Question about Brother Office Equipment & Supplies
I have a Brother printer and everytime I try to print something the paper gets jammed. How can I fix this?
    Sergeant:
    Champion:
  • 387 Answers
Take the tray out and look at the bottom where the paper goes in maybe its dirty or there is a paper stuck or the roller doean not move
i dont know what model you have but if you have manuel feed try it and see if the printer is ok so you know that its only the tray feeder
Posted on Aug 24, 2010
Hello FixYa, I have a problem with my Brother MFC-240C. Everytime I try to print something I get a paper jam error message. I have tried opening the back cover and removing the paper but it still does...
This is not a fix, but a troubleshooting step. After you perform this step, please respond and let me know the outcome.
Take a small stack of paper (less than 50 sheets) and place flat in a refrigerator overnight. After the paper has been in there for at least 8 hours, pull it out and fan it (to remove static cling between the sheets). Place in the printer and see if the paper will feed correctly.
If it does, then your problem is high humidity which is a common cause for paper sticking together and causing paper jams. If it doesn't, then you've probably got a torn piece of paper somewhere in the paper path that is causing a jam. Either way, let me know your results so I can help you troubleshoot your issue.
Apr 10, 2011 | Brother Multi-Function Center MFC-240C...
I have a brother mfc 7420 and every time I print it tells me paper jam, I pull the paper tray out fix the paper push start it tells me paper then I have to pull out the cartridge and pull out the paper...
Sounds like there is something in the paper track that's causing this to jam. Its not always easy to get small particles cleared just by removing the jammed paper.
This may not help everyone that I send it to, but it is worth a try.
I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press
the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer.
The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Sep 20, 2010 | Brother MFC 7420 All-In-One Laser Printer
Paper jams??
click here to download yor required drivers
May 12, 2010 | Brother MFC 6490CW InkJet Printer
Says there is a paper jam everytime i try to print
Hello
Check within your paper feeder rollers there might be something stuck inside it like paper clips, coins or anything small and solid. If you can find way to open the printer without braking it, that would be nice.
Hope this helps.
Jan 12, 2010 | Canon PIXMA MP180 All-In-One InkJet...
No Help Any Where For this Problem"Unable to Print 50 or 30 Both"
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry.
Keep printer unplugged for about 2 minutes and replug and try a test print.
Also make sure that you have waited long enough for the printer to heat up before giving a print job.
Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Hope that helps!
Aug 19, 2009 | Brother MultiFunction Center MFC-440CN...
Brother mfc-420cn printer envelope jam
If you did not get ALL the jammed sheet out, there is still a small piece of paper in there somewhere, probably covering a sensor or micro switch. Get a torch and look carefully. If you don't find anything you may need to disassemble the printer to find it
May 14, 2009 | Brother MFC 420CN All-In-One InkJet...
Get paper jam error on Brother MFC 5840CN
are you using brother oem ink? generic ink gives lots of problems
Dec 09, 2008 | Brother MFC-5840CN All-In-One InkJet...
Paper Jam
Seems you have a dusty roller in the feed mechanism. try cleaning off the roller with some windex (or equivalent) on a towel.
Nov 18, 2008 | Brother MFC-9420CN All-In-One Laser...
Brother printer jams all the time
Be sure the paper tray is not over full and maybe even fan the paper before loading. Check all the corners that hold the paper as they are usually adjustable for different paper sizes and sometimes move or become unattached. The paper must lay flat and snugly in all places in the tray to load properly.
Mar 28, 2007 | Brother MFC 420CN All-In-One InkJet...
26 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
