Question about Apple 15" PowerBook G4 Aluminum 1.67 GHz LCD Display (p/n 1002587) (661-3749 1002587) Mac Notebook
Mac laptop altitude problems - Apple 15" PowerBook G4 Aluminum 1.67 GHz LCD Display (p/n 1002587) (661-3749 1002587) Mac Notebook
  • Chris Edwards
    Chris Edwards Aug 24, 2010
    please descibe the poblem.
  • Bar1no Aug 24, 2010
    What problems are you having?????
  • 863 Answers
Take it out of the high altitude.
Posted on Oct 11, 2010
Hi all im using Canon SX260 HS which have gps and altitude feature. Im having problem where the altitude reading is not accurate. Any idea why is this happening or anything i can do to make it right. Using...
I think this has to do with the limitations of the GPS device build in your Canon. The device is not build to fly in a plane. You are moving to fast. I'm convinced if you are on a mountain the device will have no problem displaying the correct altitude. And when in a plane, the small antenna inside will have trouble finding good signals. Look what the Canon does, while you are still on the ground. See if it finds enough satellites in a short time. Check if the airplanes body works as a shield.
May 13, 2014 | GPS
Need an emissions schamatic for my 1984 K10 silverado 305 engine
Unfortunately, there are 13 variations for this engine and year. Was this truck sold or modified for high altitude? Was it sold in California or modified to meet the CA emission standards? Does it have a manual or auto transmission? After narrowing down based on answers to these questions, there are still alternative configurations depending on the particular equipment, so look carefully at the diagrams to see which components are used on your engine. Sometimes you can match the 3 letter code for the diagram to letters in the VIN or a sticker in the engine compartment. Please let me know if you have questions.
Fig. Fig. 49: 1984 305 (5.0L) V8 engine-4bbl federal and low altitude with automatic transmission
Fig. Fig. 50: 1984 305 (5.0L) V8 engine-4bbl federal and low altitude with automatic transmission alternate
Fig. Fig. 51: 1984 305 (5.0L) V8 engine-4bbl federal and high altitude with automatic transmission
Fig. Fig. 52: 1984 305 (5.0L) V8 engine-4bbl federal and high altitude with automatic transmission alternate
Fig. Fig. 53: 1984 305 (5.0L) V8 engine-4bbl federal and high altitude with manual transmission
Fig. Fig. 54: 1984 305 (5.0L) V8 engine-4bbl federal and high altitude with manual transmission alternate
Fig. Fig. 55: 1984 305 (5.0L) V8 engine-4bbl federal and low altitude with manual transmission
Fig. Fig. 56: 1984 305 (5.0L) V8 engine-4bbl federal and low altitude with manual transmission alternate
Fig. Fig. 57: 1984 305 (5.0L) V8 engine-4bbl federal and low altitude with manual transmission alternate
Fig. Fig. 58: 1984 305 (5.0L) V8 engine-4bbl federal and low altitude with automatic transmission alternate
Fig. Fig. 59: 1984 305 (5.0L) V8 engine-4bbl federal and high altitude with automatic transmission alternate
Fig. Fig. 60: 1984 305 (5.0L) V8 engine-4bbl federal and low altitude with automatic transmission alternate
Fig. Fig. 61: 1984 305 (5.0L) V8 engine-4bbl federal and high altitude with automatic transmission alternate
Oct 27, 2011 | Cars & Trucks
My Optoma HD 72 flashes green like others have descibed, but if I run it in High Altitude mode it corercts the problem, although it it very noisey. Any ideas to what is causing this issue and how to fix...
sounds like the air flow is restricted and overheats using the regular fan speed.
check for air flow blockages inside and outside, filter problems, etc
Mar 13, 2011 | Optoma HD72 Multimedia Projector
I can do the same ride with the unit on different bikes and get a variation in total ascent by as much as 200 feet
When starting your device, it acquires sttaelites progressively, then the altitude accuracy is not good at the beginning, so starting altitude and final altitude are not identical if you ride a loop.
Other possible cause is that the cumulation of small errors makes cumulative altitude to vary.
Garmin connect offers a feature that corrects the altitude by smoothing the waypoints, and also by using topology points.
Go to http://connect.garmin.com/
Then upload your data from your garmin device to the garmin connect database, and use the feature named "altitude correction" bottom left of the screen where your ride is detailed
Aug 27, 2010 | Garmin Edge 305 GPS Receiver
Physics
I think you should do your own homework... :)
Oct 01, 2008 | Acer Aspire 5315 Notebook
Waypoint altitude
When asked for the altitude, enter it as 1.
Jun 11, 2008 | Lowrance LCX-19C GPS Receiver
Optoma EP739 Projector Overheating
Set the projector to "high altitude mode." It will be noisier, but won't overheat. I wonder whether using one of those $10-$20 laptop coolers underneath it might be a quieter solution.
Mar 09, 2008 | Cameras
Adjusting meteo function
Yes, Sir. But remember when pilots reset their altimeter with the local altitude, the pressure value matches the moment wheather pressure. It will be wrong anyway, if you reset you altitude, but the pressure readings are still wrong. Im my case it is happening. The altutide is correct but the pressure of the watch does not match the local pressure. It is 20 hpa over it. By the way, I am an airline pilot.
Mar 05, 2008 | Tissot T-Touch T33759851
Humming noise
Most times a humming noise in a Plasma tv is associated with high altitude. If you live over 3500 ft. and when you first turn on the unit is has a slight buzz and it gets worse as it warms up then you have what is referred to as high altitude sickness. You shoul contact the manufacture with this problem and the should exchange the unit with one tested for proper operation at high altitude. If you do not live at high altitude then there is a problem in the unit that should be diagnosed.
Dec 18, 2007 | LG 50PX5D 50 in. Plasma HDTV
Incorrect altitude changes
Here is the link to the user manual for this watch if you need it; http://www.lacrossetechnology.com/k2100/manual.pdf page 12 gives you all the contact details for lacrosse. I couldnt find the info online to be sure, but some of these watches do have a separate pressure sensor for altitude and barometric pressure, and sometimes the path to one could get blocked or it could become faulty. I would contact la crosse and find a dealer to get the watch serviced, you could probably do it yourself but you need to get replacement seals from them anyway (these are important). ask them to check if the sensor is clogged, it happens sometimes. Hope this helps :)
Jun 18, 2006 | La Crosse K2-100 Wrist Watch
Apple 15" PowerBook G4 Aluminum 1.67 GHz LCD Display (p/n 1002587) (661-3749 1002587) Mac Notebook Logo
59 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
