Programing jumbo universal remote
I have a innovage prodution jumbo universal remote but can't program it i lost the codes to program it so i dont know how to program it to my television
    President:
  • 2,712 Answers
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on May 05, 2008
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    This thread has gone 14 days or more without a response.
    Please close the thread with a “FixYa” or “Helpful” rating.
    Or post back with latest developments, what steps you took,
    etc. and I will assist you further as best I can.
    Thank you.
    IrishDruid
Lost manuel how do I program it
Jumbo Universal Remote Control
Danny, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Innovage Jumbo Universal Remote
http://www.jumboremotecontrol.com/innovage_jumbo_remote_manual.PDF
How To Program The Innovage Jumbo Universal Remote Control
JUMBO Universal Remote Codes Codes For Universal Remotes
May 03, 2016 | Innovage Jumbo Universal Remote Control
How do i program the innovage jumbo universal remote
Jumbo universal remotes are essentially the same regardless of the name at the top. If you have a device you want to control, start by turning on that device. Press and hold CODE SEARCH until the red indicator stays on, then release the CODE SEARCH button. Press and quickly release the device button, e.g, TV. Point the remote directly at the device. Press the power button (in the upper right corner) repeatedly until the device responds, e.g., changes channel. Press ENTER and release to install the code. If no result, your Innovage jumbo remote may not have a suitable code available.
Oct 23, 2014 | Innovage Jumbo Universal Remote Control
I need the codes for my innovage jumbo remote ..I want to program my RCA TV, but i dont have the code
I downloaded the manual and I was able to program my jumbo remote within 1 minute.....Was very helpful, thanks for the info on the download, bye
Nov 27, 2009 | Innovage Jumbo Remote Control
Codes to program Innovage Products Jumbo Universtal Remote
Innovage Jumbo remote codes for RCA TV; 000, 003, 004, 005, 007, 009, 011, 015, 048, 082, 092, 094, 096, 098, 102, 103, 107, 113, 125, 129, 167, 179, 187, 188, 191,194.
Pansonic DVD; 175.
Pansonic VCR; 021, 060, 115, 125, 138, 148, 149.
Philips DVD; 173, 183, 198.
Bell ExpressVu; 168, 187, 194.
Dec 18, 2008 | Televison & Video
Innovage products jumbo remote
need code for jumbo remote
Jun 14, 2008 | Televison & Video
Try this site;
http://www.blurtit.com/q717681.html
Good luck
Mar 03, 2008 | Televison & Video
Universal remote control device
i have an innovage jumbo universal remote and i need the codes for my sylvania MODEL>6427 TE
Feb 28, 2008 | Televison & Video
Instructions for Programming Innovage Jumbo Universal Remote
You can download documentation for the Innovage remote here:
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/innovage/jumbo-manual.zip&area=other
Dec 31, 2007 | Televison & Video
H have the jumbo universal remote from innovage pruducts. can you e-mail me all the codes? thanj you. jtorres663@aol.com
Dec 15, 2007 | RCA RCU600M Remote Control
Televison & Video Logo
61 people viewed this question
Top Televison & Video Experts
Electro Med Services...
