Question about GE GSS25JF Side by Side Refrigerator
Hi, I have a GE GSS25JERF model refrigertor. I noticed it is not cooling and fan is stuck and not working in freezer section. Dispenser light is blinking. highly appreciate for any guidance
  • GE Master
  • 4,655 Answers
OK, Now would be a good time to see why the evaporator fan is stuck or not powered. Question is will you feel comfortable testing these items. I will give you a link to a Test Sheet and wiring diagram here=> GE GSS25JERF and I will be here to assist you. Thanks, Sea Breeze
Posted on Aug 24, 2010
Frigadare refrigertor side by side its cooling fine but the freezer wont freeze
Check the heater coil in rear of freezer. Mine was burned out. Letting ice build up on the cooling fins. Replaced with new type double heater coil and fixed proble. You'll have to remove the cover off rear wall of freezer section to access it.
Jul 04, 2014 | GE GSS20IEP Side by Side Refrigerator
My refrigerator side isn't cooling the freezer is fine on my GE Monogram Model zisb42dca
Possible faulty freezer fan motor. Dirty condenser. Faulty control board.
Feb 23, 2011 | GE Refrigerators
Refrigerator is not cooling, freezer stays @ or below zero what gives?
Thermisters have gone bad causing the damper to the fresh food section not to open,and or the freezer fan motor is not working.
Dec 12, 2010 | GE Profile Stainless Bottom-Freezer...
Freezer thaws and then Refreezes
Theory of operation: Cold air is produced in the freezer section and is then circulated via a fan located in the freezer section. It sounds like you may have either an air leak from faulty door seals, ice dispenser door flap stuck in the open position, or the light staying on the door is closed.
A faulty compressor fan may also cause symptoms like that but you should hear the thermal cut out clicking off and on due overheating of the compressor.
Oct 10, 2017 | GE Profile 26.6 cu. ft. Side-by-Side...
Freezer fan stopped working, water & ice dispenser stopped workin
these fan motors are usually good for 12-15 years, but occasionally one goes bad prematurely. IT NEEDS TO BE REPLACED. Some people try to reoil the bearings, but this is temporary and not worth the effort. The ice maker not working is only a consequence of the cold not being distributed by the fan not working. There are generic replacements that usually work well and cost $30 or less, whereas the GE replacement may cost $50-80.
Dec 27, 2009 | GE GSH25JFR Side by Side Refrigerator
Refrigerator and freezer running warm
Check and make sure fan in frezer section works properly.you should be able to hear fan slowing down when you open freezer, or find door switch and press and hold..hope it helps you..
Jul 07, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Freezer problem
Cooling is poor For an overall understanding of how refrigerators should work, read about refrigerators in the How Things Work section of our website. A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas:
Oct 23, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
GE GSS25JF Side by Side Refrigerator Logo
247 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
