Question about Whirlpool AD40DSL Dehumidifier
The bucket of my Dehumidifier is filling up with water.
  • cbrews May 07, 2008
    Sorry, I meant to say that the bucket is not filling up with water.
  • 828 Answers
That is what it is designed to do. Most dehumidifiers come with a hose connection on the bucket. To use this hose connection there is a knock-out inside the connection where the hose attaches that must be removed. The alternative is to empty the bucket when it gets full. Most Dehumidifiers are set up with a switch that will shut it down when the bucket gets near to full.
Posted on May 05, 2008
  • James Helmer
    James Helmer May 13, 2008
    If everything is operating and you are not getting water out of it your system could be low on refrigerant charge. If it is low on charge it has a refrigerant leak at some point in the system.
  • 1073 Answers
SOURCE: Problme in the dehumidifier not filling the bucket.
the unit has a sealed system issue in one of the coils, need to get it to a service company that services the brand that you have
22yooper
  • 828 Answers
SOURCE: Dehumidifier Error?
Your bucket full switch may be defective. If you are capable, bypass it since you are draining to another place other than the bucket.
Posted on May 09, 2008
SOURCE: Problem with draining water through hose
I raised mine up on a platform about 6 inches, and now mine works fine. Don't know why this is necessary, but atleast it works now.
Posted on Aug 15, 2008
  • 12 Answers
SOURCE: Danby continuous water flow will
Please try the following:
1) Remove the bucket.
2) You will notice a round outlet/spout where the water drips from into the bucket.
3) Remove the plug from the backside of the unit (you will now see a hole to the bucket area).
4) Feed a hose through the hole from the back and attach the end of the hose to the round outlet/spout.
5) Place the other end of the hose on a floor drain outlet.
6) Put the bucket back into the unit.
When the unit is turned on, the water will now flow through the hose instead (into the floor drain). When you want to use the bucket again to capture the water, you will need to remove the hose.
I hope that helps.
Posted on May 19, 2009
  • 51 Answers
SOURCE: Kenmore 54501 Dehumidifier no water in bucket
may have lost ref charge check name plate for type of ref with 12 and 22 cost of gas cost proh. check tubing in rear should be ice cold to gather condensate if not probably lost gas
Posted on Aug 09, 2009
How to get direct drain option to actually work on my Edgestar DEP700EW dehumidifier?
The outlet is probably clogged with moss or foriegn bodies. Clear the water way.
Sep 11, 2014 | EdgeStar 70 Pint Portable Energy Star...
Is there a call back on unit lad704tdl dehumidifier
Good Morning Friend,
I understand you are wondering if there is a recall on your Frigidaire dehumidifier, model# LAD704TDL. I see that the bucket is not filling with water when your appliance is running. I don't believe there are any recalls. I suggest contacting the manufacturer for further assistance. They should be able to point you in the right direction. Hope this is helpful.
-Best regards-
WP
Jun 30, 2014 | Frigidaire Dehumidifier LAD704TDL
The bucket fills up but we have to put a towel down because it leaks all over the floor. What could be wrong ?
Good Afternoon Friend,
I understand that the bucket fills with water and overflows on your Frigidaire dehumidifier, model# FAD704DUD. Please make sure your dehumidifier is installed on a level that will support it with a full bucket of water. If the dehumidifier is moving when it fills with water then this could possibly be the cause of the bucket overflowing. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 25, 2014 | Frigidaire FAD704DUD 70 Pint Dehumidifier
How much water do I put in water bucket on this thing?
You don"t put anything into the bucket. A dehumidifier will fill the bucket for you.
Jan 13, 2013 | Whirlpool AD50USL Dehumidifier
Motor is making very loud noise when on and bucket is not filling up with water. Machine is getting very very hot at the top when turning on.
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Sep 02, 2011 | Amcor AHD65 Dehumidifier
Dehumidifier will run but the bucket won't fill. Is there a way to run my model without the bucket? I have a maytag m7dh4582a and do not have my manual. Could their be something else wrong with it?
Is it producing water or not??? If no water is being produced, then check out this tip...
If you are making water and it is just going all over the place then, the little spout coming off the bottom of the coil, that runs the water into the bucket is clogged with dirt and you just need to take a small toothpick or knife and work the dirt out of the spout...
heatman101
Jul 23, 2011 | Maytag M7DH45B2A Dehumidifier
My dehumidifier is running but no water is collecting and the bucket usually fills in a few hours, what can be the trouble I cleaned the screen.
heatman101
Feb 15, 2011 | Whirlpool Gold AD70USS 70 Pint Per Day...
I have a AD50USR1 Dehumidifier. I filled the bucket with wayer, but when i slide it back ito place, the bucket is not pushing that button on machine to operate it. It says to fix or adjust bucket. How do...
Why would you be putting water INTO a Dehumidifier??
The idea of a dehumidifier is to EMPTY the bucket, then the machine takes moisture out of the air, fills the bucket and you empty it again.
Are you sure you need a dehumidifier and understand how they work?
Aug 02, 2017 | Whirlpool Dehumidifier Dehumidifier
My kenmore dehumidifier won't pull the moisture out of the air, the motor is runing when turned on but the bucket never fills up. What is the problem?
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Jun 10, 2009 | Kenmore 53509 Dehumidifier
Whirlpool AD40DSL Dehumidifier Logo
545 people viewed this question
Top Whirlpool Dehumidifiers Experts
Bill Long
Mike Squire
Mike
Are you a Whirlpool Dehumidifier Expert? Answer questions, earn points and help others
