Question about Casio OH-260 Calculator
Zero does not display correctly keys get stuck
  • 34 Answers
Throw it agaisnt the wall or click the rest button :D
Posted on Aug 24, 2010
How To enter programing mode The W10312695 Control Board
Open the fresh food door and hold the fresh food light switch closed while pressing the freezer temperature down key three times in a row. This must be done within 10 seconds.
Release the door switch.
The control will display PE to confirm entry into programming mode.
You need to confirm entry into programming mode by pressing the freezer down key once more.
The control should display zero on both led's.
Set the control to the correct code as shown on the model and serial number sticker in the fresh food section.
This is done by pressing the fresh food up and freezer up buttons until the correct code is displayed.
Once the desired program code is displayed, press the freezer down key until the program code begins flashing.
Once the programming code has been saved the programming mode can be exited by closing the fresh food door.
Sep 11, 2014 | Whirlpool Refrigerators
I have a DigitZ DZ3-600 and when I turn it on the word FULL in the display screen . What can I do to clear this and start using it?
My search is telling me that this is a scale. Is this correct? If so - this is the manual. \'FULL\' is not an error, but this is the correct model. If this is not a scale, please write again and provide more information:
The manual is short and PASTED after link to same here:
http://digitzscales.com/index.php?option=com_content&view=frontpage
Digitz DZ3-600 Manual
I. Operation
1. Place the scale on a flat, level surface and press the ON/OFF key to turn the scale on.
2. Once the start-up process completes and the scale goes to zero you are ready to weigh.
3. Place the quantity to be weighed onto the weighing platform.
4. Wait a couple seconds for the display to stabilize before taking a weight reading.
II. Changing the Unit of Measure
1. Press the MODE key to change the scales displayed unit of measure.
2. If the scale is turned off then back on, it will default to the last unit used.
• DZ3-100 Units: g (gram) oz (ounce) ct (carat) gn (grain)
• DZ3-600 Units: g (gram) oz (ounce) ozt (troy ounce) dwt (pennyweight)
III. Using the Tare Feature
You can use this scale\'s tare feature to subtract the weight of an empty container or vessel for net weight determination. NOTE: The weight of the container will subtract from the available capacity.
1. Place the empty container or vessel on the weighing platform.
2. Press the TARE key once. The display will then reset to zero. If the container is removed, it\'s weight will be displayed as a negative number.
3. You may now fill the container with the quantity to be weighed. The display will show the net weight of the contents.
4. To return to normal weight display (gross weight), remove any items from the weighing platform and
press the TARE key again to re-zero the scale.
IV. Calibration / Adjustment
1. Turn the scale on by pressing the ON/OFF key.
2. Wait for the display to show "0.0g" or "0.00g" then press and hold the MODE key until the display shows "CAL", then release.
3. Press the MODE key again. The display will flash "CAL" followed by the required calibration weight.
4. Place the required calibration weight on the center of the platform. The display will show "PASS" then return to normal weighing mode. Calibration is complete! You may now turn the scale off.
V. Error Codes
1. OUTZ - Zero range has shifted. Perform calibration adjustment. If the problem persists, the load cell may be permanently damaged due to overloading.
2. 88888 - Maximum capacity exceeded. Remove the extra weight to avoid damaging the load cell.
3. L - Batteries are low. Replace the batteries.
VI. Specifications
DZ3-100 DZ3-600
Max. Capacity 100g 600g
Readability 0.01g 0.1g
Min. Weight 0.03g 0.2g
Power Two (2) AAA Batteries
Dimensions 3.0 x 5.0 x 0.8 in.
Platform Dimensions 2.5 x 3.0 in.
For warranty and support, please email
warranty@digitzscales.com
Aug 20, 2014 | Office Equipment & Supplies
My email n password dont match, how can I fix it?
The procedure to troubleshoot email account login issues may vary depending upon your email service provider. So, to let us suggest you a specific solution, can you please share with us the name of your email service provider?
In the meanwhile, we recommend you to make sure that all the keys on your keyboard are functioning properly. If one or more keys are jammed or have stuck up, the keys that you hit may not display characters correctly on your login page. Also, make sure that the functional keys like Caps Lock and Nums Lock are On or Off only when required. To make sure that the keys on your keyboard are working fine, you can first try typing your email ID and password on a Notepad or Word Document and see if they come up correctly. If the keyboard is working fine, we suggest you to try typing your email ID and password slowly (if you have not done this already). Also, give special attention to characters like 2 or Z, 0 (zero) or O, 1 or I, 5 or S, 8 or B etc.
If one or more keys on the keyboard have become malfunctional, try logging in to your account through some other device (if you have not done this already) or consider using a different keyboard (if possible).
You can also try onscreen keyboard by press and hold the Windows key and hit the letter R. Type in OSK and hit enter. Try using the onscreen keyboard if the keyboard is not functioning correctly.
GuruAid.com
Jul 17, 2014 | Computers & Internet
Setting new price for plu
Using the 'P' key, 'C' key turn the key to the PROG position, PRESS the 0 (zero) key and then 0 (zero). At this point, press the key of the item that you wish to change or Enter the PLU # and press the PLU Key. If the description of the item is ok then press 'cash/enter' and then press it again. You should be on the PRICE/Halo line, Change the amount to the correct amount and press cash/enter at this point you can then press the clear key and then turn the key to the 'REG' Position. Press the Key of the item you changed and it should display the new price.
Jun 20, 2014 | Samsung SAM4s ER-650 Cash Register
E5-5 error code on Treadclimbe
follow the steps and fix it. God bless you
The power up test sequence has detected a key in the operated condition. The power up test
sequence is performed every time the unit is turned on (powered up). This test is performed
because a permanently stuck key will inhibit the correct operation of the unit.
Possible Causes
1. A key on the display housing is permanently stuck in the operated condition.
2. One of the upper PCA's keypad interface chips has failed.
3. Liquid (perhaps perspiration) is present on the surface of a touch sensitive display.
Possible Remedies
1. Remove the keypad connector cable from the upper PCA. Restart the power up sequence, if
the ERROR 5 is no longer present, the keypad is the cause. The keypad is typically part of
the display housing. Replace the display housing to correct the problem.
2. Remove the keypad connector cable from the upper PCA. Restart the power up sequence, if
the ERROR 5 is still present, the upper PCA is the cause. Replace the upper PCA to correctc3d2efcd-4214-4aa4-b3ad-6b1e2ccdbf44.gif
Jun 20, 2013 | Exercise & Fitness
TREADCLIMBER tc5000 error code e5_5
see the steps and fix it. God bless you
Error 5
Description
Possible Causes
Possible Remedies
Nov 18, 2012 | Exercise & Fitness
Avery H500/L200 Avery Weighing Scales For ForkliftTruck When scales powered on, screen displaying ''balance limit''. Scales will not function.
The zero capture is out of the 2percent tolerance so the cell is either faulty or requires zeroing. Open the unit and press the micros itch on the left of the board. The display flashes s. Press the zero key to change to flashing E. Press store to scroll to zero balance. Press semi auto tare. This captures zero without clearing the span calibration. The display will scroll around for a short period when complete press store.. Release the micro switch and scale will go thru warm up routine then display zero. Hope this helps, regs Darren.
Sep 28, 2011 | Health & Beauty
My zero key was stuck so I took it off and need to put it back on
turn it around in the other direction your zero is upside down..
Jan 11, 2010 | HP Pavilion dv2000 Keyboard
Sometimes when I use a formula in Excel 2003 it will not calculate - it is as if the formula does not exist. an additional problem is that when the formula works it will not calculate several columns if...
Make sure, when you entr a formula that you hit the ENTER key instead of just moving to tyour next cell. To have all numbers added or moved, use the"Special" application, or change the value. Such as -if you are working in text mode and you enter numbers, they are only numbers in text mode. They don't have a value. Correct the cells to reflect numbers. Right click, format cell - select what you want.
Nov 05, 2009 | Microsoft Office Excel 2003 for PC
How to calibrate a Pelouze model 4010 scale with a
when i turn on my 4010.the screen display shows 4010 but thats all it does.any solution.
Jul 08, 2009 | RTO Pelouze Scale With Remote Display -...
Casio OH-260 Calculator Logo
26 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
