Question about Mini Scuba Gauge Ist Scuba Pressure
Water inside the gauge.Blow out plug is good.Can you take off the face plate?
    Scholar:
  • 190 Answers
The gage may be removed from the rubber boot, but the clear face plate is not removable.
Posted on Oct 08, 2010
Speedometer not working
Unless this is something special, that unit on the transom is a pitot tube and a hose is attached to it. It reads water pressure as you go faster. It has some very small holes in it that can clog. Also the black tube can get clogged of crimped. We use to disconnect the hose at the back and test the gauge with a little air pressure ( the best we could blow by mouth was about 10 mph. If you use compressed air be careful not to break the gauge. If the gauge works, blow down the pitot tube CAREFULLY as there may be a drill plug you may blow out. Worse case , replace the pick up.
Sep 29, 2014 | Teleflex Vector Speedometer Kit (1060)...
My 1954 shippy pick up with the thrift master engine keeps overheating and cutting out can you help please
Check the radiator level, then think very hard about replacing the thermostat, then look closely at the radiator fins - front surface, behind the grille. If all that passes but the truck still overheats, doublecheck the temperature with another gauge, then consider having the cooling system flushed (or do it yourself).
Aug 03, 2014 | Cars & Trucks
Freezer door leaking
I thought my leak was also coming from a line but nope - it's the black drain grommet that fits over the drain located just above the compressor in the back bottom of the unit. I had to use a blow dryer inside the freezer section to unthought the ice that was behind the freezer back wall. No need to take the freezer inside back plate off just use a blow dryer to melt the ice where the grille is located inside the freezer. You do have to take the back plate off where the water lines go into the bottom of the fridge. Once the back plate is off you then disconnect a yello and Orange plug that goes to the water line selinoid valve. Then prop up the back plate with the water lines still attached so you can access the black grommet on the drain. You must also disconnect the black drain tube from the water tray. Be careful not to break it as there is a small push clip that must be pushed in while you pull up. Once it's off then take the black grommet off of the drain that is just above the compressor. Mine was plugged with lint and sticky - wash throughly and then take a small pick or screw driver and insert it in the drain - once I did this about 2 cups of water came out so be prepared with a cup to keep it off the wires right below the drain. Clean up the water in the freezer and then reverse wha thou took off and then plug the fridge back in - you just saved $150 on appliance house call. Bad design for a high end fridge - my sears in the garage is 20 years old and not one problem. Cold beer on hand. Hope this helps!
Aug 13, 2012 | KitchenAid KBFS20EVMS 36" french door...
How do I change a dash from metric to english
You will need to get a gauge from the same type of motorcycle that has the MPH on it. You can either switch the entire gauge which would be pretty simple on a motorcycle or just change the faceplate which would require you to take two gauges apart and reassemble the original one with a new face plate.
Make sure that the face plate speed marks line up. I would suggest getting a gauge with both MPH and KPH on it with the maximum KPH rating as your old one.
Mar 21, 2011 | Suzuki GSX-R 1000 Motorcycles
When I load papers into the document feeder on top of my HP Officejet 7210 All-in-One printer to scan these documents, the PDF file (scan results) have a multi-color series of lines from top-to-bottom on...
  1. Remove all originals from the document feeder tray.
    NOTE: It might be easier to work with the automatic document feeder if the document feeder tray is removed first.
  2. Lift the cover of the automatic document feeder. Figure 1: Lifting the ADF coverc00222493.gif
  3. Lift the lid on the HP all-in-one, and locate the notch near the top right edge of the lid backing. Figure 2: Locating the notch near the lid backingc00222494.gif 1 - Notch 2 - Lid backing
  4. Place one or two fingers in the notch, as you lower the lid of the HP all-in-one. Keep your fingers in the notch until the lid is almost closed. Figure 3: Inserting fingers into the notchc00222495.gif
  5. Push against the top of the face plate with your thumb as you pull the bottom away from the right side of the HP all-in-one with your fingers. Use a slight twisting motion to help release the face plate on the right side.
    CAUTION: Do not pull the face plate all the way off yet. There is a plastic catch on the far left inside of the face plate that helps secure the face plate in place. If the face plate is pulled straight off, the plastic catch on the inside of the face plate might be damaged. Figure 4: Releasing the face plate from the right side of the HP all-in-onec00222496.gif 1 - Releasing the right side with a slight twisting motion
  6. Slide the face plate to the left until the plastic catch on the left side is not touching any part of the HP all-in-one, then pull the face plate away from the device. Figure 5: Removing the face plate from the HP all-in-onec00222497.gif 1 - Sliding the face plate to the left 2 - Pulling the face plate away from the HP all-in-one
Cleaning the rollers or separator pad Follow the steps below to clean the rollers or separator pad.
  1. Once the face plate of the ADF is removed, use the blue-green handle to lift the pick assembly. Figure 6: Blue/green handle and the pick assemblyc00222498.gif 1 - Blue-green handle 2 - Pick assembly This allows access to the rollers and the separator pad. Figure 7: The rollers and the separator padc00222499.gif 1 - Rollers 2 - Separator pad
  2. Lightly dampen a clean, lint-free cloth with distilled water, then squeeze any excess liquid from the cloth.
  3. Use the damp cloth to wipe any residue off of the rollers or the separator pad.
  4. If the residue does not come off using distilled water, try using isopropyl (rubbing) alcohol.
  5. Use the blue-green handle to lower the pick assembly.
Reattaching the face plate of the ADF Follow the steps below to reattach the face plate to the front of the automatic document feeder.
  1. Hook the face plate onto the left side of the HP all-in-one so that the plastic catch on the far left inside of the face plate catches on the notch on the front of the automatic document feeder. Figure 8: Hooking the face plate into the left side of the HP all-in-onec00222500.gif 1 - Notch 2 - Plastic catch
  2. Line up the right edge of the face plate with the right side of the HP all-in-one, and then press on the right side of the face plate until it snaps securely into place. Figure 9: Snapping the face plate into the right side of the HP all-in-onec00222501.gif
  3. Place your hands towards the center of the face plate, and press until the center of the face plate snaps into place. You should hear two clicks; one when the left side snaps into place, and one when the right side snaps into place. Figure 10: Finishing re-attaching the face platec00222502.gif
  4. Close the cover of the automatic document feeder.
  5. If you removed the document feeder tray, reattach it.
Dec 07, 2010 | HP Officejet 7210 All-In-One InkJet...
Won't turn on
Simplest problem would be a blow fuse. Might be one on the face of the amplifier, but more likely inside. Remove the plate amp and see if one's easily visible, near where the power cord goes through the face of the amplifier.
Nov 08, 2010 | Paradigm PDR 12 Speaker
Water will not drain, drumb won't spin
check water pump for faults and or blockage it will not spin as there is to much water inside once it has drained it should spin this is a safety feature
Jan 15, 2010 | Kenmore HE2 Plus Front Load Washer
2000 Xterra intermentantly overheats (temp gauge goes up) no leak appears present. Coolant level appears correct. Heater will blow cool air, then start blowing hot air. Temp will then come back to normal....
sounds more like the thermostat may be failing. generally a water pump starts leaking out of the "weep" hole in the casting before it quits. just look at the front of the water pump for a greenish streak or an obvious leak.
if you also suspect you heater core may be getting plugged now would be a good time to back flush it to get rid of some of the gunk.
Oct 22, 2009 | 2000 Nissan Xterra
Face plate went out on my pioneer deh 6800mp
There is a fine strip that runs from the face to the circuit board. It is possible that face has gotten dirty just needs a can of compressed air or the circuit board has failed inside the face. The face plate is very easy to take apart and put back together, just make sure you don't lose any pieces ;) Good luck!
Jun 11, 2009 | Pioneer DEH-P6800MP CD Player
Ribbon cable broken and now cannot open the face plate
You need to take the unit apart to fix the cable since the other end of it plugs into the board inside, it's pretty easy to take apart though. Good luck!
Feb 09, 2009 | Pioneer DEH-P8600MP CD Player
Mini Scuba Gauge Ist  Scuba Pressure Logo
122 people viewed this question
Top Mini Scuba Diving & Snorkeling Experts
Bill Boyd
ray gallant
Are you a Mini Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
