Question about MTX Thunder 8000 T8154A Car Subwoofer
I have 2 8ohm 10" speakers an 2 4 ohm how can i wire them
I have 2 8 ohm 10" spaekers an 2 4 ohm how can i wire them
    Problem Solver:
  • 30 Answers
I need more info on the type of amp u want to use / do u have one amp or to amps that u are trying to use?
Posted on May 05, 2008
Loaded with 2-10" scorpions(8ohm)each, and a 18" black widow (?ohm)...can i load a 15" black widow(8ohm)using the same crossover Part# 90890170
I would assume that the 18" was a 4 ohm if the two 10" were 8 each. Though it might work in a pinch, the crossover point would be different and the balance between the speakers would probably be different as well. It's suggest calling Peasvey Customer Service to get the best answer. Here is their link-
Peavey com
Apr 19, 2016 | Music
I need to wire 2 12" DVC Lanzar MAXP124D to an 8 ohm load. Had it wired at a 2 ohm setting and it would over heat my amp. So tried to wire it to 8 and it wouldn't work. Need help.Thanks.
Your 8ohm channel is fried why happened was you ran 2 12s in an 8ohm load and turned it down to 2ohms the speakers was pulling all the power and that made it over heat and when it over heated it fried you're amp. It ain't no good you can't fix that
May 11, 2015 | Lanzar Car Audio & Video
I have a fender frontman 65r with a 8ohm speaker can i add another 8ohm speaker to this
http://cie-wc.edu/Series_Parallel_9_14.pdf
Not recommended.
you could add 3 more 8 ohm speakers in series / parallel wiring and keep an 8 ohm load to the amp, or
2x 4 ohm speakers in series, or
2x 16 ohm speakers in parallel
Jan 11, 2014 | Fender Frontman 65R 65W 1x12 Guitar Combo...
410 bass cab into 210
What kind of problem are you having with this, I assume impedance matching. 2 speakers in parallel cut impedance in half. ex. 2 x 8ohm in parallel equal 4 ohm. IF the same speakers are in series, they double impedance, ex. 2 x 8ohm in series equal 16 ohm. Now matching 2sp and 2 sp, both pairs SHOULD be wired the same and the removal of 2 (dep on config) usually would be treated as 1 ?ohm circuit that equal the other ?ohm circuit. AFTER the removal of 1 leg, the impedance could double or half, depending on configuration.
Mar 12, 2013 | Peavey Music
Hi, I want to know what is the best way to wire these subs. (Pair). I have heard of several ways. I have a 4 channel amp the soundstream picasso 4.760. Bridged it produces the most power. I was told...
Hello , I will be glad to help you.As far as your speakers..It depends on what impedance your subs are rated and if your Picasso amp can be bridged at 4ohm or 8ohm. If your subs are 8ohm each you can wire your subs in parallel and wire them to picasso amp in bridged mode. If your subs are 4ohm each.Then wire the subs in series then wire them to amp in bridged mode..caution do not wire subs in parallel if they are 4ohm .This would bring impedance to about 2 ohms and would be harsh for amp to handle...Goodluck
Sep 22, 2011 | Planet Audio BB212D Car Speaker
How do you wire a AW1000V to 1 amplifier?
The easiest way to wire this would be to make sure you have a 2 ohm amp, wire both voice coils in parallel to the amp. This means to connect both + terminals on the speaker to the + speaker output on the amp, then wire both - terminals on the speaker to the - speaker terminal on the amp. With the voice coils in parallel like this it makes it into a 2 ohm load at the amplifier. If you are running for example a 1000 watt amp at 2 ohms into this speaker it would give each voice coil the equivalent of 500 watts of power at 4 ohms. The other way would be to run the voice coils in series (voice coil 1 - terminal to - speaker terminal on the amp, voice coil 1 + terminal to the voice coil 2- terminal, voice coil 2 + terminal to the +speaker terminal on the amp.) The series wiring would give you a 8ohm speaker load to your amp so you would need a 8 ohm amp.
Mar 07, 2011 | AudioBahn AW1000V 10" Dual 4-ohm Voice...
I have older 15
If the speakers measure zero ohms, then the coil is shot. A speaker will not work if it has zero ohms. Replace the speaker. ALL speakers should read 4ohm, 8ohm or above. Zero means the coil wire is shoted. That there is no continuity.
Mar 31, 2010 | Orion Xtreme XTR15 Car Speaker
4ohm speaker connected a normal 8ohm crossover is
This is a wrong conection.For 8ohm crossover conect two speakers in serie and one in parallel to one of a previos.Check resistans by multimeter
Dec 02, 2009 | Parts Express 80 Hz LOW PASS 4 OHM...
When its hot outside all the speakers in my 2002 nissan pathfinder work great, but when it cools the slightest bit the front passenger speaker and rear drivers speaker stop working. can you help me with...
Hi I am Vortash it sounds like when they expand in the heat the activator coils are clear of the magnets giving a good sound .. but when cold they contract touching the magnets and you get poor vibrating sound ,, ? the problem may be two fold .. spaekers not man enough to take ower from unit .. especially if you have replaced the unit as most cars are only fitted with 10watt 8ohm to 4 ohm speakers as standard , and some of the newer cd players start at 25 watts this will disstort the speakers and they need replacing .. if this is not the case and you only have a low powered system usual culprit is water seeping down windows onto speakers at night from damp or early morning dew .. wet speakers tend to disstort.. hope this helps regards vortash
Jun 30, 2009 | 2002 Nissan Pathfinder
Directed 1100d 2-channel amp
You will bridge the amp, and if the subs are all 8 ohm subs, you can probably wire them all in parallel, if they are all 4 ohm subs, you would wire then in series.
Oct 17, 2007 | Directed 1100d Car Audio Amplifier
MTX Thunder 8000 T8154A Car Subwoofer Logo
87 people viewed this question
Top MTX Car Audio & Video Experts
hoyzee1
Mark Skinner
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
