Question about Sony Cyber-shot DSC-S700 Digital Camera
My camera got stuck, it lens its open, its stretch like it was on, but it is accually off, i tried batteries and it does not work, i tried connecting it to the pc and it dosnt work, i tried them both at the same time and its still dosnt work, please help me
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Aug 24, 2010
Stuck lens
Hi, 210 wide camera lens stuck is cause the spoil gear. This is commonly happen to physical damage camera.
Dec 26, 2013 | FUJIFILM Instax 210 Film Camera
Lens stuck open
hey, I had the same problem when I accidentally droped my camera, some parts in the mechanism are probably broken or jammed.
Most likely repairs required.
Apr 13, 2008 | Samsung Digimax S600 Digital Camera
My camera don't want to work
I checked and found another post, bc my camera was doing the same thing after 3 months of having it. Take a cotton swab to the battery connections. I did this and my camera worked, I wish I would have known this a year ago.
Jul 29, 2010 | Kodak EASYSHARE M1063 Digital Camera
My lens is stuck!
Sometimes this can happen if the battery cover was accidentally opened while the lens was moving. Try something simple. Turn the camera off. Open the battery cover and remove the batteries for 5 minutes. replace the batteries and secure the cover. Turn on the camera. The lens should go to it's home position. Let me know if this helps. And thanks for coming to FixYa. Don't forget to rate my answer!
Rob
Feb 08, 2009 | Polaroid T831 Digital Camera
My camera will not come on. and also the lens is opened out and will not go back in, i have put several new batteries in it, and if i put batteries in it and close the battery door, and push on, the light...
my camera will not turn on or off lense stuck open put new batteries still nothing my daughter took picture with it everything went blank its the samsung s630 worked fine till today!!
Jun 08, 2008 | Samsung Digimax S630 Digital Camera
Lens stuck open
try little rubbing alcohol around outer surface of lense this should loosen up the sticky ness of it
remove the memmory card and turn on this should reset camera
May 13, 2008 | Samsung Digimax 4500 Digital Camera
Lens is stuck open
We had the same problem with a Casio Exilim. Had been stuck for months...had nearly given up until I saw another post about banging the camera pretty forcefully to get the lens unstuck. I hit it once on the bottom onto my desk(w/ paper and blotter on the desk-so soft), then twice with the back of the camera against the desk. I turned it on and the lens was unstuck!! Immediately took a couple pictures and it seems to be working fine! If the camera may be lost, you've got nothing to lose to try this out...Good luck!
Apr 26, 2008 | Casio Exilim EX-S500 Digital Camera
Lens stuck halfway open
Fully charge the battery or connect the camera to the power supply (if you have an ac adaptor).
If it still does not work, it means that the lens is broken.
Reason can be that the camera was in your pocket pr carrying bag and the camera inadvertantly open and the lens mechanism was damaged. In this case, it needs repair.
Apr 21, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Lens stuck open
i have just had the same problem. mine was stuck open, i gave the lens a slight twist and heard a bit of a crack. i switched it on again, now it is ok.
Apr 09, 2008 | Samsung Digimax S600 Digital Camera
Lens stuck open
In a nutshell, this error happens when the lens gets stuck while trying to extend and comes slightly out of alignment. Particularly if it's been dropped while open. The lens gets stuck in the extended position, and refuses to move either to focus the lens or to retract when powered off.
If your camera is still under warranty, the best thing you can do have Polaroid should fix it. If your camera is out of warranty, or if Polaroid refuses to repair it for free, the one thing you can try is to If you gently, and I do mean GENTLY push against the lens with the PALM of your hand as you turn it on, it may cause it to depress back into the camera. If that doesn't work, and you can't reset it or turn it on/off several times, then you may have to send it in for a repair estimate anyway.
Dec 04, 2007 | Polaroid i832 Digital Camera
Sony Cyber-shot  DSC-S700 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
