Question about Vacuums
I'm looking for a manual for a Hawaiian Breeze 42'' hugger ceiling fan
2 Suggested Answers
  • 436 Answers
SOURCE: how to assemble the hawaiian
I cannot find exact instructions but I did find a general guide to assembly. they are usually very easy to assemble.
A standing fan is a portable fan that has a set of three oscillating blades on a long neck. The neck, also called the pole or the leg, is mounted on the floor. Standing fans have evolved from their origins as noisy accessories that blew away papers in their vicinity to silent fans whose direction can be controlled remotely. When placed at a convenient location, a standing fan can distribute air evenly to the entire room. Its speed can be controlled, and many standing fans can be programmed to stop at a set time.
  1. Installation Requirements
    • The only requirement for installing a standing fan is making sure it is near a power source. The entire unit can be assembled manually with only a screwdriver. A single standing fan, either an oscillating or pedestal fan, is very simple to assemble for basic home use.
    Pole and Base
    • The first step is to lay the parts on a floor. Then assemble the pole on the base of the stand. This is very simple, because the grooves for the screws are already drilled, so the screws just need to be inserted and screwed in. Screwing the pole into the base of the fan is required on some models; on others, the pole and the base are molded together and no screws are needed.
    Motor and Fan Installation
    • One some fans, you have to install the motor and oscillating arm to the pole. This again is done by screwing screws into predrilled holes. Grooves for long screws are at the top end of the pole, where they attach to the motor of the fan. Once the motor is placed on the top of the pole, insert the screws in the predrilled holes and tighten the screws. The next step is to wire the three blades. This is done by taking the wires from the motor and joining them to the sockets in the pole. This finishes the assembly procedure.
      To turn the fan on, ensure that the wires fit securely together. A loose connection cannot not only hamper the performance of the fan, it can also lead to problems such as electrical shocks or burning wires.
I hope this helps
good luck
Please rate FIXYA
Posted on Apr 07, 2011
I have a victorian casablanca fan serial # JU13396 - 20041. A couple days ago the light fixture assembly fell off the fan and crashed to the floor. Evidently there is a type of clip that fits under the...
this clips are common for most of the ceiling fans with light fixtures.You will get this clip from local ceiling fan repair shop or from radioshack, homedepot or from walmart store.There is exactly not a part number but this pins are called ceiling fan clips. -------- if incase you dont get required clip or any substitute clip for fixing.Then you can get it from dealer.Click this link below to directly contact dealer:--- http://www.casablanca-ceilingfan.com/customerservice.html ----------- Also there is one more part site for casablanca fan parts:--- http://www.fanmanlighting.com/shop/pc/viewCategories.asp?pageStyle=h&ProdSort=19&page=1&idCategory=42 ------------ This should help.Thanks.Helpmech.
Jul 12, 2011 | Vacuums
How to assemble the hawaiian breeze oscillating floor fan
    Pole and Base
I hope this helps
good luck
Please rate FIXYA
Apr 07, 2011 | Vacuums
Hi. I have misplaced the remote for my Aloha Breeze ceiling fan. How can I get a replacement?
Look on this site http://www.searspartsdirect.com/partsdirect/brands-products/Aloha-housewares-Inc-Parts/Fan-Parts;jsessionid=EhpYk2SBMad9Blbgl+MKrg**.pdapp401p2 to see if they have the model number and part. You'll probably find that the replacement part costs near as much as the whole thing did tho.
Mar 22, 2011 | Vacuums
Need white translucent globe for Harbor Breeze Ceiling Fan to cover light. Globe fits to fan base with 6-1/4" Inside diameter mounting ring and is secured with three thumb screws.
I believe Harbor Breeze is sold through the Home Depot. Any well stocked Home Improvement store will carry a great selection of replacement globes for your light.
Mar 07, 2011 | Vacuums
My hunter ceiling fan is not working and according to hunter technical support, I need to replace the remote control receiver (part # 8511204000) at a cost of 50.00 plus shipping.is there a way to by-pass...
If the product did not come with a manual control on it then yes you will have to use the remote. However, if the replacement remote will cost nearly as much as the ceiling fan itself you could simply purchase a new fan.
Feb 28, 2011 | Vacuums
I have a model 484 709 UPC 792145330547 The fan/light is close to ceiling (instalation). Their is supposed to be an "o" ring to remove the fan/light from the celling. I cannot find it!!! ...
Remove the cowl at the ceiling by removing the screws in the cowl (very close to the ceiling). Use caution in removing them as the weight of the fan may be carried by these screws. Depending on the style, though, the weight may be borne by supports beneath the cowl. Either way, this will get you access to the wiring, allowing you to change out/remove the fan. If the fan and cowl are together, and close to the ceiling, there is usually a method of hanging the assembly while the wiring connections are made during installation. Look for a hook that the screw hole will go over, supporting the fan.
Best regards,
--W/D--
Jan 19, 2011 | Vacuums
I bought a ceiling fan from lowe's, got it home got ceiling fan up in the bathroom, when we put in the light one of the halogen bulbs does not work , also two of the cobalt blue glass covers are cracked...
If this is a new product and it is defective, take it back to Lowe's and insist on a replacement, talk to the manager if you have to. This site will only advise you on how to fix it.
Mar 05, 2008 | Vacuums
Vacuums Logo
73 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
