Question about Toshiba Regza 32LV67U 32 in. LCD HDTV
My Regza digital TV has problems with reception. Several channels are perfect, but others keep breaking up and freezing both audio and visual. Other stations have no signal at all. My husband as a result installed a new digital aerial today but the situation hasn't improved at all.
I have the same problem with not much help from the store where i brought my TV from, they sell their items but as to good old after sales service it is non exsistant unless you are buying. They suggested it was the co-axial cable and also said the most likely factor is if you have a VCR connected then each time you want to watch TV take the aerial out of the VCR and put it directly into the TV, good one if you want to record on the VCR, this doesnt help the problem. Same you, I am still stuck with reception problems. By the way I have a 42' digital in the Loungeroom with VCR, DVD, Surround Sound all hooked up (& to same aerial on roof) with no reception problems, the one I am having trouble with is small digital TV in bedroom (room is next to loungeroom). I am on the Gold Coast in good reception area. Wonder if anyone has found a solution yet.
Posted on Nov 23, 2010
How do I keep it on Digital? When I try and turn the channel, it goes to Video 1. It says Digital channel signal strength is low.
How to fix digital TV reception problems - Simplify Digital
www.simplifydigital.co.uk > Guides
SimplifydigitalJul 11, 2014 - This handy guide will help you fix simple digital TV reception issues with Freeview, satellite and cable TV set top boxes. ... If you're suffering from poor digital TV signal, it may be possible to fix reception issues quickly, at home. ... We're here to run you through how to fix TV ...
Digital television transition in the United States - Wikipedia ...
Dec 26, 2015 | Televison & Video
My channel 7 keeps freezing and comes up with no signal sometimes for days when it's though my my bush digital recorder box. But when it's just though the tv channel 7 works fine. What's going on??
Different digital boxes and tv's have different levels of RF gain. Some need more signal and some need less to work efficiently.
Possibly your Bush pvr needs a much stronger signal than your tv so the available signal is permanently on the threshold of reception and atmospheric conditions will some of the time reduce the available signal when reception will become impossible for the box but still be above the threshold for the tv set.
Modern Bush is not reknown for being a high quality brand and the purchasers of budget brand pvr's often discover reception or performance problems in fringe signal areas. Because a single aerial must receive a very wide range of frequencies it will be more efficient for some channels than others and so one channel could be a fringe channel and another channel produce a very strong frequency.
The signal strength and quality can be checked for each channel by selecting options in the menu in order to check this theory.
The problem might be solved by replacing the Bush pvr with a premium brand or replacing your aerial for a more efficient type. One of my friends had five different boxes before he gained a satisfactory performance and another friend three boxes and still has problems.
My installation has a new high gain wideband aerial on top of my 3 storey house and a distribution amplifier in the loft to keep the input lead short and the whole lot connected by very good quality double-wrapped co-ax.
I had to add different amounts of attenuation for each box or tv set but in spite of the signal being on average too strong and needing attenuating there are still channels for which the aerial is not as efficient and providing only a weak signal.
Feb 09, 2015 | Bush Televison & Video
My tv keeps freezing up on me
are u using off antenna, like air and not cable, this is because reception comes in and out, if this happen with a dvd playing or some other video, then it's your tv or maybe cable coming in to set.
Jan 08, 2011 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Is my regza tv model 32rv635d hd ready or full hd.
Hello The Toshiba Regza 32RV635D is a Fully HD TV. with four HDMI connections.
Connections
The location of the connection ports is in keeping with today's standards. They are easily accessible and well constructed.
Port Listing: 4 HDMI, 2 SCARTs, Headphone Jack (with Independent Volume Control), S-Video, Composite Video, Common Interface, Component Video, Digital Audio Out (Optical/Toslink), RF In and D-Sub.
You can read the reviews here:-
http://reviews.cnet.co.uk/tvs/toshiba-regza-32rv635db-review-49302355/
and
http://www.techradar.com/reviews/audio-visual/televisions/plasma-and-lcd-tvs/toshiba-regza-32rv635db-679432/review
Hope this helps, if so do rate the solution.
Jan 03, 2011 | Toshiba REGZA 47HL167 TV
Hi, I have a digital tv plugged into an extension cable in an upstairs (Toshiba) bedroom; it works perfectly - receiving all channels. I have a digital tv downstairs (Samsung) where it seems the wall...
Hi Fiona
Somewhere along the line from the aerial there must be a signal splitter that feeds the upstair and downstair terminals.
Try to find that splitter and switch the output to see if the problem goes from up to downstair.
If it does switch then you know the problem is with the splitter block, and if it stays the same then the problem is with the cable and/or the connectors that run downstairs.
Also the reason you get a pixellated(snowy) picture is because of signal loss during the length of the cable you ran downstair.
If running a cable downstair becomes the best option to fix your problem , then you could buy a cheap 10db signal booster/r.f amplifier to correct the signal loss and a cable splitter to feed both tv`s
That booster would be installed upstair in your case(near the source of the signal to be amplified).
I could send you a small diagram if need be. Hope this will help and Merry Chrismas
Dec 14, 2009 | Televison & Video
Insignia LCD32 digital channels are breaking up.
coax feeding that tv may be too long or bad.
Try switching tv's if possible.
Some TV's have better reception that others.
Dec 04, 2009 | Insignia IS-LCDTV32 32 in. Television
Panasonice TV freezes and stutteers off of cable when in HD
if the picture keeps breaking up and pixelating it is normally a reception issue rather than a problem with the tv.
Nov 28, 2009 | Televison & Video
Loud Static NOISE (no visual problems)
You have a problem on your sound mother board.
Aug 25, 2009 | Televison & Video
Trouble tuning in empty dtv channels
Just go to the main settings. You will see an "autoprogram" option. Select this and it will scan all available channels and delete non-airing channels
Jun 22, 2009 | Toshiba Regza 32LV67U 32 in. LCD HDTV
Audio is breaking up, but only on some channels.
It turned out to be a faulty cable. We replaced the cable - problem fixed.
Dec 06, 2008 | Polaroid FLM-4234BH 42 in. LCD HDTV
Toshiba Regza 32LV67U 32 in. LCD HDTV Logo
316 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
