Nov 28, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
I am alway getting the f1 code
  • I called Whirlpool 1-800-253-1301 today 10/15/08 and they said the F1 issue is now under a recall!
Nov 27, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
F54 error code
Sep 28, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBK Logo
622 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
