Question about Cub Cadet Garden
I have a 2009 Cub Cadet RTZ 54, the hour meter does not work! Is there a fuse or circuit breaker that controls this unit? If so, where is it and how is it replaced? Thanks
boscia
  • 163 Answers
SOURCE: hydrostat pump leak,cub cadet garden tractor
try tightening the connections. if that doesnt work you can disconnect and wrap the threads with teflon tape but this requires draining the hydro system
Posted on Nov 30, 2008
  • 62 Answers
SOURCE: Z force 48 in. cub Cadet mower starts but dies
Check the wires to the seat switch. Under the seat you should find 2 wires connected to the seat. Unplug them, and use a jumper on the end that goes into the body of the mower. Try it again, and if it works, replace your seat.
Posted on Apr 18, 2009
  • 109 Answers
SOURCE: cub cadet 1024 wont turn over
try taking an insulated screw driver and jumping across both terminals on the solenoid, if the engine turns over, the solenoid is bad and will need to be replaced
Posted on May 03, 2009
  • 323 Answers
SOURCE: install belt on cub cadet mower
First, make sure you have the model number and serial number (located under the seat) and then go to www.cubcadet.com to get a belt diagram so you know which way the belt snakes through the pulleys.
You will have to remove the two pulley covers on either side of the deck.
Fit the belt around the right side of the deck pulleys when you are on the left. There is an arm attached to the springed pulley on the left side. It will have a hole the size of a 3/8" driver/ratchet. Set the ratchet on unscrew (to the left) and push the arm in toward the center of the mower. You will see the pulley moving too, creating enough slack to slip the belt over the edge of the rim of the pulley with a little elbow grease. If it is too tight, get someone to push in with the ratchet while you slip it on. Once again, you are the grass cutter king!
Posted on Jul 25, 2009
  • 133 Answers
SOURCE: CUB CADET
Look under the battery holder. There is alot of wires that come down from the ingition and the fuse should be mounted or fastened right under the battery holder.
Posted on Sep 01, 2009
1 year old rtz and I ran over a limb that fell in the yard. The mower made an unusual noise and stopped. Engine runs good blade engages but when you press the gas to go in forward/rev nothing happens
it is possible that the limb got caught in the pulley and made the drive belt pop off. look under it and see if there is a belt that looks really loose or out of place.
Apr 01, 2017 | Garden
Cub cadet RTZ 54 hard to start once started runs
sounds like you have a bad stater overcharg check the amps coming out of it
Oct 02, 2014 | Garden
Cub cadet RTZ L54 Hard to start once running it
you have a short in your harness some where
Sep 30, 2014 | Garden
Cub cadet RTZ L54 Hard to start once running it runs a few minutes and blows the fuse bad shuts off
Sounds like your voltage regulator is no longer regulating the voltage produced that's being sent to the coil and you're getting spikes too high that can damage the charging system or ignition system and melt things, so the fuses are doing their job, but you need to correct the problem to be safe and have a good working unit.
How can I tell if my starter is bad on my cub cadet rtz mower
Check for spark
Have to get the test plug for small engines
Is the battery years old & partially dead?
Is the oil clean & full
Won't turn over or won't start?
Clean the flywheel & ignition coil or whatever
system it has for spark
Check for intake gasket leaks.
Did the meter always go down to 9.8 when it did start?
Your best to work on things & learn-- when they work correctly,
not wait for years then be lost
May 08, 2014 | Cub Cadet Garden
Hi I did a tune up ,changed and checked every thing I done ..too I changed the oil ,oil filter ,gas filter air filter ,got a new battery changed the plugs there new too...even a new belt new key ...but...
Spark and gas??? Must have both. Pull spark plug wire and check for spark. If you have spark, check gap on spark plug. Check the bowl on carburetor. loosen bowl screw to see if gas is coming out. If you have gas coming out, carb needs to be taken off and cleaned or rebuilt.
Oct 11, 2013 | Cub Cadet Street Sign- tractor lawn riding...
I have a cub cadet RZT 54 that was purchased in the spring of 2009. The mower cranks and runs fine but the blades will not engage. Have looked at electrical connections and everything looks fine.
Do you hear a "clunk" when you engage the PTO switch, but the blades don't turn? If so, then check the mower deck belt - is it properly threaded, and tensioned by the idler pulley? If there's absolutely no sound when you engage the PTO switch, the problem is likely electrical (even though everything looks OK). The PTO switch, PTO clutch, and the reverse lockout switches (near the bottom of the fwd/reverse control arms) should be checked. I don't think there's a separate fuse for the PTO on your mower, but there may be a relay. Even though these parts and connections look OK, they can fail internally. Best bet is to get a multitester and check each of them with the ohmmeter function.
Jul 02, 2010 | Cub Cadet Garden
Blown fuses when mowing
you have a wire that is shorting out somewhere, i would trace the wires from the clutch all the way back to the fuse including the relay and pto switch. You will more than likely find your problem in the control circuit between the fuse, pto switch and relay since this is what is fuse protected.
Aug 06, 2009 | Oregon Scientific Electric PTO Clutch for...
Garden Logo
73 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
