Question about Toys
I need a wiring schematic for a heli-max axe cpv3
Dewalt model dcf887 wire schematics
Request the wiring diagram directly from Dewalt.
Jul 17, 2016 | Dewalt DCF885C2 20-Volt MAX Lithium Ion...
I have this model and we have looked the whole Heli over and can find no power on/off switch. Won't turn on or anything. Need some help here
Most of these modela need lots of power to fly, so probably you need to charge it, then you can fly 5 or max 10 mins. Then the battery will be empty again.
Dec 25, 2014 | Toys
Wiring schematic for MTB217 cooper b line
I would suggest taking a closer look at the motor name plate. I am not familiar with a 120/240 three phase service. When I checked the web it shows: Voltage 115/230 (that is single phase), Max Amps 115 Volts = 19.2 Max Amps 230 Volts = 9.6 , Single Speed, Square Flange, RPM = 3450, Threaded Shaft, Frame = 48Y Used on the following models: Sta-Rite Max-E-Glas, Max-E-Glas II, Dura-Glas, Dura-Glas II, Dyna-Glas, Dyna-Max Pentair Whisperflow, Pinnacle and Anthony AR2 Series. You should also show what voltage you are connected to.
Mar 14, 2014 | A.O. Smith SQ1102 Pool Pump Motor
Can you bind the Heli max Helis to a D6i transmitter
Yes, you need to buy an AnyLink transmetter that will plug in the trainer plug of your tranmitter.
I put a web link to Tactic anylink products that can be order from internet from online hobbyshop, look in the Where to buy tab on anylink website. Have fun :-)
Dec 09, 2013 | Heli-Max MD-530 Flybarless EP Tx-R...
Axe cp flybar paddles do not return parallel to swashplate after cyclic stick is moved left or right
it should not spin freely, the collars should have a set screw to keep the flybar secure
May 02, 2017 | Rc Helicopter Axe Cp Heli Max Flybar...
Need charging instructions for Air Hogs Havoc heli. Is remote control switch to be turned on during charging? What position is channel switch in? Is Heli on/off switch set to charge? I have no...
1.Take out charging wires. 2.turn off your heli and insert charging socket into your heli's socket. 3.the charging green light will light up while charging. 4.charging complete, the green light will turn off. 5.pull out the wires and you are ready to fly. Let the heli's battery cool down for approx. 15 minutes before charging.
Feb 19, 2010 | Spinmaster Air Hogs Battling Havoc R/C...
Heli max hicro helicopter just keeps spinning in circles
Spinning is caused by one of the main propellers rotating faster than the other. If both propellers are secured tightly to their drive shafts, the spin control knob on the remote control can be used to stop the spin. However, if one prop is slipping with respect to the other, the spin control knob will not fix the problem.
I've found that the set screws holding the propellers to the drive shafts tend to loosen after a while. If one prop is a bit loose and the other is tight, the relative slippage will cause the helicopter to spin.
To check, turn off helicopter power and manually rotate each propeller separately, watching the nylon gears in the body. If the propeller is moving and its drive shaft gear isn't, the propeller is slipping because its set screws are not applying enough pressure on the propeller's drive shaft.
Carefully tighten the set screw and the problem should be fixed. DON'T OVERTIGHTEN, or the plastic threads for the set screw will be stripped and the propeller assembly will be ruined.
Apr 10, 2009 | Max Heli- Axe CX Micro Electric Rc Mini...
Nephew lost directions for charging
make sure both heli and controller are off and batteries are new and then plug wire into heli and then turn controller on it doesnt matter abc, abc is just the frequency to controll heli just match with the letter under the heli
Jan 04, 2009 | Air Hogs Havoc Heli Helicopters
Toys Logo
137 people viewed this question
Top Toys Experts
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
