Question about Broan-NuTone N-8663RP Combination Light Fan Exhaust Fan
Loose blower wheel assembly
Blower wheel assembly gradually slides down away from nut-push on motor spindle, causing rubbing against motor base and eventual stopping of blower wheel. Solution?
  • 1 more comment
  • PatKronic May 19, 2008
    Same exact problem.
  • Anonymous Nov 23, 2008
    I Have five bathrooms with this same fans and they have all done the same thing. The motors have so much torque that they strip out the the cheap plastic fans. You can buy the replacement fans from electricmotorwarehouse.com or ventingdirect.com. This is obviously a problem that has existed for 10 to 15 years. Part numbers are 5901A-000.
    John
  • trussell35 Jan 21, 2009
    I have the same problem. The fan assembly slides down the shaft and starts rubbing on the housing. Once this happens once, it will do it again much easier next time. I did try a very crude method that didn't work. I put some "Gorilla" glue on the shaft at the bottom of the fan (once I pushed it back in place)--hoping it wouldn't allow the fan to slide back down, but it did not work. Now--the shaft is hard to get to so it could be that I didn't get the glue in exactly the right place. I'm thinking about trying it again--this time being extra careful to put the glue in the right place and allow a day or so for drying.
Place the push nut below the blower wheel. Don't bother with the top. The centripetal force tends to push the wheel down. The push nut in this position will prevent this.
Posted on Dec 05, 2009
  • 2 more comments
  • countrygirl26 Sep 08, 2012
    Thanks Jackietuzo! This absolutely did the trick.
    Thanks jackietuzo! This worked perfectly!!
  • Ketan Dodhia May 19, 2013
    this worked for me, too!
  • Brian Tully
    Brian Tully Nov 21, 2013
    Sorry to be so naive, but what is a push nut? On my unit there is just the spindle that spins and then the plastic squirrel fan that gets pushed onto the spindle. There is nothing retaining the fan other than the fact that the top of the spindle has grooves in it. I took apart the unit a couple of days ago and thought I was a genius for fixing it by sliding the fan back to the top of the spindle. But here it is 2 days later and it's making the same loud noise :(
This happened on my fan too and the motor burned out from being stalled all the time. Try putting a spring retaining ring (E-ring or similar from someplace like smallparts) of the appropriate size on the shaft below the blower wheel to keep it from sliding down. Nutone should have done this themselves to begin with! (but I guess it helps them sell motors...)
Posted on Jul 03, 2009
I have 04 vue. Fwd 3.5. How do i change out right side cv axle? I can't free end that goes into carriage bearing?
remove lower ball joint and remove axle nut in the center of spindle. then move the spindle out of the way separating the axle from the spindle.
Mar 28, 2015 | 2004 Saturn VUE
Pursuit XL scooter, rubbing sound during right turns...
My first guess is that you have either loose lug nuts(5)on one or more of the wheels, or you have loose screws(6)that hold the wheel rims together as these have split rims. This is more common on scooters with flat-free tires as the tire and the foam insert will chafe against each other and produce a rhythmic sound as the wheel rotates. Try tightening all of the lug nuts first and see if that helps. If it persists, try removing the tire by removing the 5 lug nuts and pulling it off the axle. You'll see six bolts that hold the rim halves together. Re-tighten all of these and install the wheel to see if that cleared the noise. Note: The real wheels have a key-slot in the axle and a key which slides into this slot to hold the tire to the axle. Be careful not to lose the key when you slide the wheel off, and be sure to get the key back in the slot when you install it back on the hub. Here is the page for your scooter. Click on the owners manual and scroll down to page 37 for info on tire removal.
Jan 10, 2013 | Pride Mobility Pride Pursuit XL 4 Wheel...
I have had to replace the blower wheel on my Maytag Performa Dryer twice in the past 2-3 months. The wheel when removed looks as though it is being ground down. Could there be something else wrong?
Just check that the dryer vent out the back hasn't been pushed into the machine. Sometimes when the dryer is pushed against a wall the vent can be pushed back into the machine somewhat, which will in turn push the blower wheel housing forward and deform it slightly, causing the blower wheel to rub on the housing.
Jul 06, 2011 | Dryers
Hi haw can i change my wile Bering?
Park the car on level ground. Put the transmission in park and set the parking brake. Jack the car up and place the jack stands underneath the frame of the car.
Use the tire iron to remove the lug nuts from the wheel and pull the wheel off.
Use the ratchet set to remove the mounting screws on the disc brake caliper. Pull the caliper loose and then slide the disc off of the wheel studs.
Use the ratchet to loosen and remove the wheel hub mounting bolts located on the backside of the steering spindle.
Pull the entire wheel hub assembly off of the steering spindle. Take the assembly to a machine shop and have them use a hydraulic press to press out your bearing (the bearing is pressed into the hub assembly and is too big for at-home extraction).
Press in the new wheel bearings and then reassemble the wheel hub by mounting it on the steering spindle again.
Slide the disc back into place on the wheel studs and then remount the caliper with the mounting bolts. Slide the wheel back in place on the studs and tighten down the lug nuts in a star pattern.
Lower the car off of the jack stands or move on to change the other side's wheel bearings as well.
Oct 20, 2010 | 1991 Honda Accord
How to replace rear wheel bearings on a 2000 cougar?
Hi,welcome to fixya.
The rear wheel bearings are not adjustable. If the bearings make noise or become loose, they must be replaced.
Removal & Installation
With Drum Brakes
NOTE The wheel bearings are contained within the wheel hub and must be replaced as an assembly.
  1. Disconnect the negative battery cable.
  2. Raise and safely support the vehicle.
  3. Remove the wheel and tire assembly.
  4. Remove the anti-lock sensor retaining bolt and remove the sensor.
  5. Remove the brake drum retainer and the brake drum.
  6. Remove the hub retaining nut dust cover.
    NOTE Do not use an impact gun to remove the hub retainer nut.
    0996b43f80232353.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Using suitable tools loosen and . . .
    0996b43f80232351.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. . . . remove the hub retaining nut dust cover
  7. Remove the wheel hub retainer nut.
    0996b43f8023234f.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Using suitable tools, loosen and . . .
    0996b43f80232352.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. . . . remove the hub retaining nut
  8. Slide the hub and bearing assembly off of the spindle.
    0996b43f80232350.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Carefully slide the hub and bearing assembly off of the spindle
To install:
  1. Reinstall the hub and bearing assembly to the spindle.
  2. Reinstall the hub retainer nut. Tighten the retainer nut to 170-192 ft. lbs. (230-260 Nm).
    WARNING Do not use an impact gun to tighten the hub retainer nut, otherwise the bearings may be damaged.
  3. Install the hub retaining nut dust cover.
  4. Reinstall the brake drum.
  5. Check the brake shoes for proper adjustment.
  6. Reinstall the anti-lock sensor and the retaining bolt. Tighten the retaining bolt to 7-8 ft. lbs. (9-11 Nm).
  7. Reinstall the wheel and tire assembly. Tighten the wheel nuts to 62 ft. lbs. (85 Nm).
  8. Lower the vehicle until the wheels are supporting the vehicles weight. This will properly load the suspension.
  9. Tighten the spindle-to-control arm bolt to 52-79 ft. lbs. (70-98 Nm).
  10. Tighten the tie rod-to-spindle bolt to 75-102 ft. lbs. (102-135 Nm).
  11. Finish lowering the vehicle.
Road test the vehicle and check for proper operation.
Thank You for using fixya........iluv2fish........Ray........
Jul 16, 2010 | 2000 Mercury Cougar
How to install a front blower motor in a 96 ford explorer
Blower Motor - REMOVAL & INSTALLATION
(see Figures 1 and 2)
Fig. 1: Exploded view of the blower motor mounting
Fig. 2: Exploded view of the blower motor and wheel (fan) assembly
Without Air Conditioning
  2. Remove the air cleaner or air inlet duct, as necessary.
  3. If necessary, Remove the speed control module and the washer fluid reservoir.
Fig. 3: To remove the blower motor, first disconnect the electrical wire harness plug...
Fig. 4: ...then remove the blower motor cooling tube from the motor
  1. Disconnect the wire harness connector from the blower motor by pushing down on the connector tabs and pulling the connector off of the motor.
  2. Disconnect the blower motor cooling tube at the blower motor.
Fig. 5: Remove the blower motor attaching screws and the washer fluid reservoir...
Fig. 6: ...then slide the blower motor from the housing. Take care to not damage the blower wheel (arrow)
  1. Remove the 2 screws attaching the blower motor and wheel to the heater blower assembly.
  2. Holding the cooling tube aside, pull the blower motor and wheel from the heater blower assembly and remove it from the vehicle.
  3. Remove the blower wheel push-nut and/or clamp from the motor shaft and pull the blower wheel from the motor shaft.
To install:
  1. Install the blower wheel on the blower motor shaft.
  2. Install the hub clamp and/or push-nut.
  3. Holding the cooling tube aside, position the blower motor and wheel on the heater blower assembly and install the 2 attaching screws.
  4. Connect the blower motor cooling tube and the wire harness connector.
  5. Install the vacuum reservoir on the hoses with the 1 screws.
  6. If removed, install the speed control module and the washer fluid reservoir.
  7. Install the air cleaner or air inlet duct, as necessary.
  8. Connect the negative battery cable and check the system for proper operation.
With Air Conditioning
  2. In the engine compartment, disconnect the wire harness from the motor by pushing down on the tab while pulling the connection off at the motor.
  3. Remove the air cleaner or air inlet duct, as necessary.
  4. If necessary, remove the solenoid box cover retaining bolts and the solenoid box cover.
  5. Disconnect the blower motor cooling tube from the blower motor.
  6. Remove the blower motor mounting plate attaching screws and remove the motor and wheel assembly from the evaporator assembly blower motor housing.
  7. Remove the blower motor hub clamp from the motor shaft and pull the blower wheel from the shaft.
To install:
  1. Install the blower motor wheel on the blower motor shaft and install a new hub clamp.
  2. Install a new motor mounting seal on the blower housing before installing the blower motor.
  3. Position the blower motor and wheel assembly in the blower housing and install the attaching screws.
  4. Connect the blower motor cooling tube.
  5. Connect the electrical wire harness hard shell connector to the blower motor by pushing into place.
  6. If removed, position the solenoid box cover into place and install the 2 retaining screws.
  8. Connect the negative battery cable and check the blower motor in all speeds for proper operation.
Hope this help (remember comment and rated this).
Apr 23, 2010 | 1996 Ford Explorer
Changing cvc joints 1997 accord
replace the entire CV axles. Support vehicle with jackstands by frame. Remove front wheels. Remove axle nuts. Remove lower balljoint nut. Separate balljoint from nuckle by banging hard with ball peen hammer on knuckle on spindle assy. Remove outer tie-rod nut. Separate tie-rod from steering nuckle by bangin on nuckle with ball-peen hammer. Use long pry bar to hold lower control arm down while simultaneously pulling hub/spindle assembly away from vehicle and pushing axle through hub toward transaxle. Go under vehicle and pry inner cv joint away from transaxle while holding axle assembly.
Install new CV axle in reverse of the disassembly.
Feb 21, 2010 | 1997 Honda Accord
Noise coming from my blower sounds like something is loose
HI.The blower fan or squirrel cage is rotated by the blower motor shaft, thus, forcing air through the heater core or A/C evaporator core and into the passenger compartment. it is housed in the blower compartment shroud. If the motor shaft becomes unstable, this will cause the cage, or blower wheel, to rub against the shroud, or housing. This will cause the noise you are hearing. The shaft screw may be loose, or the shaft, itself, may be faulty as well.
In most cases, replacing the blower wheel will correct this issue.It would be wise to inspect the blower housing for any loose mounting screws before replacing the wheel.
Nov 18, 2009 | 2005 Pontiac Grand Prix
Front brake rotor on 1992 Ford Ranger 4wd with auto lock in
With Automatic Locking Hubs
  1. Raise the vehicle and install safety stands.
  2. Remove the wheel lugnuts and the wheel and tire assembly.
  3. Remove the retainer washers from the lugnut studs. Remove the automatic locking hub assembly from the spindle.
  4. Remove the snap ring from the end of the spindle shaft.
  5. Remove the axle shaft spacer
  6. Being careful not to damage the plastic moving cam or thrust spacers, pull cam assembly off the wheel bearing adjusting nut and remove the two plastic thrust spacers from the adjusting nut. CAUTION: Do not pry on the plastic cam or thrust spacers during removal. Prying may damage the cam or spacers.
  7. Using a magnet, remove the locking key. NOTE: If required, rotate the adjusting nut slightly to relieve pressure against the locking key, before the key can be removed. CAUTION: To prevent damage to the spindle threads, look into the spindle keyway under the adjusting nut and remove the separate locking key before removing the adjusting nut.
  8. Loosen the wheel bearing adjusting nut from the spindle using a 2-3/8 inch Hex Locknut Wrench T70T-4252-B or equivalent.
  9. While rotating the hub and rotor assembly, tighten the wheel bearing adjusting nut to 47 Nm (35 ft lb) to seat the bearings. Spin the rotor and back off the nut one-quarter turn (90 degrees).
  10. Retighten the adjusting nut to 1.8 Nm (16 in lb) using a torque wrench.
  11. Align the closest lug in the wheel bearing adjusting nut with the center of the spindle keyway slot. Advance the nut to the next lug if required. Install the separate locking key in the spindle keyway under the adjusting nut. WARNING: Extreme care must be taken when aligning the spindle nut adjustment lug with the center of the spindle keyway slot to prevent damage to the separate locking key. The wheel and tire assembly may come off while the vehicle is in motion if the key is damaged.
  12. Install the two thrust spacers and push or press the cam assembly onto the locknut by lining up the key in the fixed cam with the spindle keyway. CAUTION: Extreme care must be taken when aligning the fixed cam key with the spindle keyway to prevent damage to the fixed cam.
  13. Install the axle shaft spacer.
  14. Clip the snap ring onto the end of the spindle shaft.
  15. Install the automatic locking hub assembly over the spindle by lining up the three hub assembly legs with three pockets in cam assembly. Install the retainer washers.
  16. Install the wheel and tire assembly. Install and tighten lugnuts to 135 Nm (100 ft lb).
  17. Make sure the final end play of the wheel on the spindle is 0.00-0.08 mm (0.000-0.003 inch). the maximum torque to rotate the hub is 2.8 Nm (25 in lb).
Jul 27, 2009 | 1992 Ford Ranger
The blower wheel on my dryer has begun to rub against the panel
your blower is held onto shaft with 2 clips,inner and outer.loosen bolt slightly and you should be able to push blower back a little be careful not to loosen too much ,they can be a pain to realign.Hope this helps,please rate my solution.:)
Jun 25, 2009 | Dryers
Broan-NuTone N-8663RP Combination Light Fan Exhaust Fan Logo
1,369 people viewed this question
Top Broan-NuTone Dryers Experts
Havn Fun Here
Havn Fun Here
Mike Squire
mike simpson
Are you a Broan-NuTone Dryer Expert? Answer questions, earn points and help others
