Question about Honda Pressure Washer PSI 3000
Oil leak appears to be from pump, not engine, GC160. What oil and how much should be replaced. what might be source of leak
    Problem Solver:
  • 18 Answers
Some pumps have a side glass and oil should be half of side glass and depends on manufacture oil is different if general pump you can use 30w non detergent
Posted on Aug 27, 2010
Our 2004 Isuzu Rodeo has developed a coolant leak. The leak appears to be around or above a little panel or plate immediately behind the oil pan? Cannot find any other source. What is inside the littl
You will have to clarify behind the oil pan. Front of engine towards fan. Rear of engine transmission side. Or above the pan towards engine side. If there is coolant leaking from behind the engine (between the engine and trans) and is not running down from above eg head gasket or hose connection, chances are good that there is a frost plug leaking on the rear of the block.
Dec 28, 2014 | 2004 Isuzu Rodeo
I have gas in my oil on my honda 5.0 gc160
Check the engine compression with a compression tester. Most likely you have a blown head gasket.
Sep 19, 2014 | replacehondaengines.com Honda 5.0 Hp...
Oil leak on driveway coming from front of engine
Dear Sir,
Here is the oil leaking Problem Identifying Technique
Engine oil leaks from the valve cover gasket are common.
  • The intake manifold plenum gasket may leak and cause increased oil consumption/burning and a spark knock during acceleration; the gasket should be replaced.
  • External oil leaks from valve cover gaskets, intake gaskets (front or rear), and the rear crankshaft (rear main) seal area are common. The rear main seal is an unlikely source. Normally, the bearing cap mating surfaces (as well as the sealing surface between the oil pan and bearing cap) are the source for the leaks.
  • Engine oil leaks at the distributor can be misdiagnosed as leaks from theintake manifold seal, oil pan gasket, or rear crankshaft (rear main) seal. A revised distributor is available if oil is found inside the distributor.
  • If the oil filter casing shows signs of distortion from excessive oil pressure, theoil pump should be replaced.
  • Often misdiagnosed as a leaking oil filter gasket, the oil filter adapter can seep from between the adapter and engine block.
  • Carbon buildup on the top of the piston is common. As the buildup increases with mileage and over time, symptoms may vary from light ticking, to ticking/hammering, to hammering/knocking noises. Fuel injector cleaner often solves the problem.
  • I think it helps to analyse u r Problem
    Nov 02, 2012 | Toyota Cars & Trucks
    95 dodge stealth oil leak near oil pump
    did you replace the seal on the bolt that holds it on
    Apr 17, 2012 | Cars & Trucks
    I have a 1999 Chrysler 300m 3.5 that is leaking oil. There is no obvious source from the engine, though it is possible. The car overheated last year and I had the dealer replace water pump and timing...
    CK- Try a set of Valve Cover Gaskets. It cannot leak from the front cover area because it is where the timing belt rides and there is no entrance into the engine EXCEPT the front CAM SEAL... Remove the cover and look toward that seal behind the cam sprocket. If so it is also leaking down into the front cover and beyond. But look at the Valve cover gasket first, since you mention that source.
    Auvedersein!!!
    Jun 07, 2011 | 1999 Chrysler 300M
    I have a North Star pressure washer GC160. What oil do I use in pump and what is recomended for the Honda engine? Can you also tell me where I can download a manual? Bob
    As far as the pump gose just use a 30 weight oil they call it pump oil but realy its a 30 weight oil if you want the # its AW-4085-0016 or equivlant . The engine oil is a 10 -30 in most tempatures they say use a 30 wight above 40 degrees but i use mobil one extend proformance 10 -30 all year long in all of my mechines and have never had any problems and there all honda engines . Just change the oil every year some of mind are 35 years oil and run perfictly
    May 09, 2011 | Northstar Pressure Washer 2800 PSI
    Oil leak
    You have to differentiate whether the oil leak is from the engine or the tranny. After determining where the source, you must isolate the specific area; timing belt area, the middle-between the engine and the tranny. This can be cheaply determine by placing white piece of paper underneath the engine and observe the droppings of oil. Oil leak repair can be costly-especially an oil starved engine, so isolating the source is essential and tear-down might required.
    Due to the age of the vehicle, possible sources are the camshaft seal, crankshalf seal, oil pan gasket, crankshaft end seal,distributor o-ring, and valve cover gasket.
    In addition, other oil leaks can come the transmission, and power steering pump and rack'n'pinion. Best to raise the vehicle and inspect undercarriage of vehicle.
    Oct 29, 2010 | 1998 Honda Civic
    My 1992 isuzu trooper is leaking oil .it appears to be coming from top passenger corner of oil pan.however oil has coated parts to rear and above oil pan.oil leak is slow.could this be oil pump.what are...
    clean your engine and look very carefully where the oil leak really come from, the cause why this leak happen, the engine was shutdown while the engine temperature is hot. usually the leak will come from the turbo. the engine must be idle for 3-5min before shutting off.
    Jun 30, 2009 | 1992 Isuzu Trooper
    Oil leak
    Sounds like the High Pressure Oil Pump mounting O seals. See if the soundproofing under the pump is soaked in oil to be sure.
    Apr 05, 2009 | 1999 Isuzu Trooper
    Honda Pressure Washer PSI 3000 Logo
    521 people viewed this question
    Top Honda Garden Experts
    John Trevino
    JOHN LAPIER
    Are you a Honda Garden Expert? Answer questions, earn points and help others
