Question about Senco Tools & Hardware - Others
Senco pw 150. installed new trigger nipple mechanisms. they are freezing for no apparent reason after running great. Why?
5 Suggested Answers
SOURCE: My 2001 olds silhouette van
I JUST BUY A USED 2001 OLDSMOBILE AND IT MAKES A ELECTRICAL NOSIE AND CLIKS BUT WILL NOT STAR JUST GOT A NEW BATTERY DRIVEN LIKE 2 AND NOW DO NOTHEING COULD IT BE SOMTHING WITH MY ANTI-THEFT DEVICE IS THAT KILLING MY BATTERY
Posted on Feb 20, 2009
Editor925
  • 285 Answers
SOURCE: trigger asembly broke ned new one
Check for authorized Senco retailers or repairers near you and they will be able to order one in for you. www.senco.com
Posted on Mar 01, 2009
  • 5 Answers
SOURCE: motor runs on
They have issues with there switches.Depending on model # check for recall. This is a safety issue.
Posted on Jul 08, 2009
  • 66 Answers
SOURCE: we installed the new fourescent bulbs in our can
You can not dim compact fluorescent lamps. The ballast for the fluorescent is built into the bottom of the lamp. IF the manufacture says that it is dimmable, then you would need a special interface (Lutorn FDBI) to make it work properly. It may work for a short while with out it, but will burn out the ballast or dimmer.
Posted on Oct 24, 2009
OK, second shot at this: About 65% of the time my SFN30 Senco finish nail gun only shoots a nail every OTHER pull of the trigger. All the O-Rings are good and the driver blade is perfectly straight.
There are 4 main causes usually with this tool:
1) Check the seal in the bottom of the cylinder (under the bumper) #BF0070 (#12 on the breakdown) If this seal is missing or worn the piston will not always return fully.
2) The pusher spring #GD0253 in the magazine is not moving the nails forward
2) The driver is bent or the tip is worn / chipped
3) The check valve ring #LB0077 on the cylinder is not sealing properly
Let me know if this helps Senco SFN30 15 Ga Finish Nailer Parts
Feb 26, 2017 | Senco Air Tools & Compressors
I have a senco stapler how do I change it so I do t have to squeeze trigger every time. I want to hold trigger down and just press to underlayment. Can't figure out how to change it.
Hi Jack,
Depending on the model number you have, Just replace the trigger with a SEQUENTAL trigger. This is a genuine SENCO part and is completely complient with all Health & Safety law. if you need a parts chart, email me at the website below. We are SENCO dealers for over 30 years in the UK Leigh Co Limited
Jan 19, 2015 | Senco Tools & Hardware - Others
Why does my senco frame pro when I use 2" nails
Good afternoon,
Usually the reason is because you're trying too hard to keep the nose of the tool in contact with the timber you are trying to nail. Perhapse you might just relax a little, then it'll all be fine.
These tools are able to fire by either placing the tool on the work piece and pulling the trigger. Or you can hold the trigger and "bounce" the tip of the nose to actuate the firing sequence. ( This is fine if you're just putting up first fix frame but, if you need a more refined and accurate fix go for the first method)
If you still can't get by, take the tool to you're local Senco Service centre and ask them to fit a restrictive trigger. That will only allow you to fire one nail at a time.
Regards
Alex
Leigh Co Limited
Oct 18, 2014 | Tools & Hardware - Others
Trigger
There is no adjustment that can be made to make the safety work or not. When new, the SCN45 had a safety system that prevents the nailer from firing unless it was pressed against a surface. If your gun fires without the safety being compressed, it has somehow been bypassed either by being jambed or tied in the firing position or the trigger lever is wedged so it can't operate properly. Below is a site that has a great breakdown of your tool that you can reference to see what parts may be missing. This is an older tool and many parts are no longer available.
Senco SCN45 Coil Nailer Parts
Dec 31, 2013 | Senco SCN45 Coil Nailer, Contact or...
My Senco SFN1 finish nailer will not shoot a nail. When the trigger is pulled air comes out but no nail is shot. Thanks,Steve L
Not sure about Senco but most have latch you can open to expose firing mechanism. Nail sometimes gets jammed and will not allow driver to fire or if not nail push driver ****** all the way back into gun then see if gun will fire.
Oct 25, 2010 | Senco 2D0001N FinishPro2N1, 18 Gauge Brad...
Framepro 602 only shoots air out a hole in the top when the trigger is pulled, occasionally shoots a nail but more often just shoots air
You have some worn out o-rings in your gun. Get a Senco repair kit #YK0360, use everything in the kit and your gun will be as good as new. Type "senco yk0360" in your search engine and shop around, the kit should be around $45 - $50.
Oct 11, 2010 | Senco Air Tools & Compressors
Senco 601 nailer shoots 2 nails each time the trigger is pulled.
the 601 had a design flaw, in the nose, where the nails hit as the are being pushed forward, the peice was made out of a peice of metal that was too soft, it wore down and that is where you get the double nail problem.
Senco offered a trade in, this was years ago, for a limited time and gave us credit towards new guns, which we gladly did
Dec 31, 2009 | Senco & Frame Pro 601 Framing Nailer
Senco finishpro ,the casting at the end of the handle where the air nipple srews in, is broken. where can I get a new one? and where on the tool can I find the model number?
Go to Senco.com and type in your model number. It should be on a plate somewhere on the tool, if not there is a toll free number for their tech support that can help you with this problem.
Sep 18, 2009 | Senco PC0974 Finish Pro 10 23 Gauge Pinner...
Trigger asembly broke ned new one senco model#03501710
Mar 01, 2009 | Senco 2D0001N FinishPro2N1, 18 Gauge Brad...
Tools & Hardware - Others Logo
57 people viewed this question
Top Senco Tools & Hardware - Others Experts
John Trevino
yoopertech
John Bowen
Are you a Senco Tool and Hardware - Other Expert? Answer questions, earn points and help others
