How can I disable the security block so I can use another computer on the network without setting it up with the security used on my main computer
  • 209 Answers
You need to configure the firewall, double click the control panel then click exception then click ADD PROGRAM. you need to select the program you want to allow.
Posted on May 13, 2008
Want to put lock on guest
Linksys E series routers can broadcast 2 wireless networks. First one is the main wireless network which is secured wireless network.
The second network is a guest network which will always show you unsecured.
It will never show you secured and you can not make it secured.
However it has a web based security.
Anyone can connect to the guest network but will not be able to access Internet without Guest access password.
In other words there is a security.
You can disable guest access also.
See more about Cisco Guest network access password
Mar 10, 2012 | Cisco Linksys E1000 WirelessN Broadband...
Allowing Network Access with Blank Passwords with Vista
Although you can log in locally without a password, by default, Vista does not allow network users to access the computer without a password.
To change this setting:
Run gpedit.msc
Go to Computer Configuration / Windows Settings / Security Settings / Local Policies / Security Options
Double click on Accounts: Limit local account use of blank passwords to console login only
Disable this option
on Feb 07, 2008 | HP Pavilion a1410n (ER890AA) PC Desktop
How to blocked the wireless
You can change the wireless settings of the router and make it secured. So that no one will be able to connect to your wireless network without a password.
Do not share your wireless network password with anybody.
If you want you can also disable the wireless broadcasting at all.
For this you will need to access the settings page of the router and change the settings manually.
Connect the computer to the router with the Ethernet cable and open the setup page of the router using
Go to wireless tab and make it secured.
See Linksys router how to
Jan 05, 2012 | Linksys WRT54GR Wireless-G Broadband...
Find ssid number for linksys model wrt54g
SID broadcast allows computers to quickly locate a new network and connect to it. In wireless home networks computers often use only the home network, which makes SSID broadcast unnecessary. Disabling SSID broadcast adds a bit of security to your wireless network, because computers won't be able to see your network's SSID.
Log into the router.
  1. Open your webbrowser and type in the address bar. This is the default IP address of the browser.
  2. Type your login info in the login screen. Default: 'admin' (without quotes) in both fields.
  3. Go to Wireless > Basic Wireless Settings 'wireless
  4. Set SSID broadcast to 'disable'.
  5. Click Save Settings.
On the next page you will set a router password to prevent unwanted visitors from accessing your router setup.
Sep 23, 2011 | Linksys Wireless-G WRT54G Router
I have a Linksys WRT160N router that I am using with a MacBook Pro laptop running Snow Leopard. I used my computer (with some difficulty) to set up the wireless access by way of a wired connection. The...
My Friend ,
Login the router setup page .
And under router security settings uncheck the option (block anonymous internet request).
Set the wireless channel as 6 or 9.
And then use wep security key.
this will surely work.
Regards :-
Jan 07, 2011 | Linksys WRT160N Wireless Router
I need to take my password off my wireless router
I think you want to disable the security of the wireless network. You want to use the wireless network without the password.
Am I right ?
You will need to access the router setup page. On this page you will find all the settings of the router. You can change the wireless settings. If you want to disable the security then you can do it OR if you want to change the password then you can change that also.
For this your computer should be connected to the router with the Cable.
Click here for step by step solutions
Jun 23, 2010 | Computers & Internet
Security code software for SE mobiles
It's defaultly 12345 and if it's not working just go to any mobile shop and tell them , they will simpley attach there phone to computer . they have a legal software which read your phone and you can get your code .
Jun 23, 2009 | Sony Ericsson K850i Mobile Phone
How can I use the WiFi on my ATT Tilt, without paying for the extra service from ATT?? Please help!
call att and have them block the data. If you do this you won't get it will eliminate any data charges. Then you can only use wifi it works great, but the downside is you can't ever get internet without wifi.
Apr 08, 2009 | HTC TyTN Smartphone
New Modem with a router for wireless Laptop
Some routers have a kind of built in firewall. You need to let the router/modem that it is okay for it to let this information pass through it. Here are your instructions
Follow the steps in this chapter and use the Gateway’s web-based utility to configure the Gateway. This chapter
will describe each web page in the Utility and each page’s key functions. The utility can be accessed via your web
browser through use of a computer connected to the Gateway. For a basic network setup, most users only have to
use the following screens of the Utility:
• Setup. On the Setup screen, enter the settings provided by your ISP.
• Security. Click the Administration tab and then the Security tab. The Gateway’s default username and
password is admin. To secure the Gateway, change the Password from its default.
There are seven main tabs: Setup, Wireless, Security, Access Restrictions, Applications & Gaming, Administration,
and Status. Additional tabs will be available after you click one of the main tabs.
• Setup. Enter the Internet connection settings on this screen.
• Basic Wireless Settings. You can choose your wireless network settings on this screen.
• Wireless Security. This screen allows you to choose your wireless security mode.
• Wireless Network Access. This screen displays your wireless network access list.
• Advanced Wireless Settings. On this screen you can access the advanced wireless features.
• WDS. The wireless distribution system feature is accessed on this screen.
• Firewall. This screen contains filters and the Block WAN Requests feature. Filters block specific internal users
from accessing the Internet and block anonymous Internet requests.
• VPN Passthrough. To enable or disable IPSec and/or PPTP Passthrough, use this screen.
Jan 20, 2009 | Linksys Computers & Internet
Can,t unstiall norton
Norton Internet Security 2004/2005 has an effective firewall. This is in addition to the Windows firewall. Firewalls monitors and restricts information that travels between your computer and a network or the Internet and provides a line of defense against someone who might try to access your computer from outside the Firewall without your permission. In this case the windows firewall was disabled and Norton Firewall was the main one. When some program from your computer tries to connect to the internet, Norton Internet Security gives a prompt, which has options to allow or block the access. Many times the recommended option is to block the access. So be careful to see what you are blocking internet access before clicking OK. Click the Norton Security icon at the bottom right corner in your system tray. On the pop up window, first check if you have not clicked ?Block Traffic? button. As this will block all internet access. If that is ok, maybe the program has been blocked access and has to be unblocked manually. But it was not easy to find where was the blocked list. But here is it location. Go to Norton Internet Security > System and Settings and this is what you see ... Then you see that the Personal firewall is turned on to protect from unauthorized access to spyware, adware and other unwanted software. Click ?Configure? button. Go to Programs and scroll down the list for Manual Program Control. There you will see the individual internet access settings for each individual program. And you see that Mozilla Firefox/Internet Explorer setting shows ?Block All?. From the drop down list select ?Permit All? and now open Firefox. It works! And he is back to using firefox as his default browser again. Now you can scroll through the entire list and individually set the programs to allow and block internet access. Now you may fix some programs not working with the internet which you might have blocked by mistake. You can also set some allowed programs to block. I hope this tip helps. Now figure out the Custom option yourself!
Sep 27, 2007 | Symantec Norton AntiVirus 2004 - (Open...
Computers & Internet Logo
David Payne
David Payne
