Question about Sanyo PLV-Z2 Multimedia Projector
Lamp mode swtiches to full power in the middle of dvd play
After a few hours of dvd play, the projector lamp switches to full power. I can switch it back down with the lamp mode remote button, but it switches back to full power again after several minutes. I have tried switching the mode via the menu, but the same problem occurs. The lamp goes to full power and the fan gets louder too. It is disrupting our movie experience!
Our movie room is tiny. Do you think the projector is becoming overheated?
  • Barb99 May 10, 2008
    Hi Marrie
    Thanks for your feedback- I'll take it in. That is, I'll take your advice into my head, and take the projector into a service center. :)
  • 563 Answers
Hi Barb99
This could unfortunately be either the fan baord or the Mainboard that has gone faulty.
You will have to get this checked out by a Service Centre as this is one of those problems that need hands on to give you the right diagnosis.
Posted on May 06, 2008
My HD80 has about 700 hours, original bulb assembly, was working fine until I got curious and "activated" the auto off function while going through the menu. Now it will power up, lamp does not go to
Ensure a video source is connected to the projector (VGA, DVD, etc)
Unplug the projector to make sure it has completely shut down (not just went into sleep mode)
Plug in power and power on the projector (make sure video source is on first)
The projector should turn on and switch to the video source (manually select if not)
Once you can see the video source, push menu and turn off auto-off.
Auto-off should only work when the projector detect a video source is no longer present on the selected input. So if you are turning on the projector with no video source connected, it will usually turn off shortly after being turned on.
Nov 30, 2014 | Optoma HD80 Projector
My NEC VT650 runs for about 15 mins then intensity of picture starts to reduce then comes back to full brilliance and does so for a few seconds and then the lamp switches off. Fan stays running. If I...
It could be the wrong lamp. Make sure that the lamp is original factory made. It may also be the lamp ballast which starts the lamp & keeps it burning steady.
Good luck,
Apr 15, 2011 | NEC VT650 OWIZ136606624901
How can i reset de lamp time
With the projector running hold the right cursor key, down cursor and the enter button down switch the mains power off.
Still holding these buttons down power the projector back on. it will take a few secounds for the lamp to light up.
When it does you should see lamp hours 0000
Hope this helps
Mar 23, 2011 | Sharp PG-A20X LCD Projector
Why does the projector keep going to standby mode?
If the lamp usage time has passed 2 000 hours (when LAMP POWER has been set to NORMAL), the projector will switch to standby mode after approximately 10 minutes of operation. The resetting procedure should thus be completed within 10 minutes.
1. Insert the power cord plug into the wall outlet and then
press the MAIN POWER switch.
2. Press the POWER button so that a picture is projected onto
the screen.
3. Press the MENU button to display the menu screen, and
then press the F or G button to select the OPTION menu.
4. Press the ENTER button, and then press the F or G button
to select LAMP RUNTIME.
5. Press and hold the ENTER button for approximately
3 seconds. The confirmation screen, "LAMP RUNTIME
RESET." is displayed and select OK.
6. Turn off the power.
This will reset the cumulative usage time for the lamp
unit to zero.
Mar 12, 2011 | Panasonic PT-AX100U-EC DLP Projector
Lamp goes out after a few minutes
my 3m projector switches off in 15 seconds indicating the lamp indicator, as the lamp has not been used enough
Mar 25, 2010 | Optoma HD80 Projector
Cannot Reset Infocus LP 350 Projector after replacing a bad lamp
that model has a history of bad ballasts. you'll need to replace it.
Mar 03, 2010 | InFocus LP350 Multimedia Projector
Flashing red light
sounds like a flaky power supply or lamp ballast
Jun 01, 2008 | Radio Shack Cinego D-1000 Multimedia...
The projector displays pink or red not full color
Hi GiantBryan
If switching the cables did not work , then this is a faulty Mainboard that will need either repair or replacement as discolouration on a Projector could only be the cables or the Mainboard.
May 12, 2008 | Epson (DHV13H010L18) Projector Lamp for...
Iamge from the previous projection from RGB still appears when i switch to Video mode. why is it?
Hi There
Looks like your Projector's Mainboard has locked the memory and is stuck.
If you can access the Projector's Menu - Reset the machine and switch it off.
If the problem still occurs , you will have to take your Projector to a Service Centre to have to Mainboard repaired.
This is 100% NOT a lamp issue.
Apr 18, 2008 | Hitachi (DT00431) Projector Lamp for...
Reset Lamp Hours Timer
This works on a couple different Toshiba models -- might work on yours...
Make sure the main power switch is OFF. Hold the "ON", "MENU", and "INPUT" buttons at the same time and turn the main power switch on. Keep them held until the yellow power standby light comes on, then let go. It is done.
Oct 13, 2007 | Toshiba TLP S30 Multimedia Projector
Sanyo PLV-Z2 Multimedia Projector Logo
85 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
