Question about Mitsubishi WS-55809 55" Rear Projection Television
The green timer light will not stop flashing and the tv will not turn on
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
ONLY 1 of 2 things can cause this problem----
First thing to do is remove front speaker grill--it should pull out and is secured with plastic pegs--behind it you will find an inspection plate---
Notice the one or two pairs of wires coming from the front keyboard of the set---remove the inspection plate and follow the wires to the right--you can unplug both plugs(most have two and they are marked with letters and different sizes so you cannot get them wrong)
The idea here is to remove the front keyboard with its reset button etc from the circuit---You will still be able to try to turn the set on with the remote---
These sets have a Receiver that is called a DM board--(large metal box to the left as you look from the back) and if the power goes out the green light will blink for about 70 seconds and then go out---it is the Receiver booting up. It is called the DM board.
If disconnecting the keyboard allows the set to turn on--you have a bad reset switch and two choices---either operate the set only with the remote or to remove the front screen and get at the reset switch (it is tiny) and remove and/or replace it.
If disconnecting the keyboard does not restore the set to operation---the receiver is bad---there are 4 or more caps and some pico fuses that can fail in that unit---Mitsubishi no longer sells or repairs these--if it is bad and not the caps there is a company you can send the unit to and have it repaired--if you need to know their name let me know---
You can call them and get a quote for repairing the receiver.
Let me know what more information you need--I am here to help.
If this told you something you did not know rate this solution as very helpful as I do this here for free.
SD TECH
Posted on Aug 24, 2010
I have a Mitsubishi WD-52725 DLP TV and green light (timer) is rapidly blinking after a power outage and set will not turn on. The bulb was replaced a month ago and it has worked fine since. Now it will...
Hello
make a System Reset process. To do this;
If the TV will not respond to either the remote control or the front panel controls and/or will not power Off, press the SYSTEM RESET button with a pointed item like the end point of a paperclip. The TV will turn Off and the TIMER light will flash quickly for about one minute. When the TIMER light stops flashing, you may again turn on the TV. The changes you made the last time the TV was on before you used the SYSTEM RESET button may be lost, however, the changes that were previously saved are not lost.
OK.
Apr 23, 2011 | Mitsubishi WD-52725 52". Rear Projection...
Flashing green light
Did you try this yet
SYSTEM RESET
turn on the TV again. Changes you made the last time
the TV was On before you used the SYSTEM RESET
button may be lost, however, the changes you made
previously are not lost.
POWER/TIMER Indicator
The green light is a multi-function indicator. This light
will flash rapidly for about one minute each time the TV
is plugged into the wall electrical outlet, when power
is restored after a power failure, or using the SYSTEM
RESET button. Do not attempt to turn on the TV again
during this period. Wait for the flashing to stop and
the light to turn off, before attempting to turn the TV
on. While the TV is powered on, the light illuminates
steadily. If the TV has been programmed to turn on
automatically using the Timer feature,
Sep 21, 2009 | Mitsubishi WS-65515 65" TV
Timer light did not stop flash
Lamp is not the issue. It most likely is a your DM card. You most likely have some capacitors that need to be replaced. This is a terrible issue with this unit. Do a google search for "DM" and the model number and you should see hundreds of posts.
Jul 02, 2009 | Mitsubishi WD-62525 62" Rear Projection...
My tv won't turn on, the timer keeps flashing
http://www.jyerdon.com/tv/
If it`s a 65513 mitsu, this will fix the flashing green light, most of the time, e-mail me with any questions, good luck
buranc@bellsouth.net
Dec 28, 2008 | Mitsubishi WS-65513 65" Rear Projection...
The TV wouldn't turn on...no power
sounds like you have a bad flyback in your set
Dec 14, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Green power light will not stop flashing and tv will not turn on or off
You need to replace the 1000uf capacitors on the DM board thats the classic symptom of the DM caps being bad the light continues to blink repeatedly. If you need more info on the repair let me know.
May 15, 2008 | Mitsubishi WS-55909 55" Rear Projection...
Flashing green timer light, no image on TV
4 capacitors on the DM board causes this they are 1000uf @35 volts replace these capacitors and that should take care of your problem
Mar 19, 2008 | Mitsubishi WD-52628 52" Projection HDTV
Mitsubishi WS-55809 55" Rear Projection Television Logo
368 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
